<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Japan Radio Compliance and Battery Compatibility – Starling 2 C26/C27 and Starling 2 Max C29]]></title><description><![CDATA[<p dir="auto">Hello ModalAI Engineering Team,</p>
<p dir="auto">We are considering purchasing the Starling 2 (C26/C27) and Starling 2 Max (C29) for indoor inspection applications in factories and warehouses in Japan.</p>
<p dir="auto">We previously contacted ModalAI Sales and were directed to this technical forum for product-related technical questions.</p>
<p dir="auto">Before purchasing, we would appreciate clarification on the following points.</p>
<p dir="auto"><strong>1. Wireless communication and Japanese radio regulations</strong></p>
<ul>
<li>Could you identify the radio modules used for remote control, Wi-Fi, video transmission, and telemetry on the C26, C27, and C29, including their model numbers and whether they have Japanese MIC/Giteki certification?</li>
<li>If any modules are not certified for use in Japan, can they be replaced with Japan-certified alternatives?</li>
<li>If so, which specific modules are compatible, and what hardware modifications or software configuration changes would be required?</li>
<li>Can these replacements be performed by the customer?</li>
</ul>
<p dir="auto"><strong>2. Battery compatibility</strong></p>
<ul>
<li>Could you provide the required battery specifications for each model, including voltage, capacity, physical dimensions, connector type, and discharge-current requirements?</li>
<li>Do the supplied batteries fall under Japan's PSE requirements, and what is their compliance status, if applicable?</li>
<li>Are there any verified compatible replacement batteries available from suppliers in Japan?</li>
<li>Can the original batteries be shipped to Japan?</li>
</ul>
<p dir="auto"><strong>3. Battery chargers</strong></p>
<p dir="auto">ModalAI Sales informed us that battery chargers are not supplied.</p>
<ul>
<li>Which chargers would you recommend for safely charging these batteries using Japan's AC 100V, 50/60Hz power supply?</li>
<li>Are there any recommended charger models available from suppliers in Japan?</li>
<li>Are you aware of any recommended chargers with the applicable Japanese PSE compliance?</li>
</ul>
<p dir="auto">If specifications differ among the C26, C27, and C29 models, please provide model-specific information where possible.</p>
<p dir="auto">Thank you for your assistance.</p>
]]></description><link>https://forum.modalai.com/topic/5524/japan-radio-compliance-and-battery-compatibility-starling-2-c26-c27-and-starling-2-max-c29</link><generator>RSS for Node</generator><lastBuildDate>Tue, 27 Oct 2026 00:55:46 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5524.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 24 Oct 2026 10:27:51 GMT</pubDate><ttl>60</ttl></channel></rss>
