<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Motor sputtering/odd noises when sending offboard waypoint in voxl-mapper]]></title><description><![CDATA[<p dir="auto"><strong>Hardware:</strong> (board / drone / SKU, serial # if you have it)<br />
MRB-D0012-4-V2-C29-T8-M11-X0<br />
<strong>Software version:</strong> (paste the output of <code>voxl-version</code>)<br />
1.6.3<br />
<strong>Configuration / services:</strong> (paste the output of <code>voxl-inspect-services</code>)</p>
<p dir="auto"><strong>What I am trying to do:</strong><br />
Attempting to fly to indoor waypoints using voxl-mapper<br />
<strong>What actually happens:</strong> (error messages, behavior)<br />
I only got it to work so far when changing the vision-hub config file to use trajectory for the offboard_mode field. However, I noticed that the motors seem to be sputtering/making weird noises as soon as I put the vehicle into offboard mode in PX4. Have you seen this before/are you familiar with what could be causing it? The drone is able to fly to the waypoint despite these odd motor noises.</p>
<p dir="auto">The drone flies normally and does not have this behavior in position mode.<br />
<strong>Steps to reproduce:</strong><br />
Enable trajectory mode in the voxl-mapper config file and attempt to send drone on a waypoint indoors in offboard mode.<br />
<strong>Logs / pictures:</strong> (attach files; PX4 logs -&gt; <a href="https://logs.px4.io" rel="nofollow ugc">https://logs.px4.io</a>)</p>
]]></description><link>https://forum.modalai.com/topic/5431/motor-sputtering-odd-noises-when-sending-offboard-waypoint-in-voxl-mapper</link><generator>RSS for Node</generator><lastBuildDate>Wed, 23 Sep 2026 05:54:56 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5431.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 23 Sep 2026 02:17:22 GMT</pubDate><ttl>60</ttl></channel></rss>
