<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Questions about using VOXL2 Max &#x2F; Max2 legally in Japan]]></title><description><![CDATA[<p dir="auto">Hello ModalAI Team,</p>
<p dir="auto">We are evaluating the VOXL2 Max / Max2 platform for an indoor autonomous drone project in Japan.</p>
<p dir="auto">I searched the forum but could not find clear information regarding compliance with Japanese radio regulations.</p>
<p dir="auto">Could you please help clarify the following questions?</p>
<p dir="auto">Wi-Fi<br />
Is the Wi-Fi module used in VOXL2 Max / Max2 certified for use in Japan?<br />
If not, is there a recommended Wi-Fi module that is compliant with Japanese radio regulations?<br />
Country code<br />
Is setting the country code using iw reg set JP sufficient for legal operation in Japan, or is a different Wi-Fi module required?<br />
Remote Controller<br />
I found a forum post explaining that the Ghost receiver can be replaced with an ELRS receiver.<br />
Is there an officially recommended RC receiver configuration for customers in Japan?<br />
Ethernet operation<br />
Is it possible to configure and operate VOXL2 Max / Max2 entirely through Ethernet without using Wi-Fi after the initial setup?<br />
Customers in Japan<br />
Are there any customers currently using VOXL2 Max / Max2 in Japan?<br />
If so, are there any recommended hardware configurations for Japan?</p>
<p dir="auto">Our application is indoor autonomous flight using VIO/VSLAM, so GPS is not required.</p>
<p dir="auto">Any advice or recommendations would be greatly appreciated.</p>
<p dir="auto">Thank you very much.</p>
<p dir="auto">Best regards,</p>
]]></description><link>https://forum.modalai.com/topic/5324/questions-about-using-voxl2-max-max2-legally-in-japan</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 07:15:58 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5324.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 17 Jul 2026 01:26:14 GMT</pubDate><ttl>60</ttl></channel></rss>
