<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Debugging steps for: &quot;Pre-arm Check Failure: Compass Sensor 0 Missing&quot;]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I've successfully flown my Starling 2 Max maybe 15 times now. Today I powered on the drone and received the status message:</p>
<p dir="auto">Pre-arm Check Failure: Compass Sensor 0 Missing</p>
<p dir="auto">I cannot fly the vehicle anymore. Can the engineering team provide some debugging steps to isolate what has failed or is going wrong?</p>
<p dir="auto">So far I swapped out the GPS unit with a second Starling 2 Max that I have, but the Pre-arm message remains and I cannot fly.</p>
<p dir="auto">Thank you!</p>
]]></description><link>https://forum.modalai.com/topic/5378/debugging-steps-for-pre-arm-check-failure-compass-sensor-0-missing</link><generator>RSS for Node</generator><lastBuildDate>Thu, 13 Aug 2026 18:07:51 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5378.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 13 Aug 2026 14:21:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Debugging steps for: &quot;Pre-arm Check Failure: Compass Sensor 0 Missing&quot; on Thu, 13 Aug 2026 15:42:53 GMT]]></title><description><![CDATA[<p dir="auto">Can you plug the cable from the working drone into the other one? That could tell you if it's the cable.</p>
]]></description><link>https://forum.modalai.com/post/26616</link><guid isPermaLink="true">https://forum.modalai.com/post/26616</guid><dc:creator><![CDATA[Eric Katzfey]]></dc:creator><pubDate>Thu, 13 Aug 2026 15:42:53 GMT</pubDate></item><item><title><![CDATA[Reply to Debugging steps for: &quot;Pre-arm Check Failure: Compass Sensor 0 Missing&quot; on Thu, 13 Aug 2026 15:26:21 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1786634750150-img_0502.jpg" alt="IMG_0502.JPG" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1786634753452-img_0503.jpg" alt="IMG_0503.JPG" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1786634763963-img_0504.jpg" alt="IMG_0504.JPG" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1786634767169-img_0505.jpg" alt="IMG_0505.JPG" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1786634770008-img_0506.jpg" alt="IMG_0506.JPG" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1786634773008-img_0507.jpg" alt="IMG_0507.JPG" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1786634775604-img_0508.jpg" alt="IMG_0508.JPG" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1786634778598-img_0509.jpg" alt="IMG_0509.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.modalai.com/post/26615</link><guid isPermaLink="true">https://forum.modalai.com/post/26615</guid><dc:creator><![CDATA[brandon]]></dc:creator><pubDate>Thu, 13 Aug 2026 15:26:21 GMT</pubDate></item><item><title><![CDATA[Reply to Debugging steps for: &quot;Pre-arm Check Failure: Compass Sensor 0 Missing&quot; on Thu, 13 Aug 2026 15:07:57 GMT]]></title><description><![CDATA[<p dir="auto">Debugging steps I have done so far:</p>
<ul>
<li>Swapped GPS unit with another Starling 2 Max</li>
<li>Inspected and re-seated connector on both sides (gps, and voxl side)</li>
<li>Ssh'd into drone and run debugging commands below.</li>
</ul>
<p dir="auto">My current hypotheses:</p>
<ul>
<li>The cable is broken between the gps and voxl board.</li>
<li>There is a hardware issue on the voxl board so it isn't sending commands over i2c</li>
</ul>
<p dir="auto">Do you have other ideas for things I can try or ideas for what could be wrong?</p>
<p dir="auto">voxl2:~$ px4-listener sensor_mag<br />
