<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Time Of Flight (TOF) camera output FPS divided by 5 after upgrading from SDK 1.5.0 to SDK 1.6.3 (Starling2 Max C29)]]></title><description><![CDATA[<p dir="auto">I would like to report a probable bug related to the TOF camera on my Starling 2 Max (configuration C29).<br />
I was previously running SDK 1.5.0, and the TOF camera was operating correctly at the frame rate specified in the file "/etc/modalai/voxl-camera-server.conf".<br />
I recently upgraded from SDK 1.5.0 to SDK 1.6.3 (I didn't try other SDK versions).<br />
Since then, the TOF camera runs at a frequency divided by 5. I tested this using the CLI inspection tool with the command "voxl-inspect-cam tof_depth" for different FPS values (same results in VOXL-Portal). I have not changed anything on the drone except the "fps" parameter in the configuration file "/etc/modalai/voxl-camera-server.conf".<br />
Here is my TOF camera configuration:</p>
<pre><code>"type": "pmd-tof-liow2",
"name": "tof",
"enabled":      true,
"camera_id":    3,
"fps":  10,
"en_rotate":    true,
"ae_mode":      "off",
"gain_min":     0,
"gain_max":     0,
"exposure_max_us":      6000,
"standby_enabled":      false,
"decimator":    5
<p dir="auto">Here are the results from "voxl-inspect-cam tof_depth" for different FPS values:</p>
<pre><code>fps = 5
| Pipe Name |  bytes  | wide |  hgt |exp(ms)| gain | frame id |latency(ms)|  fps |  mbps  | format
| tof_depth |   43200 |  180 |  240 | 48.00 |    0 |       26 |     28.1  |  1.0 |    0.3 | RAW8
fps = 10
| tof_depth |   43200 |  180 |  240 | 24.00 |    0 |       28 |     27.2  |  2.0 |    0.7 | RAW8
fps = 15
| tof_depth |   43200 |  180 |  240 | 16.00 |    0 |       16 |     28.6  |  3.0 |    1.0 | RAW8
fps = 20
| tof_depth |   43200 |  180 |  240 | 12.00 |    0 |       21 |     27.8  |  4.0 |    1.4 | RAW8
fpx = 30
| tof_depth |   43200 |  180 |  240 |  8.00 |    0 |       13 |     26.8  |  6.0 |    2.1 | RAW8
fps = 60
| tof_depth |   43200 |  180 |  240 |  4.00 |    0 |      288 |     10.0  | 12.0 |    4.1 | RAW8
fps = (8, 12, 25, 35, 40, 45, 50, 65, 70, 75, 80, 85, 90, 100, 120, 135, 140, 150, 180)
| tof_depth | Server Disconnected
<p dir="auto">Looking at the code in "src/hal3_camera_mgr.cpp", it seems expected that other frame rates do not work anymore. Here is the relevant section:</p>
<pre><code class="language-cpp">if (configInfo.type == SENSOR_TOF){
    if (configInfo.fps != 5 &amp;&amp; configInfo.fps != 10 &amp;&amp; configInfo.fps != 15 &amp;&amp; configInfo.fps != 30 &amp;&amp; configInfo.fps != 45){
        M_ERROR("Invalid TOF framerate: %d, must be either 5, 10, 15, 30, or 45\n", configInfo.fps);
        return -1;
if (configInfo.type == SENSOR_TOF_LIOW2){
    if (configInfo.fps != 5 &amp;&amp; configInfo.fps != 10 &amp;&amp; configInfo.fps != 15 &amp;&amp; configInfo.fps != 20 &amp;&amp; configInfo.fps != 30 &amp;&amp; configInfo.fps != 60){
        M_ERROR("Invalid TOF framerate: %d, must be either 5, 10, 15, 20, 30, or 60\n", configInfo.fps);
        return -1;
<p dir="auto">Below are the full version details for SDK 1.6.3 (where the issue occurs):</p>
<pre><code class="language-bash">voxl2:~$ voxl-version
system-image: 1.8.06-M0054-14.1a-perf
kernel:       #1 SMP PREEMPT Wed Oct 22 04:13:18 UTC 2025 4.19.125
hw platform:  M0054
mach.var:     1.0.1
SKU:          MRB-D0012-4-V2-C29-T9-M28-X0
voxl-suite:   1.6.3
Packages:
Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.6/binary-arm64/
Last Updated: 2026-03-09 17:52:53
List:
libfc-sensor                   1.0.9
libmodal-cv                    0.6.0
libmodal-exposure              0.1.4
libmodal-flow                  1.0.3
libmodal-journal               0.2.7
libmodal-json                  0.4.8
libmodal-pipe                  2.14.11
libqrb5165-io                  0.6.3
libvoxl-cci-direct             0.3.3
libvoxl-codec                  0.0.2
libvoxl-cutils                 0.1.6
modalai-slpi                   1.2.2
mv-voxl                        0.1-r0
qrb5165-bind                   0.1-r0
qrb5165-dfs-server             0.2.0
qrb5165-mini-tof-server        0.2.2
qrb5165-rangefinder-server     0.1.6
qrb5165-slpi-test-sig          01-r0
qrb5165-tflite                 2.17.2
voxl-bind-spektrum             0.1.1
voxl-camera-calibration        0.6.1
