<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Starling 2 Max – Using the AWUS036EACS in Japan (2.4 GHz only)]]></title><description><![CDATA[<p dir="auto"><strong>Hardware:</strong> Starling 2 Max, -M36 (Wi-Fi: Alfa AWUS036EACS)</p>
<p dir="auto"><strong>What I am trying to do:</strong><br />
We are planning an outdoor field demonstration of the Starling 2 Max in Japan. To use the included Wi-Fi adapter under Japan's 180-day exemption for radio equipment without Japanese certification, we need to operate it only in the 2.4 GHz band at 200 mW or less. (We have read the answers in <a href="https://forum.modalai.com/topic/5530.">https://forum.modalai.com/topic/5530.</a>)</p>
<p dir="auto">Could you help us with the following?</p>
<ol>
<li>
<p dir="auto"><strong>2.4 GHz-only operation:</strong> Can the adapter be set to use only 2.4 GHz and never transmit on 5 GHz, including at boot and after a reboot? If so, what settings should we use in SoftAP mode (hostapd.conf) and Station mode, and do they persist across reboots?</p>
</li>
<li>
<p dir="auto"><strong>Maximum transmit power:</strong> What is the maximum transmit power of the AWUS036EACS in the 2.4 GHz band? Can it be limited by software?</p>
</li>
<li>
<p dir="auto"><strong>Correct FCC ID:</strong> Could you tell us the correct FCC ID of the AWUS036EACS? The datasheet lists 2AB878811, but this ID appears to belong to the AWUS036ACS (RTL8811AU, no Bluetooth), and its frequency ranges match the AWUS036ACS entry on the VOXL 2 WiFi Setup page. Is the "Radio &amp; FCC Report" linked in the AWUS036EACS row of that page the correct document?</p>
</li>
<li>
<p dir="auto"><strong>Bluetooth:</strong> Is the adapter's Bluetooth function enabled on the Starling 2 Max? If not, can we confirm that it does not transmit?</p>
</li>
</ol>
<p dir="auto">Thank you for your help.</p>
<p dir="auto">Yuta Ohtani<br />
JDSC Inc.</p>
]]></description><link>https://forum.modalai.com/topic/5549/starling-2-max-using-the-awus036eacs-in-japan-2.4-ghz-only</link><generator>RSS for Node</generator><lastBuildDate>Tue, 17 Nov 2026 00:09:03 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5549.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 16 Nov 2026 01:59:26 GMT</pubDate><ttl>60</ttl></channel></rss>
