<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Starling 2 - Voxl 2]]></title><description><![CDATA[<p dir="auto">Hi ModalAI team,</p>
<p dir="auto">I’m troubleshooting an intermittent issue with a Starling 2 using a VOXL 2 and VOXL Mini 4-in-1 ESC.</p>
<p dir="auto">The main symptom is that the system will randomly cut out and I get disconnected from both SSH and ADB. At the same time, the blue LEDs on the ESC stop flashing.</p>
<p dir="auto">I also noticed that when the blue ESC LEDs stop, a green LED on another board in the VOXL stack turns on and stays on. When that green LED turns off again, the blue ESC LEDs return.</p>
<p dir="auto">A few other observations:</p>
<p dir="auto">The issue is intermittent. Sometimes the drone can stay powered normally for a while.<br />
We have successfully put the drone into hover, and it was able to stay on for a period of time without shutting down.<br />
The problem has occurred with multiple batteries, so it does not seem isolated to one battery.<br />
In the past, physically pressing or moving some of the cables/connectors sometimes caused the system to start working again.<br />
At one point the ESC would not power on for a while, but after disconnecting and reconnecting the battery, the ESC came back on.<br />
Because of this, I’m wondering if there may be an intermittent power connection, connector, cable, power-management, or ESC-related issue.</p>
<p dir="auto">I also confirmed that this is not just an ADB communication drop. After one of the disconnects I ran:</p>
<p dir="auto">adb devices</p>
<p dir="auto">and no device was listed.</p>
<p dir="auto">Shortly afterward I ran:</p>
<p dir="auto">adb shell uptime</p>
<p dir="auto">and received:</p>
<p dir="auto">17:18:36 up 0 min, 0 users, load average: 2.62, 0.57, 0.19</p>
<p dir="auto">and then:</p>
<p dir="auto">17:18:40 up 0 min, 0 users, load average: 2.81, 0.65, 0.21</p>
<p dir="auto">So it appears the VOXL is actually rebooting, rather than only losing the ADB connection.</p>
<p dir="auto">At this point, the pattern seems to be something like:</p>
<p dir="auto">ESC blue LEDs stop<br />
→ VOXL/ADB/SSH disconnect<br />
→ VOXL reboots<br />
→ ADB/SSH return<br />
→ ESC blue LEDs return</p>
<p dir="auto">Could you advise what you would recommend checking next?</p>
<p dir="auto">In particular, I’d like to know:</p>
<p dir="auto">Whether this behavior suggests an issue with the VOXL Mini ESC / power-management circuitry<br />
Which connectors or power rails I should check first<br />
What voltage I should expect at the VOXL power input for this Starling 2 configuration<br />
Whether there are any logs or diagnostic commands that could help identify the source of the reboot<br />
Whether the green LED behavior I described corresponds to a known power or fault state</p>
<p dir="auto">I can also provide close-up photos of the hardware, wiring, and LEDs if helpful.</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://forum.modalai.com/topic/5437/starling-2-voxl-2</link><generator>RSS for Node</generator><lastBuildDate>Sat, 26 Sep 2026 02:50:13 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5437.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 25 Sep 2026 18:17:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Starling 2 - Voxl 2 on Fri, 25 Sep 2026 18:18:06 GMT]]></title><description><![CDATA[<p dir="auto">Pressing down on the The M0141 also causes this reboot any thoughts I can show video if needed. <a class="plugin-mentions-group plugin-mentions-a" href="/groups/administrators" aria-label="Profile: administrators">@<bdi>administrators</bdi></a></p>
]]></description><link>https://forum.modalai.com/post/26799</link><guid isPermaLink="true">https://forum.modalai.com/post/26799</guid><dc:creator><![CDATA[Marcos Correa]]></dc:creator><pubDate>Fri, 25 Sep 2026 18:18:06 GMT</pubDate></item></channel></rss>
