<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Powering Starling 2 Max]]></title><description><![CDATA[<p dir="auto">I have a Starling 2 Max GPS-denied Development Drone. I have 4 batteries.  I plugged in two of them and the drone powered on.</p>
<p dir="auto">It also came with an AC Adapter and the instructions on how to plug into drone make sense.  The issue is that it also comes with a warning, "DO NOT ARM DRONE WHILE XT30 JUMPER OR POWER SUPPLY IS IN USE.  FAILURE TO DO SO WILL LIKELY RESULT IN DAMAGED HARDWARE. COULD RESULT IN FIRE"</p>
<p dir="auto">What do you mean by "Armed".  When I plug in the batteries the drone turns on.  I assume that means when I plug in the power supply it will also turn on.  Does that mean it is Armed?</p>
]]></description><link>https://forum.modalai.com/topic/5226/powering-starling-2-max</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 23:27:26 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5226.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 28 May 2026 20:40:32 GMT</pubDate><ttl>60</ttl></channel></rss>
