USB3 streaming slower then expected
Sorry i meant the J11 header.
I am using the RB5 drone with the 5G modem optional daughter card. This drone with this cable
picture of my setup:
OK, @Chris-Hinkey
Thanks for confirming. We should probably send you a new cable. That one in your image is an early proto-type, and surprised we shipped that. New ones have twisted pair cables on the diff pairs as shown on the website.
I'll ask our folks to send you one so you can retry with a better cable. -
Ok, sound like a plan.
Do you think its reasonable to believe that the over/underflows are cause by a bad wire in this case? or is there likely something else going on?
@Chris-Hinkey When we test throughout, we use iPerf. With USB2 only, we see it runs at about 340-380Mbps ( makes sense with overhead losses, etc).
If you do the same type of testing, you can quickly tell if despite enumerating at USB3, only the USB2 signals are working.
I'm not sure if your issue is HW or SW related, but for certain that cable is not correct. I tried to purge them from our inventory when I saw them but some made it out. With the new cable on the way, you should certainly get much better throughput. We can't guarantee greater than 3-5Gbps though since the new cable is still a prototype and has no shielding required to get full 10Gbps USB3 rates. I have that note on our cable tech docs page. Let me know when you get the replacement then we'll know better if there is some SW issue also occurring.
Thanks! -
I received the new cable thanks for getting that out so quickly. I ran through my set of tests and I am seeing similar performance as before.
is it possible the USB hub on the 5G card only supports a lower standard of USB?
I am willing to run an iPerf test in our lab, can you give me a bit more detail on how to perform the tests that you run?
are you using a usb 3.0 to 10G ethernet adapter or doing this directly over USB?
how do i my hardware setup to run that test?
Hi @Chris-Hinkey
Glad you got the new cable and were able to help rule that out.
The Hub on the M0090 is a USB3 hub, with USB3 backhaul. It is certainly capable of several Gbps.Is it possible your device is not setup to run faster as well? Maybe it is limited to USB2 speeds?
On another post I was just helping a user also understand that when you add in encryption, you are slowing your data rate for the same radio/link rate due to adding more overhead. Something else to think of where maybe your reported sample rate is correct, but you have a 3x overhead loss due to coding or encryption of the link? Food for thought... maybe disable all encryption/parity/ECC, etc on the link to see if you can get your data rate as close as possible to the baud/link rates, then individually enable those back in to see the impact of overhead losses?I'll have to pull in @tom for help on running iPerf. You might be able to use any OTS USB to ETH dongle that supports Linux and you should have a network that supports it somewhere to connect to and push that throughput.
This same benchmarking application works perfectly on an intel based laptop or desktop at full rates of 56MS/s full duplex. it is just streaming I/Q samples no extra overhead.
Its possible that the problem is CPU bound but i would expect higher utilization reported from
top
while the benchmarking application is running if that was the case.I am hoping that running your iPerf test sheds some light on what is happening. looking forward to some guidance.
@Chris-Hinkey You could use that USB -> JST cable + an ethernet to USB-A adapter, we like this one: https://www.cablecreation.com/products/usb-3-0-gigabit-adapter-2-pack?_pos=8&_sid=9389ea323&_ss=r
and then connect ethernet from that adapter to your desktop / laptop.
With internet connected to your VOXL2 via. WiFi on ethernet you can run the following to install iperf:
sudo apt update sudo apt -y install iperf3
Then once you verify that you can ping your VOXL2 from host machine (or vice-versa) you can run
iperf3 -s
on one machine andiperf3 -c <server IP address>
on the other. -
Sorry it took me a while to get back to this effort. I was able to run the test i am seeing some interesting behavior.
between a 1Gbps nic on linux box and 1Gbps usb to eth module on drone:
drone(server) to lab04:
Connecting to host 192.168.1.10, port 5201 [ 4] local 192.168.1.20 port 55110 connected to 192.168.1.10 port 5201 [ ID] Interval Transfer Bandwidth Retr Cwnd [ 4] 0.00-10.00 sec 398 MBytes 334 Mbits/sec 1127 144 KBytes [ 4] 10.00-20.00 sec 420 MBytes 352 Mbits/sec 646 124 KBytes [ 4] 20.00-30.00 sec 409 MBytes 343 Mbits/sec 1051 91.9 KBytes [ 4] 30.00-40.00 sec 402 MBytes 337 Mbits/sec 859 122 KBytes [ 4] 40.00-50.00 sec 411 MBytes 345 Mbits/sec 591 119 KBytes [ 4] 50.00-60.00 sec 414 MBytes 348 Mbits/sec 958 123 KBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth Retr [ 4] 0.00-60.00 sec 2.40 GBytes 343 Mbits/sec 5232 sender [ 4] 0.00-60.00 sec 2.40 GBytes 343 Mbits/sec receiver iperf Done.
