<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[QGC GPS Speed Error]]></title><description><![CDATA[<p dir="auto">Hello!</p>
<p dir="auto">I have a Qualcomm Flight RB5 that I have been working on to try to get it flying. When I try to arm the drone, however, arming fails because it fails the preflight checks. I get the error of <code>Preflight Fail: GPS Horizontal Pos Error too high</code> or <code>GPS Speed Accuracy too low</code> from QGC. Does anyone have any suggestions for fixes for this?</p>
<p dir="auto">Other possibly relevant info:</p>
<ul>
<li>The MAV has never been flying before (because of these issues)</li>
<li>I have tried this in 4 different (albeit indoor) locations and keep getting the same 2 errors</li>
<li>Under sensor status in QGC AHRS, GPS, &amp; Pre-Arm Check all have errors (when in the Arm menu)</li>
<li>I have also tried removing &amp; reinserting &amp; playing with the GPS connection into the flight controller (and tried arming it without the GPS but this had the Magnetometer fail)</li>
</ul>
<p dir="auto">Thank you so much for the help, let me know if there is anything that may come to mind, or any information that I may need to add to help troubleshoot this.</p>
<p dir="auto">Thanks again,<br />
Frank</p>
]]></description><link>https://forum.modalai.com/topic/695/qgc-gps-speed-error</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 03:23:02 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/695.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 31 Jan 2022 17:34:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to QGC GPS Speed Error on Wed, 30 Mar 2022 04:20:59 GMT]]></title><description><![CDATA[<p dir="auto">I have not flown the RB5 and I am still new to using PX4, but on a similar platform I recommend checking parameters in QGC and look for <code>EKF2_Aid_Mask</code>. You can toggle to:<br />
<img src="/assets/uploads/files/1648613903566-5fcf07a0-841e-4751-a38a-affff3b935f5-image.png" alt="5fcf07a0-841e-4751-a38a-affff3b935f5-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Which should disable GPS inputs and allow you to fly indoors. Just remember to set it back to use GPS when you want to fly outdoors. As Modal mentions, take appropriate safety precautions whens flying indoors even with VIO enabled.</p>
]]></description><link>https://forum.modalai.com/post/3871</link><guid isPermaLink="true">https://forum.modalai.com/post/3871</guid><dc:creator><![CDATA[Steve Turner]]></dc:creator><pubDate>Wed, 30 Mar 2022 04:20:59 GMT</pubDate></item><item><title><![CDATA[Reply to QGC GPS Speed Error on Fri, 11 Mar 2022 21:58:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/frank-doyle" aria-label="Profile: Frank-Doyle">@<bdi>Frank-Doyle</bdi></a> said in <a href="/post/3229">QGC GPS Speed Error</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chad-sweet" aria-label="Profile: Chad-Sweet">@<bdi>Chad-Sweet</bdi></a>, thank you so much for the response.</p>
<p dir="auto">After trying the MAV outside, the error does not go away, and even when inside, the error pops up while QGC shows that there the MAV is being seen by 8-11 satellites. We, also, would like to fly inside so we can use motion capture to record ground-truth data to compare with the VIO data &amp; our state-estimation algorithms, so being able to fly inside is important. (We have been following every guideline and more to make sure everything is safe, though)</p>
<p dir="auto">Is there any way that we would be able to disable the GPS requirement/functionality before flight? Just removing the connector does not work since the MAV then gives an error about the magnetometer not reading correctly. Thank you so much again!</p>
</blockquote>
<p dir="auto">I'm also having this problem. Did you manage to resolve this?</p>
]]></description><link>https://forum.modalai.com/post/3731</link><guid isPermaLink="true">https://forum.modalai.com/post/3731</guid><dc:creator><![CDATA[Djalma Ribeiro]]></dc:creator><pubDate>Fri, 11 Mar 2022 21:58:59 GMT</pubDate></item><item><title><![CDATA[Reply to QGC GPS Speed Error on Wed, 02 Feb 2022 15:44:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chad-sweet" aria-label="Profile: Chad-Sweet">@<bdi>Chad-Sweet</bdi></a>, thank you so much for the response.</p>
]]></description><link>https://forum.modalai.com/post/3229</link><guid isPermaLink="true">https://forum.modalai.com/post/3229</guid><dc:creator><![CDATA[Frank Doyle]]></dc:creator><pubDate>Wed, 02 Feb 2022 15:44:53 GMT</pubDate></item><item><title><![CDATA[Reply to QGC GPS Speed Error on Mon, 31 Jan 2022 18:43:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/frank-doyle" aria-label="Profile: Frank-Doyle">@<bdi>Frank-Doyle</bdi></a> we added some instructions for just flying with VIO indoors <a href="https://docs.modalai.com/Qualcomm-Flight-RB5-user-guide-using-vio/" rel="nofollow ugc">here</a> which will hopefully help</p>
<p dir="auto">As always, please be careful! Flying indoors can be dangerous, we have safety tips <a href="https://modalai.com/safety" rel="nofollow ugc">here</a></p>
]]></description><link>https://forum.modalai.com/post/3210</link><guid isPermaLink="true">https://forum.modalai.com/post/3210</guid><dc:creator><![CDATA[Chad Sweet]]></dc:creator><pubDate>Mon, 31 Jan 2022 18:43:22 GMT</pubDate></item><item><title><![CDATA[Reply to QGC GPS Speed Error on Mon, 31 Jan 2022 17:49:12 GMT]]></title><description><![CDATA[<p dir="auto">Those errors are all related to not having GPS signal. Can you take it outside and see if this error goes away?</p>
]]></description><link>https://forum.modalai.com/post/3209</link><guid isPermaLink="true">https://forum.modalai.com/post/3209</guid><dc:creator><![CDATA[Chad Sweet]]></dc:creator><pubDate>Mon, 31 Jan 2022 17:49:12 GMT</pubDate></item></channel></rss>
