@Eric-Katzfey
Now using the docker image.
Posts made by leonardo Andrade 0
RE: VOXL2 - HITL/VIO
Hi Eric, this is my first time doing any setup with HITL.
I'm using the standard voxl-px4-hitl-start file, on the host computer it apparently opens communication with the usb, I send the command to arm the drone and when I tried the first time, it still tookoff, without showing any stability, now it triggers the failsafe and doesn't even takeoff.
Do you have any suggestions as to how I could approach it better? As it's my first time, I'm a bit lost as to how to debug in this case.
ps: I'm not using GPS
voxl-px4-hitl-start
During the execution of voxl-px4-hitl
Failsafe triggered
@Eric-Katzfey said in VOXL2 - HITL/VIO:
qshell dsp_hitl status
I runned the command , but seems it's ok.What could I check? What do you suggest?@Eric-Katzfey
VOXL2 - HITL/VIO
Hey guys !
I want to run PX4-HITL using VIO, but I'm running into some problems.
I was able to create the communication with the FTDI cable, but using the docker image or using gazebo on my computer I had problems with the pre-flights checks.
I also had problems with QGC, which kept alerting me to an unknown mode-
The data presented was strange
The version of the sdk and packages are:
I used as reference :
https://docs.modalai.com/voxl2-PX4-hitl/I would like to know if there are any additional steps for the parameters with VIO and what would be the correct way to execute VOXL-PX4-HITL.
RE: ODOMETRY MESSAGE
@Eric-Katzfey thanks mate for your answer!
ODOMETRY MESSAGE
I'm missing the odometry message (ID 331) in QGC after updating the system to version 1.1.3.
I loaded the parameters (Indoor VIO Missing GPS) :
However, when I use the voxl-inspect-qvio service (and take measurements with markings on the ground, the coordinates are correct/within tolerance).
When I call the service:
voxl-inspect-mavlink mavlink_onboardThe odometry message is there, but when I call
voxl-inspect-mavlink mavlink_to_gcs
Which of course reflects what is appearing in QGC (there is no odometry message, only local_position_ned).
So we're not supposed to have the odometry message in these new versions? Mainly because the PX4 v1.14 firmware no longer supports the EKF2_AID_MASK parameters, among others.
I really want to answer this question, especially to find out if I can fly autonomously.
RE: UART communication using J19 - VOXL2 SENTINEL
Hi Alex,
When I tested was with the px4 running.
That apps you said is like this?
https://docs.px4.io/main/en/modules/hello_sky.htmlIβm still learning some parts of px4 itself .
Ideally, I thought to connect the esp to cpu where I could to read the data coming , such as to connect a arduino board in a computer. However to control the gimbal should be using mavlink .
Itβs like to learn to use the peripherals of my sentinel, because in the future I need also to connect UART lidar.
What do you recommend? Because the others UARTs ports that I have are full right now.
Best regards!
hi guys!
I have a very dumb question.
I'd like to develop a gimbal using uart communication. But since I'd already removed the GPS module, I thought I'd use these uart ports.
I tried connecting an ESP32 to J19 of the VOXL2 (PINOS: #2-TX, #3-RX, #6-GND) and checking communication using the qrb5165io-uart-test and qrb5165io-slpi-uart-test commands.
I also checked this link:
https://docs.modalai.com/voxl2-qups/
Could you please guide me?!
Thank you! -
LAND by RC SPEKTRUM DX6
Hi guys,
I would like to know if it is possible to assign an switch to my RC Spektrum DX6 to land the Sentinel drone.
Best Regards,
Leonardo Andrade.
VIO Algorithms
Good Morning guys,
I would like to know how could I test my own VIO algorithms on sentinel drone.
Best Regards!
List of commands to JParser - VOXL Portal
Hello everyone!
I'm trying to get information and spin engines, like a checklist for the drone's verification to maintenance from VOXL-PORTAL.
So, i was reading the js file called "JParser" and others html files, I would like to know where can find the request messages
var parser = new jParser(msg, { msg_type: { index: 'uint8', }, status_text_msg: { status_text: ['array', 'char', 127], }, fm_msg: { armed: 'uint8', num_sats: 'uint8', base_mode: 'uint8', custom_mode: 'uint32', batt_remaining: 'uint8', }});
As shown above the "fm_msg" and "status_text_msg" are the messages, but where can I find this list or how can I request it to controller?
thanks for all!
RE: Limits of VOXL-Portal
@Eric-Katzfey , I was trying to develop a test platform, to spin the motors and monitoring others variables. Is it not possible right now?
Hey guys,
I was looking for the voxl-portal and I started to think if is possible to send commands MAVLINK/PX4 or parts of the QGC duty be transferred to there.
Someone can leave me clear, please
Thanks
