Voxl2 Mavros install problem:
Hi I want to use mavros on the sentinel drone, but when I follow this documentand tried:
apt install -f ros-melodic-mavros ros-melodic-mavros-extras ros-melodic-control-toolbox
I got this error:
Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: ros-melodic-mavros : Depends: libeigen3-dev but it is not going to be installed Depends: ros-melodic-eigen-conversions but it is not going to be installed Depends: ros-melodic-tf2-eigen but it is not going to be installed ros-melodic-mavros-extras : Depends: ros-melodic-tf2-eigen but it is not going to be installed E: Unable to correct problems, you have held broken packages.
I did got ros melodic running on the drone and I checked the voxl-configure-pkg-manage, and update afterward. But I'm still not able to get mavros installed.
voxl-configure-pkg-manager Which repository do you want to use? stable - recommended for most users staging - packages under testing for next sdk release sdk-X.Y - Specific SDK release dev - recommended for ModalAI development team only 1) dev 3) sdk-0.7 5) sdk-0.9 7) staging 2) sdk-0.6 4) sdk-0.8 6) sdk-1.0 #? 6 Using repo: sdk-1.0
Any recommendation?
