<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ESC won&#x27;t calibrate]]></title><description><![CDATA[<p dir="auto">Setting up a flight core on a 550 quad that was previously successfully flown with a pixhawk cube.  Everything is working fairly well, except one of my four motors won't spin.  I have used the Python tool several times in an effort to recalibrate that last ESC which I know worked previously, but now it won't.  Can you offer any ideas on how to proceed?  Thanks, Jim.</p>
]]></description><link>https://forum.modalai.com/topic/778/esc-won-t-calibrate</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Apr 2026 15:45:38 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/778.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 02 Mar 2022 00:10:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ESC won&#x27;t calibrate on Wed, 02 Mar 2022 19:30:39 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for your suggestions.  I ran the pwm test command in the MavLink console and confirmed all motors except the suspect one so looks like I'm going to replace an ESC.  I do appreciate your guidance.</p>
]]></description><link>https://forum.modalai.com/post/3622</link><guid isPermaLink="true">https://forum.modalai.com/post/3622</guid><dc:creator><![CDATA[Jimk_Aero]]></dc:creator><pubDate>Wed, 02 Mar 2022 19:30:39 GMT</pubDate></item><item><title><![CDATA[Reply to ESC won&#x27;t calibrate on Wed, 02 Mar 2022 00:57:04 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/739">@Jimk_Aero</a> ,</p>
<p dir="auto">Have you confirmed that you can spin the motor 'manually'?</p>
<p dir="auto">If you are comfortable using the MAVLink shell from QGroundControl, you could try to use the <code>pwm</code> command at the command line to try to spin the motor manually.</p>
<p dir="auto"><a href="https://dev.px4.io/master/en/middleware/modules_command.html#pwm" rel="nofollow ugc">https://dev.px4.io/master/en/middleware/modules_command.html#pwm</a></p>
<p dir="auto">If that doesn't work than I'd start to look at the wiring next.</p>
]]></description><link>https://forum.modalai.com/post/3607</link><guid isPermaLink="true">https://forum.modalai.com/post/3607</guid><dc:creator><![CDATA[modaltb]]></dc:creator><pubDate>Wed, 02 Mar 2022 00:57:04 GMT</pubDate></item></channel></rss>
