<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[VOXL2 reboots randomly]]></title><description><![CDATA[<p dir="auto">Hello<br />
We have 3 VOXL2s. All three of them are on the same VOXL suite.<br />
One of the VOXLs has had a problem for a while now where it would have a high accelerometer bias that would keep coming back randomly. Back then, the VOXL was running an alpha or beta software version, and we thought that was the issue. However, we moved all VOXLs to the same SDK version, and the VOXL2 kept having issues. It still has the accelerometer bias issue, which shows up way more often than on any of our other VOXL2s.</p>
<p dir="auto">Recently, a new problem popped up: the VOXL2 would randomly start rebooting. At first, we thought it had just lost communication, but after digging further, we found it actually rebooted. It is hard to say if there is something in particular that causes it, as the rebooting sometimes happens shortly after the VOXL was turned on and sometimes once we actually start running packages. The CPU load looks normal to me under full load:<br />
Name   MHz   Temp   Util | Sep  1 2026 08:54:07|<br />
cpu0     1804   60.6   66.0 | Uptime:      0:17:45|<br />
cpu1     1804   60.2   64.3 |                     |<br />
cpu2     1804   59.0   62.4 |    Mem Use (MB)     |<br />
cpu3     1804   60.2   64.0 |     1526.3/7671     |<br />
cpu4     2419   67.2   66.7 |   Mem Allocation    |<br />
cpu5     2419   62.5   15.8 |      -0.1 MB/s      |<br />
cpu6     2419   62.9   10.1 |                     |<br />
cpu7     2841   72.9   71.3 | Governor: Perf      |<br />
Total                 63.2   52.6 | Pitmode: Not Active |<br />
10s avg                       53.5 | Auto Pitmode: OFF   |<br />
-------------------------|                     |<br />
GPU    587   51.7    0.8 |                     |<br />
GPU 10s avg          0.8 |                     |</p>
<p dir="auto">This happens with battery power supply as well as using the normal power supply cable.<br />
All three VOXLs have the same settings and software packages installed. The problem only happens on the one drone.<br />
I tried to look at the logs after a reboot, but nothing special showed up.<br />
The VOXL could have this issue constantly on one day, even when we power-cycle it over and over again, and then the next day, it is fine again.<br />
On days where it has the issues, we also noticed that it does not connect to the chrony server or only after minutes (usually happens within seconds) and saved data in rosbags do not make sense (e.g., with motion capture running at 200Hz, the drone thinks it jumped 30 meters in the air when moved less than a meter by hand, and heading is off by 90°...). On days when the VOXL works, all of these issues seem to magically disappear, and it works like the other drones. However, we have not had one of these "normal" days in a while. The issues seem to be getting worse. Fortunately, I have recently only been using the drones for software package tests and have not actually flown them. Reboots mid-flight would have been really bad.</p>
<p dir="auto">Unfortunately, the problem is urgent, as we have important flight tests coming up and the VOXL is currently unusable.</p>
<p dir="auto">Hardware: VOXL2<br />
SKU: MCCA-M0054-CC-T0-M0-X0<br />
voxl-suite: 1.6.5</p>
<p dir="auto">voxl-version<br />
────────────────────────────────────────────────────────────────────────────────<br />
system-image: 1.8.06-M0054-14.1a-perf<br />
kernel:       #1 SMP PREEMPT Wed Oct 22 04:13:18 UTC 2025 4.19.125<br />
hw platform:  M0054<br />
mach.var:     1.0.1<br />
voxl-suite:   1.6.5<br />
Packages:<br />
Repo:  <a href="http://voxl-packages.modalai.com/" rel="nofollow ugc">http://voxl-packages.modalai.com/</a> ./dists/qrb5165/sdk-1.6/binary-arm64/<br />
Last Updated: 2026-07-07 17:09:44<br />
List:<br />
libfc-sensor                   1.0.12<br />
libmodal-cv                    0.6.1<br />
libmodal-exposure              0.1.5<br />
libmodal-flow                  1.0.5<br />
libmodal-journal               0.2.7<br />
libmodal-json                  0.4.8<br />
libmodal-pipe                  2.14.12<br />
libqrb5165-io                  0.6.3<br />
libvoxl-cci-direct             0.4.0<br />
libvoxl-codec                  0.1.1<br />
libvoxl-cutils                 0.1.6<br />
modalai-slpi                   1.2.3<br />
mv-voxl                        0.1-r0<br />
qrb5165-bind                   0.1-r0<br />
qrb5165-dfs-server             0.2.0<br />
qrb5165-mini-tof-server        0.2.2<br />
qrb5165-rangefinder-server     0.1.6<br />
qrb5165-slpi-test-sig          01-r0<br />
qrb5165-tflite                 2.17.2<br />
voxl-bind-spektrum             0.1.1<br />
voxl-camera-calibration        0.6.2<br />
voxl-camera-server             2.2.28<br />
voxl-ceres-solver              2:2.0.0-3<br />
voxl-configurator              1.1.31<br />