never published<br />
voxl2:~$ px4-listener sensor_gps</p>
<p dir="auto">TOPIC: sensor_gps<br />
sensor_gps<br />
timestamp: 678990321 (0.088196 seconds ago)<br />
timestamp_sample: 0<br />
time_utc_usec: 1786650062749778<br />
device_id: 11272245 (Type: 0xAC, SERIAL:6 (0x00))<br />
lat: 396691361<br />
lon: -1052411998<br />
alt: 2071371<br />
alt_ellipsoid: 2049863<br />
s_variance_m_s: 0.12200<br />
c_variance_rad: 0.75099<br />
eph: 0.46500<br />
epv: 0.56300<br />
hdop: 0.60000<br />
vdop: 0.86000<br />
noise_per_ms: 95<br />
jamming_indicator: 63<br />
vel_m_s: 0.02500<br />
vel_n_m_s: 0.00600<br />
vel_e_m_s: 0.02500<br />
vel_d_m_s: -0.01500<br />
cog_rad: 6.06156<br />
timestamp_time_relative: 0<br />
heading: nan<br />
heading_offset: 0.00000<br />
heading_accuracy: 0.00000<br />
rtcm_injection_rate: 0.00000<br />
automatic_gain_control: 0<br />
fix_type: 4<br />
jamming_state: 1<br />
spoofing_state: 1<br />
vel_ned_valid: True<br />
satellites_used: 24<br />
selected_rtcm_instance: 0</p>
<p dir="auto">voxl2:~$ cat /etc/modalai/voxl-px4.conf<br />
#!/bin/bash</p>
<h1></h1>
<h1>voxl-px4 Configuration File</h1>
<h1></h1>
<h1>AIRFRAME:</h1>
<h1>Tell PX4 which AIRFRAME to use.</h1>
<h1>Options include: [MULTICOPTER, FIXED_WING]</h1>
<h1></h1>
<h1>GPS:</h1>
<h1>Tell PX4 which GPS to use. If there is no GPS unit use NONE. Otherwise</h1>
<h1>choose AUTODETECT and the startup script will attempt to automatically</h1>
<h1>configure the GPS, magnetometer, and status LED</h1>
<h1>Options include: [NONE, AUTODETECT]</h1>
<h1></h1>
<h1>RC:</h1>
<h1>Tell PX4 which RC transmitter to use.</h1>
<h1>Use EXTERNAL when getting RC control from external Mavlink messages (e.g Via QGC)</h1>
<h1>Options include: [SPEKTRUM, CRSF_MAV, CRSF_RAW, M0065_SBUS, EXTERNAL, FAKE_RC_INPUT]</h1>
<h1></h1>
<h1>ESC:</h1>
<h1>Tell PX4 which type of ESC to use.</h1>
<h1>Options include: [VOXL_ESC, VOXL2_IO_PWM_ESC]</h1>
<h1></h1>
<h1>POWER_MANAGER:</h1>
<h1>Tell PX4 which power manager to use.</h1>
<h1>Use NONE for ModalAI Mini-ESC since the ESC driver handles PM.</h1>
<h1>Use EXTERNAL when not using the ModalAI APM power manager to power the board</h1>
<h1>This also just disables the voxlpm driver, same as the NONE option</h1>
<h1>Options include: [VOXLPM, EXTERNAL, NONE]</h1>
<h1></h1>
<h1>AIRSPEED_SENSOR:</h1>
<h1>Tell PX4 which airspeed sensor peripheral to use.</h1>
<h1>Note: The sensor will be started on external I2C port on voxl2</h1>
<h1>Options include: [NONE, MS4525DO]</h1>
<h1></h1>
<h1>DISTANCE_SENSOR:</h1>
<h1>Tell PX4 which distance sensor peripheral to use.</h1>
<h1>Note: The sensor will be started on the RC port so it is only</h1>
<h1>really possible to use it when using external RC.</h1>
<h1>Options include: [NONE, LIGHTWARE_SF000]</h1>
<h1></h1>
<h1>OSD:</h1>
<h1>Tell PX4 whether to enable OSD (on-screen display).</h1>
<h1>Options include: [ENABLE, DISABLE]</h1>
<h1></h1>
<h1>DAEMON_MODE:</h1>
<h1>Tell PX4 whether to enable daemon mode.</h1>
<h1></h1>
<h1>SENSOR_CAL:</h1>
<h1>Tell PX4 where to source sensor calibration information.</h1>
<h1>Options include: [ACTUAL, FAKE]</h1>
<h1></h1>
<h1>ARTIFACT_MODE:</h1>
<h1>Do not allow artifacts to be saved to disk. Will not start the logging</h1>
<h1>module, will delete any current log files, and will delete the data manager file.</h1>
<h1></h1>
<h1>EXTRA_STEPS:</h1>
<h1>Optional field that allows a user to define custom commands to be run by PX4 on boot.</h1>
<h1>Must be a valid bash array as seen below</h1>
<h1>Example: EXTRA_STEPS=( "qshell gps start" "qshell commander mode manual" )</h1>