lab04(server) to drone:
Connecting to host 192.168.1.20, port 5201 [ 4] local 192.168.1.10 port 52686 connected to 192.168.1.20 port 5201 [ ID] Interval Transfer Bandwidth Retr Cwnd [ 4] 0.00-10.00 sec 297 MBytes 249 Mbits/sec 0 208 KBytes [ 4] 10.00-20.00 sec 301 MBytes 252 Mbits/sec 0 208 KBytes [ 4] 20.00-30.00 sec 294 MBytes 247 Mbits/sec 0 208 KBytes [ 4] 30.00-40.00 sec 297 MBytes 249 Mbits/sec 0 208 KBytes [ 4] 40.00-50.00 sec 295 MBytes 248 Mbits/sec 0 208 KBytes [ 4] 50.00-60.00 sec 301 MBytes 252 Mbits/sec 0 208 KBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth Retr [ 4] 0.00-60.00 sec 1.74 GBytes 250 Mbits/sec 0 sender [ 4] 0.00-60.00 sec 1.74 GBytes 249 Mbits/sec receiver iperf Done.
between a 1Gbps nic on linux box and 1Gbps usb to eth module on another linux box:
lab01(server) to lab04:Connecting to host 192.168.1.20, port 5201 [ 4] local 192.168.1.10 port 56964 connected to 192.168.1.20 port 5201 [ ID] Interval Transfer Bandwidth Retr Cwnd [ 4] 0.00-10.00 sec 1.07 GBytes 923 Mbits/sec 0 208 KBytes [ 4] 10.00-20.00 sec 1.07 GBytes 921 Mbits/sec 0 208 KBytes [ 4] 20.00-30.00 sec 1.07 GBytes 921 Mbits/sec 0 208 KBytes [ 4] 30.00-40.00 sec 1.07 GBytes 921 Mbits/sec 0 208 KBytes [ 4] 40.00-50.00 sec 1.07 GBytes 921 Mbits/sec 0 208 KBytes [ 4] 50.00-60.00 sec 1.07 GBytes 921 Mbits/sec 0 208 KBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth Retr [ 4] 0.00-60.00 sec 6.44 GBytes 921 Mbits/sec 0 sender [ 4] 0.00-60.00 sec 6.43 GBytes 921 Mbits/sec receiver iperf Done.
lab04(server) to lab01:
Connecting to host 192.168.1.10, port 5201 [ 4] local 192.168.1.20 port 46692 connected to 192.168.1.10 port 5201 [ ID] Interval Transfer Bandwidth Retr Cwnd [ 4] 0.00-10.00 sec 1.10 GBytes 942 Mbits/sec 0 477 KBytes [ 4] 10.00-20.00 sec 1.10 GBytes 941 Mbits/sec 0 477 KBytes [ 4] 20.00-30.00 sec 1.10 GBytes 941 Mbits/sec 0 477 KBytes [ 4] 30.00-40.00 sec 1.10 GBytes 941 Mbits/sec 0 477 KBytes [ 4] 40.00-50.00 sec 1.10 GBytes 941 Mbits/sec 85 389 KBytes [ 4] 50.00-60.00 sec 1.10 GBytes 941 Mbits/sec 0 494 KBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth Retr [ 4] 0.00-60.00 sec 6.57 GBytes 941 Mbits/sec 85 sender [ 4] 0.00-60.00 sec 6.57 GBytes 941 Mbits/sec receiver iperf Done.
does this point to a possible hardware defect, or is this the expected performance? Thanks for the help
any more advice here?
Hi @Chris-Hinkey,
Thanks for the reminder. We just ordered some more equipment to dig in further and for more testing.
Please bear with us and sorry for the delays.
Thanks -
@Vinny Any updates?
@chinkey I ran a few tests yesterday. I used the speedtest-cli application with a USB dongle. In the first test I connected a USB 2.0 Ethernet dongle to my laptop and got around 90 Mbps. I then connected that dongle to the RB5 USB port and also got about 90 Mbps. I then tried a USB 3.0 Ethernet dongle. On the laptop I saw about 520 Mbps but was only able to achieve about 250 Mbps on RB5. So I think that's pretty similar to what you were seeing. It's unclear at this time why there is such a difference.
