<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[VOXL 2 Mini: technical questions for a custom indoor inspection drone (SLAM, precision landing, cameras)]]></title><description><![CDATA[<p dir="auto">Hi ModalAI team,</p>
<p dir="auto">We were directed here from the sales channel. A few technical questions for our indoor GPS-denied inspection PoC — a compact custom quadcopter (X4) airframe built around the VOXL 2 Mini.</p>
<p dir="auto">[SLAM / autonomy]</p>
<ul>
<li>VOA performance in narrow (~300 mm) corridors — any pipe / industrial refs?</li>
<li>Open-VINS is pure VIO (no loop closure) — for repeated long flights, is Mapper + AprilTag re-localization enough to bound drift?</li>
</ul>
<p dir="auto">[Precision landing]</p>
<ul>
<li>voxl-vision-hub provides AprilTag relocalization but notes it "does not yet support autonomous takeoff and landing." Is a fully automated AprilTag precision landing onto a charging dock achievable using the VOXL SDK alone (voxl-tag-detector / voxl-vision-hub + PX4 precision-land), without us writing our own landing logic? If so, what is the recommended setup? If some part still needs custom development, which part?</li>
</ul>
<p dir="auto">[Cameras / sensors]</p>
<ul>
<li>VOXL 2 Mini has 4 MIPI-CSI. Using 2 for VIO + 1 downward for precision landing = 3. Can a 4th camera (gimbal / thermal) be added, and how?</li>
<li>For the downward precision-landing camera, is MSU-M0166 (AR0144 micro-coax) the right choice? Can that downward AR0144 be shared by both VIO and the voxl-tag-detector (AprilTag) at the same time?</li>
<li>Recommended ToF module for collision avoidance?</li>
</ul>
<p dir="auto">[Airframe / drivetrain]</p>
<ul>
<li>Is VOXL ESC Mini (M0129) compatible with our own motor selection (DShot/PWM) in a standard quadcopter (X4) configuration?</li>
<li>Any thermal / layout guidance for integrating VOXL 2 Mini + ESC Mini into a custom ducted-cage airframe?</li>
</ul>
<p dir="auto">[Mission / comms]</p>
<ul>
<li>Vision Hub: can an external host (our charging station) send trajectories and trigger auto takeoff / landing?</li>
<li>WiFi 2.4 GHz stability indoors — recommended radio module?</li>
</ul>
<p dir="auto">Note: We don't have hardware yet (pre-purchase), so voxl-version / voxl-inspect-services / PX4 logs are not available at this stage.</p>
<p dir="auto">Thanks!<br />
JinHyeok Kim, Pablo Air</p>
]]></description><link>https://forum.modalai.com/topic/5302/voxl-2-mini-technical-questions-for-a-custom-indoor-inspection-drone-slam-precision-landing-cameras</link><generator>RSS for Node</generator><lastBuildDate>Wed, 01 Jul 2026 20:52:16 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5302.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 01 Jul 2026 01:49:58 GMT</pubDate><ttl>60</ttl></channel></rss>