<h1></h1>
<h1></h1>
<p dir="auto">AIRFRAME=MULTICOPTER<br />
GPS=AUTODETECT<br />
RC=GHST<br />
ESC=VOXL_ESC<br />
POWER_MANAGER=NONE<br />
AIRSPEED_SENSOR=NONE<br />
DISTANCE_SENSOR=NONE<br />
OSD=DISABLE<br />
DAEMON_MODE=ENABLE<br />
SENSOR_CAL=ACTUAL<br />
ARTIFACT_MODE=DISABLE<br />
EXTRA_STEPS=()</p>
<p dir="auto">voxl2:~$ voxl-version<br />
────────────────────────────────────────────────────────────────────────────────<br />
system-image: 1.8.06-M0054-14.1a-perf<br />
kernel:       #1 SMP PREEMPT Wed Oct 22 04:13:18 UTC 2025 4.19.125<br />
hw platform:  M0054<br />
mach.var:     1.0.1<br />
SKU:          MRB-D0012-4-V2-C29-T9-M28-X0<br />
voxl-suite:   1.6.3<br />
Packages:<br />
Repo:  <a href="http://voxl-packages.modalai.com/" rel="nofollow ugc">http://voxl-packages.modalai.com/</a> ./dists/qrb5165/sdk-1.6/binary-arm64/<br />
Last Updated: 2026-07-29 21:29:05<br />
WARNING: repo file has changed since last update,<br />
packages may have originated from a different repo<br />
List:<br />
libfc-sensor                   1.0.9<br />
libmodal-cv                    0.6.0<br />
libmodal-exposure              0.1.4<br />
libmodal-flow                  1.0.3<br />
libmodal-journal               0.2.7<br />
libmodal-json                  0.4.8<br />
libmodal-pipe                  2.14.11<br />
libqrb5165-io                  0.6.3<br />
libvoxl-cci-direct             0.3.3<br />
libvoxl-codec                  0.0.2<br />
libvoxl-cutils                 0.1.6<br />
modalai-slpi                   1.2.2<br />
mv-voxl                        0.1-r0<br />
qrb5165-bind                   0.1-r0<br />
qrb5165-dfs-server             0.2.0<br />
qrb5165-mini-tof-server        0.2.2<br />
qrb5165-rangefinder-server     0.1.6<br />
qrb5165-slpi-test-sig          01-r0<br />
qrb5165-tflite                 2.17.2<br />
voxl-bind-spektrum             0.1.1<br />
voxl-camera-calibration        0.6.1<br />
voxl-camera-server             2.2.19<br />
voxl-ceres-solver              2:2.0.0-2<br />
voxl-configurator              1.1.5<br />
voxl-cpu-monitor               0.7.7<br />
voxl-docker-support            1.3.1<br />
voxl-elrs                      1.1.0<br />
voxl-esc                       1.5.7<br />
voxl-esptool                   0.2.0<br />
voxl-feature-tracker           0.5.2<br />
voxl-flow-server               0.3.6<br />
voxl-gphoto2-server            0.0.10<br />
voxl-imu-server                2.0.1<br />
voxl-io-server                 0.0.8<br />
voxl-jpeg-turbo                2.1.3-7<br />
voxl-lepton-server             1.3.3<br />
voxl-lepton-tracker            0.0.4<br />
voxl-libgeographic             1.0.0<br />
voxl-libgphoto2                0.0.4<br />
voxl-libuvc                    1.0.7<br />
voxl-logger                    0.6.1<br />
voxl-mavcam-manager            0.6.0<br />
voxl-mavlink                   0.1.6<br />
voxl-mavlink-server            1.4.14<br />
voxl-modem                     1.2.3<br />
voxl-mongoose                  7.19.0<br />
voxl-mpa-to-ros                0.3.9<br />
voxl-mpa-tools                 1.5.6<br />
voxl-nano-tracker              0.1.7<br />
voxl-open-vins-server          0.6.0<br />
voxl-opencv                    4.5.5-3<br />
voxl-osd                       0.3.8<br />
voxl-portal                    0.8.7<br />
voxl-px4                       1.14.0-2.0.133<br />
voxl-px4-params                0.9.0<br />
voxl-qvio-server               1.2.3<br />
voxl-remote-id                 0.0.9<br />
voxl-reset-slpi                0.0.1<br />
voxl-state-estimator           0.0.6<br />
