I want to use the VOXL2+Doodle Labs Mini-OEM. According to your website it can "routinely transmit full HD video over 20+ km.".
Is it possible to pair it with the VOXL2 mini? Or use the Doodle Labs nano-OEM?
Hi!
What would get the highest theoretical range if combined with only the VOXL 2 or VOXL 2 mini?
Many of these are compatible with the VOXL 2 mini through dongle mode (What the hell is dongle mode? Does it add weight?). But wouldn't that add more weight than just using the VOXL 2 instead?
Hi @Vinny. I require a minimum operational range of 10km with video feedback. I've selected the MPU5 from Persistent Systems for this application. Since it is portable and can be carried on the body.
https://www.persistentsystems.com/mpu5-specs/
Pair it with a Microhard HP900. It may be possible to achieve 480p up to 80km away, but that's just an assumption.
@Eric-Katzfey What options do I have with the VOXL 2 mini? Without necessarily adding more componentry. I'm looking for a operational range of +10km with video feedback.
Does the VOXl 2 mini have any integrated radio/cellular? What operational range has Modalai achieved or know is a possibility with a certain base station?
What's the out-of-sight range for the VOXL 2 Mini? If you want video feedback through 5G with onboard antennas.
How can you get the most range without adding more componentry? The only accessory I could find was the "VOXL Cellular LTE" but that's only compatible with the VOXL 2.
VOXL ESC Mini 4-in-1 with Built-in Power Module
There's no info on how much you can output to the motors, and if it's possible to step up voltage.
With the M0134 at least it's listed as 4 channels with 10A continuous. But that can't be used to power two servos or a VOXL 2 mini...
