<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Starling 2 Max V4/C29: current assembly STEP / CAD availability]]></title><description><![CDATA[<p dir="auto">Hi ModalAI team,</p>
<p dir="auto">I recently purchased the Starling 2 Max with C29 option a few days ago. While I await delivery I am investigating retrofitting propeller guards and additional payloads, and so I need some details about the airframe.</p>
<p dir="auto">Could you confirm which assembly STEP or mechanical drawings apply to the <strong>Starling 2 Max V4 frame with the C29 sensor configuration</strong>?</p>
<p dir="auto">I downloaded the complete <strong>CAD Models</strong> folder from FileCloud. It contains seven models, and the newest Starling 2 Max assembly is:</p>
<p dir="auto"><code>D0012-4-V3-C28-M36-T7-K0-Starling2-Max-V3-20260317.step</code></p>
<p dir="auto">The other two Max files are labelled Hardware Revision 2 and HW Rev1, with internal STEP export dates in September and June 2024 respectively. I could not find an assembly identified as V4/C29.</p>
<p dir="auto">Your <a href="https://www.modalai.com/products/starling-2-max-replacement-parts" rel="nofollow ugc">replacement-parts page</a> lists the V4 frame <strong>M10001459</strong>, motor <strong>M10001367</strong> and feet <strong>M10001460</strong>, and says the V3/V4 frames are not interchangeable.</p>
<p dir="auto">I also found this earlier report of the V3 CAD having smaller-motor legs than the delivered drone, with physical legs marked 1460 versus 868B in the CAD:<br />
<a href="https://forum.modalai.com/topic/5364/hardware-starling-2-max-landing-legs-cad-different-from-drone">https://forum.modalai.com/topic/5364/hardware-starling-2-max-landing-legs-cad-different-from-drone</a></p>
<p dir="auto">Could you please clarify:</p>
<ol>
<li>Is a current <strong>V4/C29 assembly STEP</strong> available, and where can it be downloaded?</li>
<li>If there is no complete model, can you provide drawings for the changed V4 frame/motor/feet interfaces and the <strong>fitted C29 ToF module and mounting plastics</strong>, including their assembly positions?</li>
<li>Which parts of the V3 model, particularly the <strong>top bracket and arm geometry</strong>, remain dimensionally valid for V4? Are there any approved payload attachment points or load limits for the top bracket?</li>
</ol>
<p dir="auto">The aim is to check a removable mount and propeller-bumper clearances without assuming that the older assembly matches the current hardware. A model including the installed battery envelopes and propeller sweep/height would be helpful too.</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://forum.modalai.com/topic/5529/starling-2-max-v4-c29-current-assembly-step-cad-availability</link><generator>RSS for Node</generator><lastBuildDate>Sun, 01 Nov 2026 10:31:28 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5529.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 30 Oct 2026 12:29:11 GMT</pubDate><ttl>60</ttl></channel></rss>
