<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M0022 PWM Breakout Board: 8-Channel Output Pinout]]></title><description><![CDATA[<p dir="auto"><strong>Hardware:</strong> (board / drone / SKU, serial # if you have it): VOXL 2 IO (M0065) and M0022 PWM Breakout Board (Rev A, as shown in the diagram)</p>
<p dir="auto"><strong>Software version:</strong> (paste the output of <code>voxl-version</code>)</p>
<p dir="auto"><strong>Configuration / services:</strong> (paste the output of <code>voxl-inspect-services</code>)</p>
<p dir="auto"><strong>What I am trying to do:</strong><br />
: I’m reviewing the wiring diagram that shows the M0022 PWM Breakout Board connected to the 10-pin J1 connector on the M0065. The PWM output header on the M0022 appears to have eight columns of three pins each.</p>
<p dir="auto">Could you confirm whether each column corresponds to one PWM channel and contains a PWM signal pin, a power pin, and a ground pin? If so, could you confirm the pin order within each column and which column corresponds to each channel (PWM 1–8)?</p>
<p dir="auto">Are the power and ground pins shared across all eight columns? Is the power rail supplied through the M0065 J1 connector, or does it require an external supply?</p>
<p dir="auto"><img src="/assets/uploads/files/1794804394880-930d5b8e-402a-480f-b02d-9041945f4446-image.jpeg" alt="930d5b8e-402a-480f-b02d-9041945f4446-image.jpeg" class=" img-fluid img-markdown" /><br />
<strong>What actually happens:</strong> (error messages, behavior)</p>
<p dir="auto"><strong>Steps to reproduce:</strong></p>
<p dir="auto"><strong>Logs / pictures:</strong> (attach files; PX4 logs -&gt; <a href="https://logs.px4.io" rel="nofollow ugc">https://logs.px4.io</a>)</p>
]]></description><link>https://forum.modalai.com/topic/5548/m0022-pwm-breakout-board-8-channel-output-pinout</link><generator>RSS for Node</generator><lastBuildDate>Mon, 16 Nov 2026 12:37:02 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5548.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 16 Nov 2026 04:47:02 GMT</pubDate><ttl>60</ttl></channel></rss>
