<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[VOXL 2 on SDK 1.8: Spektrum satellite - input_rc never published]]></title><description><![CDATA[<h1>VOXL 2 on SDK 1.8: Spektrum satellite via the Sentinel Spektrum Bind Board, input_rc never published</h1>
<h2>Summary</h2>
<p dir="auto">On a VOXL 2 with SDK 1.8 (voxl-px4 1.18.0-1.0.9) and <code>RC=SPEKTRUM</code>, a bound Spektrum SPM9745 DSMX<br />
satellite connected through the Sentinel Spektrum Bind Board (J10 + J19) produces no RC input:<br />
<code>px4-listener input_rc</code> reports "never published". The <code>spektrum_rc</code> task starts without error, but<br />
unlike <code>crsf_rc</code> it never logs opening a UART. We read on the forum that Sentinel/SDK 1.5.0 was the<br />
last tested Spektrum setup and that later SDKs changed GPIO defaults. We would like to know whether<br />
Spektrum RC is still supported on SDK 1.8 and what is needed to make it work.</p>
<h2>Setup</h2>
<table class="table table-bordered table-striped">
<thead>
<tr>
<th>Item</th>
<th>Value</th>
</tr>
</thead>
<tbody>
<tr>
<td>Flight computer</td>
<td>VOXL 2 (QRB5165), board previously used in a Sentinel (Sentinel param files and logs on the device)</td>
</tr>
<tr>
<td>VOXL SDK</td>
<td>1.8.0</td>
</tr>
<tr>
<td>voxl-px4</td>
<td>1.18.0-1.0.9</td>
</tr>
<tr>
<td>voxl-px4-params</td>
<td>0.9.35</td>
</tr>
<tr>
<td>Transmitter</td>
<td>Spektrum DX6e</td>
</tr>
<tr>
<td>Receiver</td>
<td>Spektrum SPM9745 DSMX remote receiver (satellite)</td>
</tr>
<tr>
<td>Adapter</td>
<td>ModalAI Sentinel Spektrum Bind Board, connected to VOXL 2 J10 (pins 1 and 6) and J19 (pins 9, 11, 12)</td>
</tr>
<tr>
<td><code>/etc/modalai/voxl-px4.conf</code></td>
<td><code>AIRFRAME=MULTICOPTER</code>, <code>GPS=AUTODETECT</code>, <code>RC=SPEKTRUM</code>, <code>ESC=VOXL_ESC</code>, <code>POWER_MANAGER=VOXLPM</code>, <code>DAEMON_MODE=ENABLE</code>, <code>SENSOR_CAL=ACTUAL</code></td>
</tr>
</tbody>
</table>
<h2>What we see</h2>
<ol>
<li>The satellite is bound: its LED is solid with the DX6e on and dark with the DX6e off.</li>
<li><code>voxl-px4-start</code> runs <code>qshell spektrum_rc start</code> (no <code>-d</code> argument). The journal shows<br />
<code>Creating pthread spektrum_rc_main</code>, <code>Successfully created px4 task PX4_spektrum_rc_main</code> and<br />
<code>Ok executing command: spektrum_rc start</code>. No error follows.</li>
<li><code>px4-listener input_rc</code> reports <code>never published</code>, also after a full power cycle (battery removed).</li>
<li><code>px4-qshell spektrum_rc stop</code>, then <code>px4-qshell spektrum_rc start -d 7</code>: same result.</li>
<li>No <code>SerialImpl</code> "opened UART" line appears for <code>spektrum_rc</code>, neither at boot nor after the manual<br />
start. For comparison, with <code>RC=CRSF_RAW</code> on the same board every start logs<br />
<code>[SerialImpl] Successfully opened UART 7 with baudrate 420000</code>. The other serial devices also log<br />
their opens (ESC on UART 2 at 2000000, GPS autodetect on UART 6).</li>
<li><code>px4-qshell spektrum_rc status</code> and <code>px4-qshell spektrum_rc</code> (no arguments) return<br />
<code>cmd returned with: 1</code> / <code>Command failed</code>, so we cannot see the default device or the driver state.</li>
</ol>
<p dir="auto">Wiring continuity check (multimeter, receiver plug through the bind board to the VOXL 2):<br />
receiver pin 1 (data) to J19 pin 11, receiver pin 2 (GND) to J19 pin 12, receiver pin 3 (3.3 V) to<br />
J19 pin 9. J10 pins 1 and 6 also go into the bind board. The receiver is powered (its LED works), so<br />
power and ground are correct, and the remaining line, data, reaches J19 pin 11 (RC UART RX).</p>
<h2>Questions</h2>
<ol>
<li>Is Spektrum RC (<code>spektrum_rc</code> on the DSP) still supported on SDK 1.8 / voxl-px4 1.18?</li>
<li>Which UART does <code>spektrum_rc</code> use by default on VOXL 2, and does it log when it opens it? Is<br />
<code>-d 7</code> the right argument for J19?</li>
<li>Does the Sentinel Spektrum Bind Board need a GPIO set (power enable or routing) on newer SDKs, and<br />
if so, which GPIO and value?</li>
<li>Is there a supported way to bind from the VOXL 2 on SDK 1.8 (e.g. a bind command using the J10<br />
power line)?</li>
<li>If Spektrum is no longer supported, what is the recommended RC setup for a VOXL 2 with this<br />
transmitter?</li>
</ol>
<h2>What we can provide, if needed</h2>
<ul>
<li>Full <code>journalctl -u voxl-px4</code> output from boot.</li>
<li><code>px4-param show</code> output and the PX4 parameter file.</li>
<li>Photos of the bind board and its wiring to J10 and J19.</li>
</ul>
]]></description><link>https://forum.modalai.com/topic/5563/voxl-2-on-sdk-1.8-spektrum-satellite-input_rc-never-published</link><generator>RSS for Node</generator><lastBuildDate>Wed, 25 Nov 2026 19:13:05 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5563.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 25 Nov 2026 16:05:57 GMT</pubDate><ttl>60</ttl></channel></rss>
