<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[VOXL 2 Mini Tof]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/7">@Alex-Kushleyev</a> and <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/14">@Eric-Katzfey</a>,</p>
<p dir="auto">I hope you are doing well.</p>
<p dir="auto">I recently came across the updates regarding the <strong>M0189 VOXL 2 Mini ToF sensor</strong>, and I am interested in evaluating it for integration into our UAV platform based on VOXL2 mini.</p>
<p dir="auto">We are currently planning to work on VOXL2 mini-based system and are exploring additional sensing solutions for obstacle detection, terrain following, and navigation-related applications. The Mini ToF sensor appears to be a promising option, and I would like to gather some additional information regarding its integration and availability.</p>
<p dir="auto">Could you please provide guidance on the following:</p>
<ol>
<li>
<p dir="auto"><strong>Integration Guidelines</strong></p>
<ul>
<li>Recommended hardware connections and interfacing requirements with VOXL2 mini.</li>
<li>Software and SDK support available for the sensor.</li>
<li>Any required drivers, services, or configuration steps within the VOXL SDK.</li>
<li>Best practices for mounting, calibration, and deployment on UAV platforms.</li>
<li>Available documentation, reference designs, or example projects demonstrating integration with VOXL2 mini.</li>
</ul>
</li>
<li>
<p dir="auto"><strong>Sensor Performance and Use Cases</strong></p>
<p dir="auto">*Typical operating range and field-of-view specifications.</p>
<ul>
<li>Expected performance in outdoor environments and varying lighting conditions.</li>
<li>Any known limitations or considerations for autonomous flight applications.</li>
<li>Whether the Mini ToF sensor provides 2D ranging data (single-point or multi-zone distance measurements) or a 3D depth map / point cloud output. If 3D depth information is available, could you please provide details regarding the depth resolution, output format, field of view, and any supported visualization or processing tools within the VOXL ecosystem?</li>
</ul>
</li>
<li>
<p dir="auto"><strong>Availability and Purchasing</strong></p>
<ul>
<li>Current availability status of the M0189 VOXL 2 Mini ToF sensor board.</li>
<li>Recommended purchasing channels and lead times.</li>
<li>Whether the sensor is available as a standalone module or requires additional interface hardware.</li>
</ul>
</li>
</ol>
<p dir="auto">We are currently evaluating sensors for integration into our UAV platform and would appreciate any documentation, recommendations, or resources that could help us better understand the capabilities and integration process of the Mini ToF sensor with VOXL2 mini.</p>
<p dir="auto">Thank you for your time and support.</p>
<p dir="auto">I look forward to your guidance.</p>
]]></description><link>https://forum.modalai.com/topic/5283/voxl-2-mini-tof</link><generator>RSS for Node</generator><lastBuildDate>Tue, 23 Jun 2026 13:14:02 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5283.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 22 Jun 2026 15:50:12 GMT</pubDate><ttl>60</ttl></channel></rss>
