Dear all,
got the long waited TOF camera, but when i tried to connected it, the connecter camed out
what are my option???
Dear all,
last question :
I could not see the point cloud with stereo , but since I need it to indoor solution, I will use tof anyway.
I using the drone without any GPS module (don't need it)
but I could not to change from manual to mission nor off board.
when I change the gps to rc transmitter (first option) I was able to get move to mission
but only left stick worked (up down rotate) the second stick won't work (forward and rotation)
is there a way to move to mission without gps module?
@Chad-Sweet
sweet, placing an order.
it will give me the cloud point, right? want to be sure
so all I need is to buy the tof camera, and I will get the extension as in the picture?
@Alex-Gardner one sec before I buy the tof camera
I see there is an extension cable is it come along with the camera, or I need to purchase it separately ?
second thing, can you print the 3d model of the tof camera, and what will be the cost of that?
zeev
Dear all,
I wish to use the voxl board with any physical gps component.
it not allowing me to move to mission or off board.
my gps_1 and gps_2 are disabled.
what I need to change to get this option?
too much setting with ads shell.
I started to wrote entire web application, so I can change the values like every normal device have (such as routers)
too many parameters to work with in add shell.
ok,
understood, I ordered the tof camera, hoping for the best
saw the 3d, it's not what i looking for
i make it short.
i bought voxl flight deck v1 with hires,stereo,tracking
and for the cloud points i now understand i need tof,stereo,tracking.
i think if i asked for the setup with the tof, i could get all connected in specific plastic.
i willing to buy the tof camera, but i would like the plastic in front of the flight deck that will support the tof camera, rather then hires camera.
is there any step file to print the front side with tof?
Dear all,
i saw on the wifi antennas that they can operate in 2.4 and 5 ghz.
i tried to connect to 5ghz wifi with no success.
does the flight deck support 5ghz and if yes, how can activate it?
zeev
i manage to move gimbel, just send mavlink command to desired pwm
wrote an android soft for my client in android with java.
if I only know about voxl 2, or voxl cam.
you need to strength the pre sale
to duck a tape is not an option, is there any 3d model that I can print?
and where I will connect it on my voxl flight deck, which camera I will take out?
Dear Matt,
i done the process, i bought the voxl flight deck,
i am afraid that i missing a key issue, does i have a tof camera ??
and if not, how i can buy one and how it's difficult to attach it to the flight deck?
zeev
Dear all,
how can I get the web portal and cloud point as in your video?
straggling with that for few days
sweet,
i connecting to modalai voxl flight deck,
i receiving it today, just wanted to be sure that i connecting the correct battery.
already add support for java, rest (with java spring), python and js/node.js.
changed also the web server to react with easy access.
i will share with you my code (basicly a docker on same network)