voxl-camera-server             2.2.19
voxl-cassie-ros2               0.0.1
voxl-ceres-solver              2:2.0.0-2
voxl-configurator              1.1.5
voxl-cpu-monitor               0.7.7
voxl-docker-support            1.3.1
voxl-elrs                      1.1.0
voxl-esc                       1.5.7
voxl-esptool                   0.2.0
voxl-feature-tracker           0.5.2
voxl-flow-server               0.3.6
voxl-gphoto2-server            0.0.10
voxl-imu-server                2.0.1
voxl-io-server                 0.0.8
voxl-jpeg-turbo                2.1.3-7
voxl-lepton-server             1.3.3
voxl-lepton-tracker            0.0.4
voxl-libgeographic             1.0.0
voxl-libgphoto2                0.0.4
voxl-libuvc                    1.0.7
voxl-logger                    0.6.1
voxl-mavcam-manager            0.6.0
voxl-mavlink                   0.1.6
voxl-mavlink-server            1.4.14
voxl-microdds-agent            3.0.0-0
voxl-modem                     1.2.3
voxl-mongoose                  7.19.0
voxl-mpa-to-ros                0.3.9
voxl-mpa-to-ros2               0.0.7
voxl-mpa-tools                 1.5.6
voxl-nano-tracker              0.1.7
voxl-open-vins-server          0.6.0
voxl-opencv                    4.5.5-3
voxl-osd                       0.3.8
voxl-portal                    0.8.7
voxl-px4                       1.14.0-2.0.133
voxl-px4-params                0.9.0
voxl-qvio-server               1.2.3
voxl-remote-id                 0.0.9
voxl-reset-slpi                0.0.1
voxl-ros2-foxy                 0.0.1
voxl-state-estimator           0.0.6
voxl-streamer                  0.8.0
voxl-suite                     1.6.3
voxl-tag-detector              0.1.0
voxl-tflite-server             0.5.1
voxl-utils                     2.0.2
voxl-uvc-server                0.1.7
voxl-vision-hub                1.9.21
voxl-vtx                       2.0.2
voxl-wavemux                   0.0.3
voxl2-io                       0.0.3
voxl2-security-hardening-utls  1.0-r0
voxl2-system-image             1.8.06-r0
voxl2-wlan                     1.0-r0
<p dir="auto">Below are the full version details for SDK 1.5.0 (where the TOF camera worked as expected):</p>
<pre><code class="language-bash">────────────────────────────────────────────────────────────────────────────────
system-image: 1.8.04-M0054-14.1a-perf
kernel:       #1 SMP PREEMPT Mon Mar 24 22:31:58 UTC 2025 4.19.125
hw platform:  M0054
mach.var:     1.0.1
voxl-suite:   1.5.0
Packages:
Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.5/binary-arm64/
Last Updated: 2026-02-05 12:12:50
List:
libfc-sensor                1.0.7
libmodal-cv                 0.5.18
libmodal-journal            0.2.6
libmodal-json               0.4.7
libmodal-pipe               2.13.2
libqrb5165-io               0.5.0
libvoxl-cutils              0.1.5
modalai-slpi                1.2.0
mv-voxl                     0.1-r0
qrb5165-bind                0.1-r0
qrb5165-imu-server          1.1.3
qrb5165-rangefinder-server  0.1.5
qrb5165-system-tweaks       0.3.6
qrb5165-tflite              2.8.0-2
voxl-camera-calibration     0.6.0
voxl-camera-server          2.2.4
voxl-ceres-solver           2:1.14.0-10
voxl-configurator           1.0.2
voxl-cpu-monitor            0.6.0
voxl-cross-template         0.0.1
voxl-elrs                   0.4.7
voxl-esc                    1.5.4
voxl-joystick-server        0.0.6
voxl-logger                 0.5.3
voxl-mavlink                0.1.5
voxl-mavlink-server         1.4.9
voxl-modem                  1.1.8
voxl-mongoose               7.7.0-2
voxl-mpa-tools              1.4.0
voxl-open-vins              0.4.19
voxl-open-vins-server       0.3.12
voxl-opencv                 4.5.5-3
voxl-osd                    0.1.8
voxl-portal                 0.7.11
voxl-px4                    1.14.0-2.0.105
voxl-px4-params             0.7.5
voxl-qvio-server            1.2.0
voxl-ros2-humble            0.0.3
voxl-state-estimator        0.0.5
voxl-streamer               0.7.5
voxl-suite                  1.5.0
voxl-tag-detector           0.0.5
voxl-tflite-server          0.4.1
voxl-utils                  1.4.8
voxl-vision-hub             1.8.23
voxl-vtx                    1.4.7
voxl-wavemux                0.0.1
voxl2-io                    0.0.3
voxl2-system-image          1.8.04-r0
voxl2-wlan                  1.0-r0
