<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[High res camera latency]]></title><description><![CDATA[<p dir="auto">voxl-inspect-cam -a shows that the hires_down_large_color latency is &gt;900ms.  What is the cause of the latency and can it be reduced?</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.modalai.com/topic/5189/high-res-camera-latency</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 05:33:06 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5189.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 30 Apr 2026 20:17:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to High res camera latency on Wed, 06 May 2026 03:34:26 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/3766">@bschulzhf</a> ,</p>
<p dir="auto"><code>voxl-inspect-cam -a</code> command should not be generally used as it puts a lot of stress on the system. just use it to inspect the stream that you need, such as <code>voxl-inspect-cam hires_down_large_color</code>.</p>
<p dir="auto">Also, in your camera config changes, it is not clear exactly what changes you actually made, since you did not provide a diff (but i can see that you probably disabled all the streams except for the preview stream). In any case, you should revert your changes and just inspect the stream you need to estimate the latency.</p>
<p dir="auto">If you want to provide more information about your application, we can suggest appropriate camera server parameter changes. I do see that <code>ae_desired_msv": 60</code> is potentially too dark (the target average pixel value for auto exposure control) - you can try increasing it and see if the image is too dark.</p>
<p dir="auto">Alex</p>
]]></description><link>https://forum.modalai.com/post/25855</link><guid isPermaLink="true">https://forum.modalai.com/post/25855</guid><dc:creator><![CDATA[Alex Kushleyev]]></dc:creator><pubDate>Wed, 06 May 2026 03:34:26 GMT</pubDate></item><item><title><![CDATA[Reply to High res camera latency on Mon, 04 May 2026 15:09:00 GMT]]></title><description><![CDATA[<p dir="auto">As an update, I was able to get the latency down to about 50-60ms by making the following changes to /etc/modalai/voxl-camera-server.conf.  Are there any other optimizations I can make?</p>
<p dir="auto">{<br />
"type":	"imx412",<br />
"name":	"hires_down",<br />
"enabled":	true,<br />
"camera_id":	2,<br />
"fps":	10,<br />
"en_preview":	true,<br />
"preview_width":	4056,<br />
"preview_height":	3040,<br />
"en_raw_preview":	false,<br />
"en_small_video":	false,<br />
"small_video_width":	1024,<br />
"small_video_height":	768,<br />
"small_venc_mode":	"h264",<br />
"small_venc_br_ctrl":	"cqp",<br />
"small_venc_Qfixed":	30,<br />
"small_venc_Qmin":	15,<br />
"small_venc_Qmax":	40,<br />
"small_venc_nPframes":	9,<br />
"small_venc_mbps":	2,<br />
"small_venc_osd":	false,<br />
"en_large_video":	false,<br />
"large_video_width":	4056,<br />
"large_video_height":	3040,<br />
"large_venc_mode":	"h264",<br />
"large_venc_br_ctrl":	"cqp",<br />
"large_venc_Qfixed":	40,<br />
"large_venc_Qmin":	15,<br />
"large_venc_Qmax":	50,<br />
"large_venc_nPframes":	29,<br />
"large_venc_mbps":	40,<br />
"large_venc_osd":	false,<br />
"en_snapshot":	false,<br />
"en_snapshot_width":	4056,<br />
"en_snapshot_height":	3040,<br />
"exif_focal_length":	3.0999999046325684,<br />
"exif_focal_length_in_35mm_format":	17,<br />
"exif_fnumber":	1.2400000095367432,<br />
"snapshot_jpeg_quality":	75,<br />
"ae_mode":	"lme_msv",<br />
"gain_min":	54,<br />
"gain_max":	8000,<br />
"ae_desired_msv":	60,<br />
"exposure_min_us":	20,<br />
"exposure_max_us":	33000,<br />
"exposure_soft_min_us":	5000,<br />
"ae_filter_alpha":	0.600000023841858,<br />
"ae_ignore_fraction":	0.20000000298023224,<br />
"ae_slope":	0.05000000074505806,<br />
"ae_exposure_period":	1,<br />
"ae_gain_period":	1<br />
}</p>
]]></description><link>https://forum.modalai.com/post/25839</link><guid isPermaLink="true">https://forum.modalai.com/post/25839</guid><dc:creator><![CDATA[bschulzhf]]></dc:creator><pubDate>Mon, 04 May 2026 15:09:00 GMT</pubDate></item></channel></rss>
