<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[VOXL 2 J3 Pin 56 Usage and External Switch Circuit]]></title><description><![CDATA[<p dir="auto"><strong>Hardware:</strong> (board / drone / SKU, serial # if you have it) VOXL 2 with a custom carrier board under development.</p>
<p dir="auto"><strong>Software version:</strong> (paste the output of <code>voxl-version</code>)</p>
<p dir="auto"><strong>Configuration / services:</strong> (paste the output of <code>voxl-inspect-services</code>)</p>
<p dir="auto"><strong>What I am trying to do:</strong><br />
We would like to implement external switches on our custom carrier board using the following VOXL 2 J3 signals:</p>
<ul>
<li>Pin 49 (PM_RESIN_N): Connect to GND through a normally open momentary switch and a 100Ω series resistor.</li>
<li>Pin 56 (SDM_FORCE_USB_BOOT): Connect to GND through an ON/OFF switch.</li>
</ul>
<p dir="auto"><strong>What actually happens:</strong> (error messages, behavior)<br />
We noticed that J3 pin 56 is marked with a No ERC “X” in the attached reference schematic. The schematic also states: “DO NOT USE SIGNAL PINS WITH NO_ERC ‘X’ MARKER ON THEM.”</p>
<p dir="auto">Before proceeding with the design, could you please clarify the following?</p>
<ol>
<li>Can J3 pin 56 be used on a custom carrier board to force VOXL 2 into USB boot / EDL mode, despite this marking? If not, what alternative method is recommended?</li>
<li>If pin 56 can be used, is connecting it to GND through an ON/OFF switch correct? Are any series or external pull-up/pull-down resistors required?</li>
<li>Is the proposed switch connection for pin 49 correct? Is the 100Ω series resistor required, optional, or unnecessary? Is an external pull-up resistor needed?</li>
</ol>
<p dir="auto"><strong>Steps to reproduce:</strong></p>
<p dir="auto"><strong>Logs / pictures:</strong> (attach files; PX4 logs -&gt; <a href="https://logs.px4.io" rel="nofollow ugc">https://logs.px4.io</a>)</p>
]]></description><link>https://forum.modalai.com/topic/5566/voxl-2-j3-pin-56-usage-and-external-switch-circuit</link><generator>RSS for Node</generator><lastBuildDate>Mon, 30 Nov 2026 06:51:52 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5566.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 30 Nov 2026 02:41:53 GMT</pubDate><ttl>60</ttl></channel></rss>
