<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[voxl2  mini flashing]]></title><description><![CDATA[<p dir="auto">hi,<br />
just received the module, M0204-1-00 QRB5165M<br />
it appears to be blank (adb not identified), so i switched to fastboot, downloaded sdk 1.6.3.<br />
when running <a href="http://install.sh" rel="nofollow ugc">install.sh</a> i get the following error, where can get the system image for this board ?:</p>
<p dir="auto">[WARNING] This system image flash is intended only for the following<br />
platform: VOXL2 Mini (m0104)</p>
<pre><code>      Make sure that the device that will be flashed is correct.
      Flashing a device with an incorrect system image will lead
      the device to be stuck in fastboot.
<p dir="auto">Would you like to continue with the VOXL2 Mini (m0104) system image flash?</p>
<ol>
<li>Yes</li>
<li>No<br />
#? 1<br />
[INFO] checking if partition modalai_cal exists<br />
[INFO] Found modalai_cal partition<br />
[INFO] checking if partition modalai_conf exists<br />
[INFO] Found modalai_conf partition<br />
[ERROR] file is missing: {devcfg-m0054-1-v8.mbn}</li>
</ol>
]]></description><link>https://forum.modalai.com/topic/5348/voxl2-mini-flashing</link><generator>RSS for Node</generator><lastBuildDate>Mon, 27 Jul 2026 20:26:33 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5348.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 27 Jul 2026 12:39:03 GMT</pubDate><ttl>60</ttl></channel></rss>
