<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Unable to calibrate compass on VOXL CAM w/ Flight Controller]]></title><description><![CDATA[<p dir="auto">Hi, I"m just finished to mount the voxl cam w/ fligth controller on my frame and did all the connections.</p>
<p dir="auto">It ask me to setup the frame which is a generic X, and ask now to calibrate the sensors. All is fine for the Gyro and accelerometer, but I tried several times to calibrate the compass and didn't work.  I let the rotation angle to NONE.</p>
<p dir="auto">Do I should setup a Rotation angle before to calibrate the compass?</p>
<p dir="auto">Thanks for your answer!</p>
]]></description><link>https://forum.modalai.com/topic/699/unable-to-calibrate-compass-on-voxl-cam-w-flight-controller</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 02:31:27 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/699.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 02 Feb 2022 13:01:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Unable to calibrate compass on VOXL CAM w/ Flight Controller on Fri, 04 Feb 2022 15:57:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chad-sweet" aria-label="Profile: Chad-Sweet">@<bdi>Chad-Sweet</bdi></a> Hi Chad, I go further and for the accelerometer calibration I have another issue.</p>
<ol>
<li>
<p dir="auto">With Rotation None, the QGC see my aircraft on left side instead of level position, and so on.<br />
When I test to arm and take off, it see the vehicle as turn on right side and have failsafe issue.</p>
</li>
<li>
<p dir="auto">If I put Rotation = Roll 270 is much better, and I can arm and takeoff (just simulate for now).<br />
Still, I have two positions that are not right, aka it show the vehicle on:</p>
</li>
</ol>
<ul>
<li>left side instead of noise up</li>
<li>right side instead of noise down</li>
</ul>
<p dir="auto">I would really appreciate your help to indicate me the right value for the Rotation to well calibrate this sensor.</p>
<p dir="auto">Thank you!</p>
]]></description><link>https://forum.modalai.com/post/3255</link><guid isPermaLink="true">https://forum.modalai.com/post/3255</guid><dc:creator><![CDATA[marian]]></dc:creator><pubDate>Fri, 04 Feb 2022 15:57:04 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to calibrate compass on VOXL CAM w/ Flight Controller on Thu, 03 Feb 2022 16:11:43 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for your answer. That's normal then, because I didn't attach a gps to the board. My intention is to use it on indoor.</p>
]]></description><link>https://forum.modalai.com/post/3247</link><guid isPermaLink="true">https://forum.modalai.com/post/3247</guid><dc:creator><![CDATA[marian]]></dc:creator><pubDate>Thu, 03 Feb 2022 16:11:43 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to calibrate compass on VOXL CAM w/ Flight Controller on Wed, 02 Feb 2022 17:16:49 GMT]]></title><description><![CDATA[<p dir="auto">There is no built-in magnetometer. Have you connected a supported GPS/Mag unit to J10? See details here: <a href="https://docs.modalai.com/flight-core-datasheets-connectors/#j10---external-gps--magnetometer-connector" rel="nofollow ugc">https://docs.modalai.com/flight-core-datasheets-connectors/#j10---external-gps--magnetometer-connector</a></p>
]]></description><link>https://forum.modalai.com/post/3232</link><guid isPermaLink="true">https://forum.modalai.com/post/3232</guid><dc:creator><![CDATA[Chad Sweet]]></dc:creator><pubDate>Wed, 02 Feb 2022 17:16:49 GMT</pubDate></item></channel></rss>
