<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[IMU&#x2F;Gyro Calibration]]></title><description><![CDATA[<p dir="auto">I'm using a VOXL2 (m0054) running SDK 1.6.5 in a custom airframe, and I wanted to confirm somethings about the calibration process. In the past, I thought I was able to use voxl-calibrate-imu to calibrate the IMU and gyros in lieu of running the calibration through PX4. However, recently that doesn't seem to work anymore.</p>
<p dir="auto">Based on what I've been able to find on the forum, the IMU used by PX4 is separate from the IMU used by ModalAI apps and isn't calibrated by voxl-calibrate-imu. Can you confirm that in order to prepare a vehicle for flight, I'd need to calibrate the imu_apps IMU using voxl-calibrate-imu and then also calibrate the PX4 IMU through QGC (and ignore the pop-up about unreliable calibration over WiFi)?</p>
<p dir="auto">Also, for other VOXL IMU related commands like voxl-inspect-imu and voxl-calibrate-imu-temp, are these only for imu_apps (i.e. not for the PX4 imu), or is there a way to get these to show information from the PX4 IMU?</p>
]]></description><link>https://forum.modalai.com/topic/5317/imu-gyro-calibration</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Jul 2026 16:20:35 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5317.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 13 Jul 2026 16:29:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to IMU&#x2F;Gyro Calibration on Mon, 13 Jul 2026 17:53:09 GMT]]></title><description><![CDATA[<p dir="auto">Yes, your understanding is correct. To see the PX4 IMU values use standard PX4 commands. For example, on voxl2 you can use the PX4 listener commands:</p>
<pre><code>voxl2:/$ px4-listener sensor_accel
TOPIC: sensor_accel
 sensor_accel
    timestamp: 30123125 (0.006725 seconds ago)
    timestamp_sample: 30122829 (296 us before timestamp)
    device_id: 2490378 (Type: 0x26, SPI:1 (0x00))
    x: -0.05360
    y: 0.01754
    z: -9.68999
    temperature: 34.62560
    error_count: 0
    clip_counter: [0, 0, 0]
    samples: 20
voxl2:/$ px4-listener sensor_gyro
TOPIC: sensor_gyro
 sensor_gyro
    timestamp: 37716660 (0.003955 seconds ago)
    timestamp_sample: 37716405 (255 us before timestamp)
    x: -0.00409
    y: 0.00796
    z: -0.01429
    temperature: 34.32669
    error_count: 0
    samples: 20
]]></description><link>https://forum.modalai.com/post/26372</link><guid isPermaLink="true">https://forum.modalai.com/post/26372</guid><dc:creator><![CDATA[Eric Katzfey]]></dc:creator><pubDate>Mon, 13 Jul 2026 17:53:09 GMT</pubDate></item></channel></rss>