voxl-streamer                  0.8.0<br />
voxl-suite                     1.6.3<br />
voxl-tag-detector              0.1.0<br />
voxl-tflite-server             0.5.1<br />
voxl-utils                     2.0.2<br />
voxl-uvc-server                0.1.7<br />
voxl-vision-hub                1.9.21<br />
voxl-vtx                       2.0.2<br />
voxl-wavemux                   0.0.3<br />
voxl2-io                       0.0.3<br />
voxl2-security-hardening-utls  1.0-r0<br />
voxl2-system-image             1.8.06-r0<br />
voxl2-wlan                     1.0-r0<br />
voxl2:~$</p>
<p dir="auto">voxl2:~$ px4-qshell<br />
voxl2:~$</p>
<p dir="auto">voxl2:~$ ist8310 status<br />
-bash: ist8310: command not found</p>
<p dir="auto">voxl2:~$ px4-qshell ist8310 status<br />
INFO  [qshell] Send cmd: 'ist8310 status'<br />
INFO  [qshell] cmd returned with: -1<br />
INFO  [qshell] qshell return value timestamp: 766401772, local time: 766406205<br />
ERROR [qshell] Command failed<br />
voxl2:~$</p>
<p dir="auto">voxl2:~$ grep -i -n -E "mag|ist|qmc|gps" /usr/bin/voxl-px4-start<br />
8:echo "GPS: $GPS"<br />
13:echo "DISTANCE SENSOR: $DISTANCE_SENSOR"<br />
119:# Auto detect the magnetometer. If one or both of these devices<br />
122:/bin/echo "Looking for qmc5883l magnetometer"<br />
123:qshell qmc5883l start -R 10 -X -b 1<br />
124:/bin/echo "Looking for ist8310 magnetometer"<br />
125:qshell ist8310 start -R 10 -X -b 1<br />
126:/bin/echo "Looking for ist8308 magnetometer"<br />
128:qshell ist8308 start -R 12 -X -b 1<br />
129:/bin/echo "Looking for iis2mdc magnetometer"<br />
133:# GPS and magnetometer<br />
134:if [ "$GPS" != "NONE" ]; then<br />
136:	gps start -d /dev/ttyHS7<br />
138:	qshell gps start<br />
200:if [ "$DISTANCE_SENSOR" == "LIGHTWARE_SF000" ]; then<br />
214:# Optional distance sensor on spare i2c<br />
307:	# Also remove the data manager file that may have saved GPS waypoint information</p>
<p dir="auto">voxl2:~$ px4-qshell qmc5883l status<br />
INFO  [qshell] Send cmd: 'qmc5883l status'<br />
INFO  [qshell] qshell return value timestamp: 948521138, local time: 948523611<br />
ERROR [qshell] Command failed</p>
INFO  [qshell] qshell return value timestamp: 961731054, local time: 961733319<br />
voxl2:~$</p>
<p dir="auto">voxl2:~$ px4-qshell ist8310 start -R 10 -X -b 1<br />
INFO  [qshell] Send cmd: 'ist8310 start -R 10 -X -b 1'<br />
INFO  [qshell] qshell return value timestamp: 973342325, local time: 973345077<br />
INFO  [qshell] qshell return value timestamp: 989255823, local time: 989257867<br />
never published</p>
<p dir="auto">voxl2:~$ px4-qshell qmc5883l start -R 10 -X -b 1<br />
INFO  [qshell] Send cmd: 'qmc5883l start -R 10 -X -b 1'<br />
INFO  [qshell] qshell return value timestamp: 1009230646, local time: 1009233503<br />
voxl2:~$<br />
INFO  [qshell] qshell return value timestamp: 1009321642, local time: 1009323539<br />
voxl2:~$<br />
never published</p>
<p dir="auto">voxl2:~$ journalctl -u voxl-px4 -b | grep -i -E "mag|ist|qmc|i2c|gps"<br />
Aug 13 13:54:30 m0054 voxl-px4[2464]: GPS=AUTODETECT<br />
Aug 13 13:54:30 m0054 voxl-px4[2464]: DISTANCE SENSOR=NONE<br />
Aug 13 13:54:30 m0054 voxl-px4[2464]: GPS: AUTODETECT<br />
Aug 13 13:54:30 m0054 voxl-px4[2464]: DISTANCE SENSOR: NONE<br />
Aug 13 13:54:33 m0054 voxl-px4[2464]: WARN  [SPI_I2C] UnknownApp: no instance started (no device on bus?)<br />
Aug 13 13:54:33 m0054 voxl-px4[2464]: INFO  [muorb] [drivers__device] Register interrupt b214f094 e612f13c b2602648<br />
Aug 13 13:54:33 m0054 voxl-px4[2464]: INFO  [muorb] [drivers__device] *** I2C Device ID 0xb76329 12018473<br />
