Calibrating compass on an m500 after swapping out a fried VOXL-Flight
  • I ordered a new VOXL-Flight after fatally over-powering the one on board an m500 drone I'm working with and am currently getting the new one integrated into the m500 in place of the fried one.
    I can't seem to calibrate the compass through QGC. I've gone through the process several times and although I'm told I've completed the process successfully by the prompts, every time I reboot, the Vehicle Set-Up status in QGC tells me that set-up is still required. I was able to calibrate the gyro and accelerometer. Could this be the result of a damaged Pixhawk4 GPS module? I haven't replaced that part yet, would that have been damaged by connecting the drone's power module to a 19V supply? The "GPS fix" light is blinking blue but the larger LED hasn't lit up since I hooked up the fresh VOXL-Flight.
