<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA["[ERROR] test sig failed to save" when installing system on RB5]]></title><description><![CDATA[<p dir="auto">I'm trying to re-install the system on a RB5.<br />
The system image I want to install is 1.0.5-M0052-9.1-perf-c, and the current system is 1.0.3-M0052-9.1-perf.</p>
<p dir="auto">I get the following error messages when running flash-full .sh(1.0.5-M0052-9.1-perf-c):<br />
[INFO] version: 0.0<br />
[INFO] adb installed<br />
[INFO] fastboot installed<br />
[INFO] qti-ubuntu-robotics-image-qrb5165-rb5-boot.img present<br />
[INFO] abl.elf present<br />
[INFO] qti-ubuntu-robotics-image-qrb5165-rb5-sysfs.ext4 present<br />
[INFO] Saving camera calibration files<br />
adb: error: remote object '/data/modalai' does not exist<br />
[INFO] Saving test sig<br />
/usr/lib/rfsa/adsp/: 9 files pulled. 6.1 MB/s (4505752 bytes in 0.710s)<br />
[ERROR] test sig failed to save</p>
<p dir="auto">It seems like the script is trying to backup some files, but the files aren't there.<br />
What should I do to install the system image 1.0.5 properly?</p>
]]></description><link>https://forum.modalai.com/topic/915/error-test-sig-failed-to-save-when-installing-system-on-rb5</link><generator>RSS for Node</generator><lastBuildDate>Fri, 09 Oct 2026 08:34:31 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/915.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 05 May 2022 17:10:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to "[ERROR] test sig failed to save" when installing system on RB5 on Thu, 05 May 2022 18:13:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/andyh" aria-label="Profile: andyh">@<bdi>andyh</bdi></a> Okay great, we do have your files in our database. I will send you your files via. an email to your account registered here in the next few minutes.</p>
<p dir="auto">Here are a list of the files I will send you:</p>
<ul>
<li><a href="http://testsig-0xbb02a75f.so" rel="nofollow ugc">testsig-0xbb02a75f.so</a></li>
<li>opencv_stereo_extrinsics.yml</li>
<li>opencv_stereo_intrinsics.yml</li>
<li>opencv_stereo_rear_extrinsics.yml</li>
<li>opencv_stereo_rear_intrinsics.yml</li>
<li>opencv_tracking_intrinsics.yml</li>
</ul>
<p dir="auto">The steps you will do to fix your issue are as follows:</p>
<ul>
<li>Download all of the above files</li>
<li>Create the <code>/data/modalai</code> directory on your RB5 with <code>adb shell mkdir -p /data/modalai</code></li>
<li>In your terminal, navigate to the directory where you saved the above files</li>
<li>Push the camera calibration files to your RB5 with <code>adb push *.yml /data/modalai/.</code></li>
<li>Push the testsig file to your RB5 with <code>adb push testsig*.so /usr/lib/rfsa/adsp/.</code></li>
</ul>
<p dir="auto">After doing this the flashing script should be happy.</p>
<p dir="auto">It seems as though those files were somehow lost, possibly due to a re-flash with an older version of our script (newer versions such as the one in <code>1.0.5-M0052-9.1-perf-c</code> save these files during the flashing process)</p>
]]></description><link>https://forum.modalai.com/post/4308</link><guid isPermaLink="true">https://forum.modalai.com/post/4308</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Thu, 05 May 2022 18:13:04 GMT</pubDate></item><item><title><![CDATA[Reply to "[ERROR] test sig failed to save" when installing system on RB5 on Thu, 05 May 2022 17:34:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tom" aria-label="Profile: tom">@<bdi>tom</bdi></a> it's M2100000CU4</p>
]]></description><link>https://forum.modalai.com/post/4306</link><guid isPermaLink="true">https://forum.modalai.com/post/4306</guid><dc:creator><![CDATA[andyh]]></dc:creator><pubDate>Thu, 05 May 2022 17:34:03 GMT</pubDate></item><item><title><![CDATA[Reply to "[ERROR] test sig failed to save" when installing system on RB5 on Thu, 05 May 2022 17:21:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/andyh" aria-label="Profile: andyh">@<bdi>andyh</bdi></a> What is the serial number of your RB5. It should be on a sticker with a barcode in the form M2100000***</p>
<p dir="auto">It seems as though your system is missing both the camera calibration files as well as the testsig which is required for PX4 to run properly.</p>
<p dir="auto">I can check to see if we have your RB5's files backed up in our system.</p>
]]></description><link>https://forum.modalai.com/post/4304</link><guid isPermaLink="true">https://forum.modalai.com/post/4304</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Thu, 05 May 2022 17:21:20 GMT</pubDate></item></channel></rss>
