<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M0041-4 Power Module for VOXL2 Mini Dead and Killed VOXL2 Mini]]></title><description><![CDATA[<p dir="auto">We are using the VOXL2 Mini with the M0041-4 power module on a 6S drone. I had been testing it on the bench with a 24V power supply without issue for the last few weeks. I was moving it onto the drone which is 6S and soldered power wires directly onto the ESC battery pads and added and XT30 to connect to the power module. When I plugged in the power module it sparked and I quickly unplugged. I have double checked polarity after the fact and it is correct. I put a multimeter on the xt30 and measured 25.1V. I do not see what I did wrong to make it fry. The IC that blew is the actual voltage regulator (marked 327;LGHW;8937 on the IC). Unfortunately I tried powering the VOXL2 mini up with another M0041-4 and my power supply and that is dead too. What am I doing wrong? Let me know if there is more information you need.</p>
]]></description><link>https://forum.modalai.com/topic/5278/m0041-4-power-module-for-voxl2-mini-dead-and-killed-voxl2-mini</link><generator>RSS for Node</generator><lastBuildDate>Sat, 20 Jun 2026 23:14:15 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5278.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 19 Jun 2026 19:51:26 GMT</pubDate><ttl>60</ttl></channel></rss>