Aug 13 13:54:33 m0054 voxl-px4[2464]: INFO  [muorb] [drivers__device] Set up I2C bus mutex for bus 5<br />
Aug 13 13:54:33 m0054 voxl-px4[2464]: INFO  [muorb] icp101xx #0 on I2C bus 5<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: Looking for qmc5883l magnetometer<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: INFO  [qshell] Send cmd: 'qmc5883l start -R 10 -X -b 1'<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: Looking for ist8310 magnetometer<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: INFO  [qshell] Send cmd: 'ist8310 start -R 10 -X -b 1'<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: Looking for ist8308 magnetometer<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: INFO  [qshell] Send cmd: 'ist8308 start -R 12 -X -b 1'<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: Looking for iis2mdc magnetometer<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: INFO  [qshell] Send cmd: 'gps start'<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: INFO  [muorb] [qshell] qshell gotten: qmc5883l start -R 10 -X -b 1<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: INFO  [muorb] [qshell]   arg0 = 'qmc5883l'<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: INFO  [muorb] [drivers__device] *** I2C Device ID 0x80d09 527625<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: INFO  [muorb] [drivers__device] Set up I2C bus mutex for bus 1<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: ERROR [muorb] [drivers__device] i2c probe failed<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: INFO  [muorb] [SPI_I2C] PX4_qshell: no instance started (no device on bus?)<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: ERROR [muorb] [qshell] Failed to execute command: qmc5883l start -R 10 -X -b 1<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: INFO  [muorb] [qshell] qshell gotten: ist8310 start -R 10 -X -b 1<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: INFO  [muorb] [qshell]   arg0 = 'ist8310'<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: INFO  [muorb] [drivers__device] *** I2C Device ID 0x60e09 396809<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: ERROR [muorb] [qshell] Failed to execute command: ist8310 start -R 10 -X -b 1<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: INFO  [muorb] [qshell] qshell gotten: ist8308 start -R 12 -X -b 1<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: INFO  [muorb] [qshell]   arg0 = 'ist8308'<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: INFO  [muorb] [drivers__device] *** I2C Device ID 0xb0c09 723977<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: ERROR [muorb] [qshell] Failed to execute command: ist8308 start -R 12 -X -b 1<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: INFO  [muorb] [drivers__device] *** I2C Device ID 0xe1e09 925193<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: INFO  [muorb] [qshell] qshell gotten: gps start<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: INFO  [muorb] [qshell]   arg0 = 'gps'<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: INFO  [muorb] [tasks] Creating pthread gps<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: INFO  [muorb] [tasks] Successfully created px4 task PX4_gps with tid 2097644<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: INFO  [muorb] [qshell] Ok executing command: gps start<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: INFO  [muorb] [gps] GPS UART baudrate set to 115200<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: INFO  [muorb] [drivers__device] *** I2C Device ID 0x7b3809 8075273<br />