voxl-cpu-monitor               0.7.7<br />
voxl-docker-support            1.3.1<br />
voxl-elrs                      1.1.7<br />
voxl-esc                       1.6.3<br />
voxl-esptool                   0.2.1<br />
voxl-feature-tracker           0.5.2<br />
voxl-flow-server               0.3.6<br />
voxl-focus-camera              0.6.2<br />
voxl-gphoto2-server            0.0.10<br />
voxl-imu-server                2.0.2<br />
voxl-io-server                 0.1.1<br />
voxl-jpeg-turbo                2.1.3-7<br />
voxl-lepton-server             1.4.1<br />
voxl-lepton-tracker            0.0.4<br />
voxl-libgeographic             1.0.0<br />
voxl-libgphoto2                0.0.4<br />
voxl-libuvc                    1.0.7<br />
voxl-logger                    0.6.3<br />
voxl-mavcam-manager            0.6.1<br />
voxl-mavlink                   0.1.6<br />
voxl-mavlink-server            1.4.16<br />
voxl-modem                     1.2.5<br />
voxl-mongoose                  7.19.0-1<br />
voxl-mpa-to-ros                0.3.9<br />
voxl-mpa-tools                 1.5.8<br />
voxl-nano-tracker              0.1.7<br />
voxl-open-vins-server          0.6.2<br />
voxl-opencv                    4.5.5-3<br />
voxl-osd                       0.4.11<br />
voxl-portal                    0.9.4<br />
voxl-px4                       1.14.0-2.0.142<br />
voxl-px4-params                0.9.15<br />
voxl-qvio-server               1.2.3<br />
voxl-remote-id                 0.0.9<br />
voxl-reset-slpi                0.0.4<br />
voxl-state-estimator           0.0.6<br />
voxl-streamer                  0.8.1<br />
voxl-tag-detector              0.1.0<br />
voxl-tflite-server             0.5.1<br />
voxl-utils                     2.0.5<br />
voxl-uvc-server                0.1.8<br />
voxl-vision-hub                1.9.21<br />
voxl-vtx                       2.2.38<br />
voxl-wavemux                   0.0.3<br />
voxl2-io                       0.0.3<br />
voxl2-security-hardening-utls  1.0-r0<br />
voxl2-system-image             1.8.06-r0<br />
voxl2-wlan                     1.0-r0</p>
<p dir="auto">voxl-inspect-services:<br />
Service Name             |  Enabled  |   Running   |  CPU Usage<br />
docker-autorun           | Disabled  | Not Running |<br />
modallink-relink         | Disabled  | Not Running |<br />
voxl-camera-server       |  Enabled  |   Running   |     0.0%<br />
voxl-cpu-monitor         |  Enabled  |   Running   |     0.0%<br />
voxl-dfs-server          | Disabled  | Not Running |<br />
voxl-dma-latency         |  Enabled  |   Running   |<br />
voxl-feature-tracker     | Disabled  | Not Running |<br />
voxl-flow-server         | Disabled  | Not Running |<br />
voxl-imu-server          |  Enabled  |   Running   |     2.0%<br />
voxl-io-server           | Disabled  | Not Running |<br />
voxl-lepton-server       | Disabled  | Not Running |<br />
voxl-lepton-tracker      | Disabled  | Not Running |<br />
voxl-logger              | Disabled  | Not Running |<br />
voxl-mavcam-manager      | Disabled  | Not Running |<br />
voxl-mavlink-server      |  Enabled  |   Running   |     2.0%<br />
voxl-mini-tof-server     | Disabled  | Not Running |<br />
voxl-modem-doodle        | Disabled  | Not Running |<br />
voxl-modem               | Disabled  | Not Running |<br />
voxl-nano-tracker        | Disabled  | Not Running |<br />
voxl-open-vins-server    | Disabled  | Not Running |<br />
voxl-osd                 | Disabled  | Not Running |<br />
voxl-portal              |  Enabled  |   Running   |     0.0%<br />
voxl-px4                 |  Enabled  |   Running   |    15.7%<br />
voxl-qvio-server         | Disabled  | Not Running |<br />
voxl-rangefinder-server  | Disabled  | Not Running |<br />
voxl-remote-id           | Disabled  | Not Running |<br />
voxl-softap              | Disabled  | Not Running |<br />
voxl-state-estimator     | Disabled  | Not Running |<br />
voxl-static-ip-watcher   | Disabled  | Not Running |<br />
voxl-static-ip           | Disabled  | Not Running |<br />
voxl-streamer            | Disabled  | Not Running |<br />
voxl-tag-detector        | Disabled  | Not Running |<br />
voxl-tflite-server       | Disabled  | Not Running |<br />
voxl-time-sync           | Disabled  | Not Running |<br />
voxl-uvc-server          | Disabled  | Not Running |<br />
voxl-vision-hub          |  Enabled  |   Running   |     0.0%<br />
voxl-vrx                 | Disabled  | Not Running |<br />
voxl-vtx                 | Disabled  | Not Running |<br />
voxl-wait-for-fs         |  Enabled  |  Completed  |</p>
]]></description><link>https://forum.modalai.com/topic/5402/voxl2-reboots-randomly</link><generator>RSS for Node</generator><lastBuildDate>Tue, 01 Sep 2026 23:11:03 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5402.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 01 Sep 2026 13:13:55 GMT</pubDate><ttl>60</ttl></channel></rss>
