<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[VOXL2 J19 external I2C not showing clock activity]]></title><description><![CDATA[<p dir="auto">Hello ModalAI Support,</p>
<p dir="auto">I am trying to use external I2C on a VOXL2 M0054 through J19.</p>
<p dir="auto">I checked the hardware side and found:</p>
<ul>
<li>J19 I2C lines sit high at about 3.3V when idle</li>
<li>continuity from J19 to my external board is good</li>
<li>ground connection is good</li>
</ul>
<p dir="auto">However, when I try to access the external I2C buses from the VOXL, I do not see any clock activity on the J19 I2C clock pins with an oscilloscope. The lines remain at steady 3.3V and no external device responds.<br />
From the documentation, my understanding is that:</p>
<ul>
<li>J19 pins 4/5 are the external magnetometer I2C path</li>
<li>J19 pins 7/8 are the spare external I2C path</li>
<li>the J19 I2C path goes through a TCA9517 level shifter/buffer</li>
</ul>
<p dir="auto">Could you please advise:</p>
<ul>
<li>Whether I should expect visible clock activity on these J19 pins when accessing the external I2C buses?</li>
<li>Whether any additional configuration is required to enable the J19 external I2C path on VOXL2 M0054?</li>
<li>Whether this symptom suggests a known issue with the J19 / external I2C buffer path?</li>
</ul>
<p dir="auto">I can provide more details if needed.<br />
Best regards<br />
Joel</p>
]]></description><link>https://forum.modalai.com/topic/5300/voxl2-j19-external-i2c-not-showing-clock-activity</link><generator>RSS for Node</generator><lastBuildDate>Tue, 30 Jun 2026 13:42:30 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5300.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 29 Jun 2026 16:01:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to VOXL2 J19 external I2C not showing clock activity on Tue, 30 Jun 2026 13:09:26 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/14">@Eric-Katzfey</a></p>
<p dir="auto">Yes, mainly via PX4 / qshell, and I also cross-checked once from Linux userspace.<br />
I tested both J19 I2C paths:</p>
<ul>
<li>pins 4/5</li>
<li>pins 7/8</li>
</ul>
<p dir="auto">With both methods I could not communicate with the devices on my custom PCB, and on the oscilloscope the SCL lines stayed flat at 3.3V with no clock activity.<br />
So it looks less like a device/address issue and more like the J19 I2C lines are not being driven out to the connector.</p>
<p dir="auto">Do J19 pins 4/5 and 7/8 require any additional enable/configuration on VOXL2 before they can be used for external sensors and whats the preferred way to access them?</p>
]]></description><link>https://forum.modalai.com/post/26279</link><guid isPermaLink="true">https://forum.modalai.com/post/26279</guid><dc:creator><![CDATA[saegsali]]></dc:creator><pubDate>Tue, 30 Jun 2026 13:09:26 GMT</pubDate></item><item><title><![CDATA[Reply to VOXL2 J19 external I2C not showing clock activity on Mon, 29 Jun 2026 19:01:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/3200">@saegsali</a> But how were you trying to access the I2C? What software? Via PX4?</p>
]]></description><link>https://forum.modalai.com/post/26274</link><guid isPermaLink="true">https://forum.modalai.com/post/26274</guid><dc:creator><![CDATA[Eric Katzfey]]></dc:creator><pubDate>Mon, 29 Jun 2026 19:01:55 GMT</pubDate></item><item><title><![CDATA[Reply to VOXL2 J19 external I2C not showing clock activity on Mon, 29 Jun 2026 17:59:33 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/14">@Eric-Katzfey</a></p>
<p dir="auto">We have a custom PCB which we use for different sensors e.g. to measure temperatures. The board is tested with an Arduino where it works with I2C.</p>
<p dir="auto">I now used the same PCB and connected it to the I2C lines on the J19 plug (4/5) and (7/8) but with neither of these I was able to establish communication to the I2C chips on the PCB. I then analyzed the SCL lines (pins 4 and <img src="https://forum.modalai.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f60e.png?v=r4gp3i66d9g" class="not-responsive emoji emoji-android emoji--sunglasses" title="8)" alt="😎" /> with an oscilloscope and realized that no signal is present there.</p>
<p dir="auto">Therefore I was wondering if any additional configuration is needed for using J19's I2C lines with external sensors?</p>
<p dir="auto">Thank you in advance!</p>
]]></description><link>https://forum.modalai.com/post/26273</link><guid isPermaLink="true">https://forum.modalai.com/post/26273</guid><dc:creator><![CDATA[saegsali]]></dc:creator><pubDate>Mon, 29 Jun 2026 17:59:33 GMT</pubDate></item><item><title><![CDATA[Reply to VOXL2 J19 external I2C not showing clock activity on Mon, 29 Jun 2026 16:09:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/3200">@saegsali</a> How are you trying to access the external i2c buses on J19?</p>
]]></description><link>https://forum.modalai.com/post/26272</link><guid isPermaLink="true">https://forum.modalai.com/post/26272</guid><dc:creator><![CDATA[Eric Katzfey]]></dc:creator><pubDate>Mon, 29 Jun 2026 16:09:40 GMT</pubDate></item></channel></rss>
