<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[m500 firmware update]]></title><description><![CDATA[<p dir="auto">Hi team,</p>
<p dir="auto">I am trying to update the firmware using the latest v1.11.3-0.2.3, but I got some questions. I am following the instruction by this link:<br />
<a href="https://docs.modalai.com/update-flight-core-firmware/" rel="nofollow ugc">https://docs.modalai.com/update-flight-core-firmware/</a></p>
<p dir="auto">I use MCBL-00010 with microUSB cable to connect the PC with QGC. After this, the instruction says "Power cycle the Flight Core or VOXL Flight (the bootloader runs and the green LED flashes quickly)", does the "power cycle" mean that I should use QGC to reboot the drone or anything else?</p>
<p dir="auto">I tried to reboot the drone, then get back to the firmware tab in QGC while USB is connecting, but it shows an error log:</p>
<pre><code class="language-PX4">Error: Open failed on port cu.usbmodem01: Permission error while locking the device
Upgrade cancelled
If upgrade failed, make sure to connect directly to a powered USB port on your computer, not through a USB hub. Also make sure you are only powered via USB not battery.
<p dir="auto">I am confused about this, and why it says only powered via USB not battery? I tried to turn off the battery, but nothing happened in QGC and showing disconnected.</p>
<p dir="auto">I am trying to fix the GPS no LED flash issue by updating firmware. So, please any advice on this issue?</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://forum.modalai.com/topic/663/m500-firmware-update</link><generator>RSS for Node</generator><lastBuildDate>Wed, 09 Sep 2026 13:39:06 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/663.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 17 Jan 2022 15:57:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to m500 firmware update on Tue, 18 Jan 2022 14:18:53 GMT]]></title><description><![CDATA[<p dir="auto">Hi @RichieRich , I fixed the issue as I disordered the instruction. Anyways, thanks so much <img src="https://forum.modalai.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=43a1be1fe87" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=";)" alt="😉" /></p>
]]></description><link>https://forum.modalai.com/post/3079</link><guid isPermaLink="true">https://forum.modalai.com/post/3079</guid><dc:creator><![CDATA[yu zhang]]></dc:creator><pubDate>Tue, 18 Jan 2022 14:18:53 GMT</pubDate></item><item><title><![CDATA[Reply to m500 firmware update on Tue, 18 Jan 2022 14:10:51 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/jeremy-schmidt" aria-label="Profile: Jeremy-Schmidt">@<bdi>Jeremy-Schmidt</bdi></a> , I got it, and I already completed the update. I disordered the instruction before. Now, it works well and GPS led works again. Thanks!</p>
]]></description><link>https://forum.modalai.com/post/3078</link><guid isPermaLink="true">https://forum.modalai.com/post/3078</guid><dc:creator><![CDATA[yu zhang]]></dc:creator><pubDate>Tue, 18 Jan 2022 14:10:51 GMT</pubDate></item><item><title><![CDATA[Reply to m500 firmware update on Mon, 17 Jan 2022 21:01:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yu-zhang" aria-label="Profile: yu-zhang">@<bdi>yu-zhang</bdi></a> said in <a href="/post/3053">m500 firmware update</a>:</p>
<blockquote>
<p dir="auto">Error: Open failed on port cu.usbmodem01: Permission error while locking the device<br />
Upgrade cancelled</p>
</blockquote>
<p dir="auto">It looks like you have an OS permission issue that's locking the device. Take at look at how you setup QGC and the USB device on your Mac.</p>
<p dir="auto">As for the firmware upgrade and power, on other PX4 controllers you need to only power the controller via USB. In our setup, there's only one power source and you cannot power via USB. Thus you use the main battery supply as documented in the link above to power cycle.</p>
]]></description><link>https://forum.modalai.com/post/3065</link><guid isPermaLink="true">https://forum.modalai.com/post/3065</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 17 Jan 2022 21:01:01 GMT</pubDate></item><item><title><![CDATA[Reply to m500 firmware update on Mon, 17 Jan 2022 20:35:09 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">Do you already have the new firmware downloaded? If so, power up the drone with usb connected.<br />
Connect to QGC and navigate to the firmware tab.</p>
<p dir="auto">At this point you want to power cycle the drone and when it comes back up in QGC you should see the window pop up which allows you to choose which firmware to select.</p>
<p dir="auto">I believe our videos will show you the rest of the process. Let me know if you run into problems.</p>
]]></description><link>https://forum.modalai.com/post/3063</link><guid isPermaLink="true">https://forum.modalai.com/post/3063</guid><dc:creator><![CDATA[Jeremy Schmidt]]></dc:creator><pubDate>Mon, 17 Jan 2022 20:35:09 GMT</pubDate></item></channel></rss>
