<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Starling 2 Max payload with Livox MID-360 + gimbal-camera for indoor 3D]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I am considering the Starling 2 Max for indoor 3D reconstruction which will run on a PC, the drone is only for indoor data capture.</p>
<p dir="auto">Planned configuration:</p>
<p dir="auto">Drone: Starling 2 Max<br />
Radio: WiFi + ELRS<br />
Kit: Battery Pack + Controller<br />
Camera config: Dual 4K &amp; Dual Tracking &amp; ToF, C29<br />
Possible LiDAR: Livox MID-360<br />
Possible gimbal-camera: SIYI A8 mini or similar MAVLink-controlled gimbal-camera</p>
<p dir="auto">My questions:</p>
<p dir="auto">With the C29 configuration, what is the realistic remaining payload margin after battery and standard hardware?<br />
Can Starling 2 Max safely carry a Livox MID-360 + lightweight gimbal-camera + mounts/cables for slow indoor flight and stable hover?<br />
Do you recommend Livox MID-360 and SIYI A8 mini, or would you suggest a better LiDAR, camera, gimbal, expansion hub, or mounting setup?<br />
Should the built-in Starling cameras remain fixed for VIO/navigation, while a separate gimbal-camera is added for reconstruction capture?<br />
Can Starling 2 Max support programmable gimbal pitch control, including forward-facing to straight-down/nadir viewing?<br />
Can gimbal angle, camera frames, IMU, VIO/pose, and LiDAR data be logged with usable timestamps for offline processing?<br />
Are there recommended mounting locations or safety accessories, such as prop guards, that avoid blocking VIO cameras, LiDAR FOV, or the nadir camera view?<br />
Are there ModalAI-supported examples or ROS 2 workflows for LiDAR integration, gimbal control, synchronized logging, or autonomous indoor scan paths?</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.modalai.com/topic/5313/starling-2-max-payload-with-livox-mid-360-gimbal-camera-for-indoor-3d</link><generator>RSS for Node</generator><lastBuildDate>Thu, 09 Jul 2026 03:24:28 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5313.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 08 Jul 2026 17:35:33 GMT</pubDate><ttl>60</ttl></channel></rss>
