<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[&quot;set_position_target_local_ned: coordinate frame 0 unsupported&quot; error in QGroundControl]]></title><description><![CDATA[<p dir="auto">Hello -<br />
After upgrading SDK from 1.5.0 to 1.6.3, I am unable to calibrate the Starling 2 in QGroundControl  (Version 4.4.4)<br />
Error message: "set_position_target_local_ned: coordinate frame 0 unsupported"<br />
It seems the Starling 2 is sending a Mavlink message that is trying to set the coordinate frame to 0 (MAV_FRAME_GLOBAL), which cannot be processed by the local NED setpoint command.<br />
Any suggestions on how to correct this error would be appreciated.<br />
Thanks</p>
]]></description><link>https://forum.modalai.com/topic/5247/set_position_target_local_ned-coordinate-frame-0-unsupported-error-in-qgroundcontrol</link><generator>RSS for Node</generator><lastBuildDate>Fri, 05 Jun 2026 18:09:10 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5247.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 04 Jun 2026 22:08:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to &quot;set_position_target_local_ned: coordinate frame 0 unsupported&quot; error in QGroundControl on Fri, 05 Jun 2026 17:20:43 GMT]]></title><description><![CDATA[<p dir="auto">Hey <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/3114">@Hector-Gutierrez</a><br />
I tried recreating your issue, however I am able to calibrate the imu over QGC and then arm the drone too, while running voxl-vision-hub and voxl-open-vins-server<br />
May I know what changes you made to <code>voxl-vision-hub</code>? Could you share your <code>voxl-vision-hub.conf</code> file too?<br />
Am I correct to assume that you made your changes to the voxl-vision-hub <strong>dev</strong> branch then installed it on the starling 2?</p>
]]></description><link>https://forum.modalai.com/post/26039</link><guid isPermaLink="true">https://forum.modalai.com/post/26039</guid><dc:creator><![CDATA[ApoorvThapliyal]]></dc:creator><pubDate>Fri, 05 Jun 2026 17:20:43 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;set_position_target_local_ned: coordinate frame 0 unsupported&quot; error in QGroundControl on Fri, 05 Jun 2026 16:20:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/3114">@Hector-Gutierrez</a> Well, I'm happy that worked, but you shouldn't have to disable voxl-vision-hub like that. I only suggested that as a debug step. We'll take a look and see if we can reproduce the error and come up with a better solution.</p>
]]></description><link>https://forum.modalai.com/post/26038</link><guid isPermaLink="true">https://forum.modalai.com/post/26038</guid><dc:creator><![CDATA[Eric Katzfey]]></dc:creator><pubDate>Fri, 05 Jun 2026 16:20:47 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;set_position_target_local_ned: coordinate frame 0 unsupported&quot; error in QGroundControl on Fri, 05 Jun 2026 16:11:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/14">@Eric-Katzfey</a> : I'm not running any custom software other than voxl-vision-hub.<br />
If I stop and disable voxl-vision-hub, the  "set_position_target_local_ned: coordinate frame 0 unsupported" error goes away !<br />
With this I am able to complete calibration (compass and IMU) successfully in GQC, BUT drone fails to arm in Position mode <strong>even though QGC shows "Ready to Fly" and all Sensor status show as "normal".</strong><br />
Checking VIO in VOXL Portal shows correct operation of VIO:  VIO plot follows drone motion, which seems to indicate that VIO is working fine, but<br />
QGC shows "Yaw estimate error" , and "--"  as altitude estimate, which prevent the drone from arming in Position mode.<br />
Then I re-enable and restart voxl-vision-hub.<br />
Now GQC receives altitude estimates and I'm able to arm the drone in position mode !<br />
So the trick seems to be to disable/stop  voxl-vision-hub, calibrate IMU if needed, and enable/restart voxl-vision-hub, to be able to arm in Position mode.<br />
Seems odd but I'll take it !   Let me know if you have any comments or suggestions.  Thanks.</p>
]]></description><link>https://forum.modalai.com/post/26037</link><guid isPermaLink="true">https://forum.modalai.com/post/26037</guid><dc:creator><![CDATA[Hector Gutierrez]]></dc:creator><pubDate>Fri, 05 Jun 2026 16:11:59 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;set_position_target_local_ned: coordinate frame 0 unsupported&quot; error in QGroundControl on Fri, 05 Jun 2026 14:24:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/3114">@Hector-Gutierrez</a> What calibration step is not working? Are you running any custom software, like ROS or MAVSDK based applications? If you disable voxl-vision-hub does the error go away?</p>
]]></description><link>https://forum.modalai.com/post/26036</link><guid isPermaLink="true">https://forum.modalai.com/post/26036</guid><dc:creator><![CDATA[Eric Katzfey]]></dc:creator><pubDate>Fri, 05 Jun 2026 14:24:05 GMT</pubDate></item></channel></rss>