Aug 13 13:54:34 m0054 voxl-px4[2464]: INFO  [muorb] [drivers__device] Set i2c address 0x38, fd 5<br />
Aug 13 13:54:35 m0054 voxl-px4[2464]: INFO  [uORB] Advertising remote topic vehicle_gps_position<br />
Aug 13 13:54:35 m0054 voxl-px4[2464]: INFO  [uORB] Advertising remote topic vehicle_magnetometer<br />
Aug 13 13:54:35 m0054 voxl-px4[2464]: INFO  [uORB] Advertising remote topic sensor_preflight_mag<br />
Aug 13 13:54:36 m0054 voxl-px4[2464]: INFO  [muorb] [gps] u-blox firmware version: SPG 5.10<br />
Aug 13 13:54:36 m0054 voxl-px4[2464]: INFO  [muorb] [gps] u-blox protocol version: 34.10<br />
Aug 13 13:54:36 m0054 voxl-px4[2464]: INFO  [muorb] [gps] u-blox module: MAX-M10S<br />
Aug 13 13:54:36 m0054 voxl-px4[2464]: INFO  [muorb] [gps] GPS UART baudrate set to 115200<br />
Aug 13 13:55:06 m0054 voxl-px4[2464]: INFO  [muorb] [uORB] Advertising remote topic obstacle_distance<br />
Aug 13 13:55:06 m0054 voxl-px4[2464]: INFO  [muorb] [uORB] Advertising remote topic distance_sensor<br />
Aug 13 13:55:06 m0054 voxl-px4[2464]: INFO  [muorb] [gps] GPS UART baudrate set to 9600<br />
Aug 13 13:55:06 m0054 voxl-px4[2464]: INFO  [muorb] [gps] GPS UART baudrate set to 38400<br />
Aug 13 13:55:06 m0054 voxl-px4[2464]: INFO  [muorb] [gps] Got ack to initial CFG_VALSET!<br />
Aug 13 13:55:06 m0054 voxl-px4[2464]: INFO  [muorb] [gps] u-blox firmware version: SPG 5.10<br />
Aug 13 13:55:06 m0054 voxl-px4[2464]: INFO  [muorb] [gps] u-blox protocol version: 34.10<br />
Aug 13 13:55:06 m0054 voxl-px4[2464]: INFO  [muorb] [gps] u-blox module: MAX-M10S<br />
Aug 13 13:55:06 m0054 voxl-px4[2464]: INFO  [uORB] Advertising remote topic sensor_gps<br />
Aug 13 13:55:06 m0054 voxl-px4[2464]: INFO  [uORB] Advertising remote topic estimator_gps_status<br />
Aug 13 14:10:33 m0054 voxl-px4[2464]: INFO  [muorb] [qshell] qshell gotten: ist8310 status<br />
Aug 13 14:10:33 m0054 voxl-px4[2464]: INFO  [muorb] [qshell]   arg0 = 'ist8310'<br />
Aug 13 14:10:33 m0054 voxl-px4[2464]: INFO  [muorb] [SPI_I2C] Not running<br />
Aug 13 14:10:33 m0054 voxl-px4[2464]: ERROR [muorb] [qshell] Failed to execute command: ist8310 status<br />
Aug 13 14:10:33 m0054 voxl-px4[2464]: INFO  [muorb] [health_and_arming_checks] Preflight: GPS Horizontal Pos Drift too high<br />
Aug 13 14:10:33 m0054 voxl-px4[2464]: INFO  [muorb] [qshell] qshell gotten: qmc5883l status<br />
Aug 13 14:10:33 m0054 voxl-px4[2464]: INFO  [muorb] [qshell]   arg0 = 'qmc5883l'<br />
Aug 13 14:10:33 m0054 voxl-px4[2464]: ERROR [muorb] [qshell] Failed to execute command: qmc5883l status<br />
Aug 13 14:10:33 m0054 voxl-px4[2464]: INFO  [muorb] [qshell] qshell gotten: ist8310 start -R 10 -X -b 1<br />
Aug 13 14:10:33 m0054 voxl-px4[2464]: INFO  [muorb] [drivers__device] *** I2C Device ID 0x60e09 396809<br />
Aug 13 14:10:33 m0054 voxl-px4[2464]: INFO  [muorb] [drivers__device] Set up I2C bus mutex for bus 1<br />
Aug 13 14:10:33 m0054 voxl-px4[2464]: ERROR [muorb] [drivers__device] i2c probe failed<br />
Aug 13 14:10:33 m0054 voxl-px4[2464]: INFO  [muorb] [SPI_I2C] PX4_qshell: no instance started (no device on bus?)<br />
Aug 13 14:10:33 m0054 voxl-px4[2464]: ERROR [muorb] [qshell] Failed to execute command: ist8310 start -R 10 -X -b 1<br />
voxl2:~$</p>
]]></description><link>https://forum.modalai.com/post/26614</link><guid isPermaLink="true">https://forum.modalai.com/post/26614</guid><dc:creator><![CDATA[brandon]]></dc:creator><pubDate>Thu, 13 Aug 2026 15:07:57 GMT</pubDate></item></channel></rss>
