<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Remote ID Invalid - Is an updated script available?]]></title><description><![CDATA[<p dir="auto">The Serial Number generated via remote-id considered invalid when attempting to register with FAA. Currently using starling 2 max running 1.6.4~beta4.</p>
<p dir="auto">Referencing other messages, appears that the serial generated hard codes length character as C, which would require 12 digits. Since actual serial is 10 digits, it should be A.</p>
<p dir="auto">Has there been any updates to scripts to correct this?</p>
]]></description><link>https://forum.modalai.com/topic/5222/remote-id-invalid-is-an-updated-script-available</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 00:13:04 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5222.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 28 May 2026 02:19:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Remote ID Invalid - Is an updated script available? on Fri, 29 May 2026 20:40:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/3787">@JB1</a> Our voxl-remote-id software with WiFi dongle is intended only for reference and is not meant to be a commercially ready system for our customers who need a remote id solution for their VOXL2 based drone products. Integration, testing, validation, and FAA registration with desired hardware is up to the end user. At a minimum the manufacturer id would need to be changed from ModalAI's id to your companies issued manufacturer id.</p>
]]></description><link>https://forum.modalai.com/post/25957</link><guid isPermaLink="true">https://forum.modalai.com/post/25957</guid><dc:creator><![CDATA[Eric Katzfey]]></dc:creator><pubDate>Fri, 29 May 2026 20:40:32 GMT</pubDate></item><item><title><![CDATA[Reply to Remote ID Invalid - Is an updated script available? on Fri, 29 May 2026 19:37:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/3787">@JB1</a> I'll look into your questions. There is no RTC on VOXL2.</p>
]]></description><link>https://forum.modalai.com/post/25956</link><guid isPermaLink="true">https://forum.modalai.com/post/25956</guid><dc:creator><![CDATA[Eric Katzfey]]></dc:creator><pubDate>Fri, 29 May 2026 19:37:27 GMT</pubDate></item><item><title><![CDATA[Reply to Remote ID Invalid - Is an updated script available? on Fri, 29 May 2026 18:14:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/14">@Eric-Katzfey</a> appreciate the help. related questions.</p>
<p dir="auto">when starting up the voxl-remote-id service, noticing that hostapd was not connecting. identified that it was inactive, so started it, with no luck. for reference, using the m0213 botsunlimited sparrow.</p>
<p dir="auto">traced the following:</p>
<ul>
<li>In the hostapd.conf file, it operates at 5Ghz (hw_mode=a) and at channel 149. is this expected? Should remote-id operate at 2.4Ghz (hw_mode=g, channel=6)?</li>
<li>noticed there is nothing telling hostapd to create a socket directory, added ctrl_interface=/data/misc/wifi/hostapd</li>
</ul>
<p dir="auto">Added those changes, and now remote-id successfully connects to hostapd, mavlink-server, and can enter active mode</p>
<p dir="auto">However, that identified some other items during troubleshooting:</p>
<ul>
<li>when attempting to register drone with FAA - receive invalid serial number - is there specific format that you register drones with faa?</li>
<li>/persist partition on /dev/sda2 has a bad superblock or wrong filesystem type - it fails each time - without persist, RTC doesn't save and resets every reboot - is that expected behavior?</li>
<li>wifi does not reinitialize on soft reboot - requires a full power cycle</li>
</ul>
]]></description><link>https://forum.modalai.com/post/25954</link><guid isPermaLink="true">https://forum.modalai.com/post/25954</guid><dc:creator><![CDATA[JB1]]></dc:creator><pubDate>Fri, 29 May 2026 18:14:42 GMT</pubDate></item><item><title><![CDATA[Reply to Remote ID Invalid - Is an updated script available? on Thu, 28 May 2026 19:34:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/14">@Eric-Katzfey</a> thank you!</p>
]]></description><link>https://forum.modalai.com/post/25947</link><guid isPermaLink="true">https://forum.modalai.com/post/25947</guid><dc:creator><![CDATA[JB1]]></dc:creator><pubDate>Thu, 28 May 2026 19:34:38 GMT</pubDate></item><item><title><![CDATA[Reply to Remote ID Invalid - Is an updated script available? on Thu, 28 May 2026 17:29:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/3787">@JB1</a> FYI: The code repo is here: <a href="https://gitlab.com/voxl-public/voxl-sdk/services/voxl-remote-id" rel="nofollow ugc">https://gitlab.com/voxl-public/voxl-sdk/services/voxl-remote-id</a>. You can see my commits on the dev branch.</p>
]]></description><link>https://forum.modalai.com/post/25943</link><guid isPermaLink="true">https://forum.modalai.com/post/25943</guid><dc:creator><![CDATA[Eric Katzfey]]></dc:creator><pubDate>Thu, 28 May 2026 17:29:05 GMT</pubDate></item><item><title><![CDATA[Reply to Remote ID Invalid - Is an updated script available? on Thu, 28 May 2026 17:28:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/3787">@JB1</a> Yes, you are correct. It has been updated to use the 10 character ID. You can find the updated package here: <a href="http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-remote-id_0.1.0-202605281019_arm64.deb" rel="nofollow ugc">http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-remote-id_0.1.0-202605281019_arm64.deb</a></p>
]]></description><link>https://forum.modalai.com/post/25942</link><guid isPermaLink="true">https://forum.modalai.com/post/25942</guid><dc:creator><![CDATA[Eric Katzfey]]></dc:creator><pubDate>Thu, 28 May 2026 17:28:13 GMT</pubDate></item></channel></rss>
