<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Starling 2 Max indoor navigation workflow]]></title><description><![CDATA[<p dir="auto">Dear ModalAI Team,</p>
<p dir="auto">I would like to ask whether the ModalAI Starling 2 Max is suitable for the following workflow:</p>
<p dir="auto">Software: ArduCopter, Mission Planner<br />
Environment: Mostly empty large buildings with rooms and corridors.</p>
<p dir="auto">The drone takes off and lands at a predefined location (the same point)<br />
The drone fully autonomously executes a flight path planned in Mission Planner<br />
After battery replacement, it is able to fly the same mission again with approximately ±20 cm accuracy<br />
Questions:<br />
How much lighting is required inside the building for accurate navigation, or can it operate in complete darkness?<br />
Is ArduCopter’s Dijkstra-based path planning with predefined inclusion and exclusion zones supported?<br />
Is the drone capable of detecting obstacles in front of it and measuring distance? If so, can ArduCopter’s BendyRuler obstacle avoidance system be used?<br />
What level of navigation accuracy can be expected after 20–30 minutes of flight?</p>
<p dir="auto">Thank You</p>
]]></description><link>https://forum.modalai.com/topic/5206/starling-2-max-indoor-navigation-workflow</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 12:19:03 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5206.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 13 May 2026 11:07:43 GMT</pubDate><ttl>60</ttl></channel></rss>