<p dir="auto">Between versions 2.2.4 and 2.2.19 of the "voxl-camera-server" repository, I extracted the commits that modified the file "src/hal3_camera_mgr.cpp":</p>
<pre><code>a7f5ea0 | 2025-12-10 | Eric Katzfey | Fixed the rest of the compiler warnings for the qrb5165-2 build
aa7b12d | 2025-12-05 | Alex Kushleyev | fix boson buffer pre-allocation size - the extra allocation should only be done in raw preview mode
f461dc0 | 2025-11-11 | Tom Martinson | Merge branch 'ar0144-rotate-encoded' into dev
3189b6b | 2025-11-10 | Alex Kushleyev | add option to invert boson output via a command
a3ac28e | 2025-11-10 | Tom Martinson | add new ar0144 rotated sensor type
bfce3c3 | 2025-11-10 | Alex Kushleyev | move some misp init code from camera mgr to misp
25fe9b6 | 2025-11-10 | Alex Kushleyev | load body to imu extrinsics from file
5289342 | 2025-11-07 | Alex Kushleyev | remove hist ae option; add manual and auto=lme_msv
a279e3d | 2025-11-06 | Jacob Camarillo | Remove unused OSD code
51cceec | 2025-11-06 | Alex Kushleyev | fix the neutral point of UV in monochrome YUVs from 127 to 128 for mono images sent to encoder
d1a9da8 | 2025-10-30 | Alex Kushleyev | Add an option to rotate AR0144 encoded video
86e1476 | 2025-10-29 | Alex Kushleyev | enable buffer recycling and camera customer register reinit for recovery
2b9816f | 2025-10-29 | Alex Kushleyev | Add boson 14bit support
cda94c2 | 2025-10-09 | zauberflote | Enable misp in stereo config
eeda888 | 2025-09-25 | Alex Kushleyev | enable rotation of imx412 and imx664 via en_rotate config option. using cci direct to set the readout direction
52643e8 | 2025-09-17 | Alex Kushleyev | fix bayer publish stride; enable publishing bayer images via shared ion buffers
2a2c14d | 2025-09-17 | Alex Kushleyev | Merge branch 'dev' into fix-encoder-dynamic-low-bitrate
dd7565a | 2025-09-16 | james | v2.2.7 remove voxl-cpu-monitor as build dependency and some general cleanups
a435e8c | 2025-09-08 | Alex Kushleyev | enable low fps to be set dynamically without having it set in the camera config (less than 1.5mbps for h264 and less than 3.0mbps for h265
272fe47 | 2025-09-03 | Alex Kushleyev | add a test colormap for boson using _color stream
1d81a46 | 2025-08-21 | Alex Kushleyev | fix pipe json for AR0144 Color from YUV to RGB
51afcb4 | 2025-08-21 | Alex Kushleyev | only read camera calibration if eis is enabled; add option to disable AWB on individual misp channels; add hooks for using RGB images instead of YUV for AWB
1c3e99e | 2025-08-14 | Alex Kushleyev | add imx214 misp supported resolutions
2390f20 | 2025-07-30 | modaljc | enable boson misp encoded by default instead of boson small encoded
50a27ba | 2025-07-30 | Alex Kushleyev | Merge branch 'dev' of gitlab.com:voxl-public/voxl-sdk/services/voxl-camera-server into dev
bbc9b89 | 2025-07-30 | Alex Kushleyev | add boson support to MISP; fix real-time fps control
96c6a0d | 2025-07-22 | james | v2.2.5 fix stereo cam pair going out of sync due to too high of an allowed discrepancy
055e11a | 2025-06-16 | Alex Kushleyev | clean up before merge to dev
effc3e8 | 2025-06-12 | Alex Kushleyev | add eis params and minor cleanup
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/7">@Alex-Kushleyev</a>  and modalai team, what can I do to fix that ?<br />
Let me know if you need additional logs or tests.<br />
Thanks in advence</p>
]]></description><link>https://forum.modalai.com/topic/5151/time-of-flight-tof-camera-output-fps-divided-by-5-after-upgrading-from-sdk-1-5-0-to-sdk-1-6-3-starling2-max-c29</link><generator>RSS for Node</generator><lastBuildDate>Tue, 07 Apr 2026 09:40:08 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5151.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 02 Apr 2026 17:26:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Time Of Flight (TOF) camera output FPS divided by 5 after upgrading from SDK 1.5.0 to SDK 1.6.3 (Starling2 Max C29) on Thu, 02 Apr 2026 19:37:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/3216">@qt</a> , there is a "decimator" param, which reduces the TOF fps in standby mode (when drone is not flying) in order to reduce the cpu usage, since the TOF processing software can use substantial cpu depending on the FPS. <a href="https://docs.modalai.com/voxl-camera-server/#camera-server-config-file" rel="nofollow ugc">https://docs.modalai.com/voxl-camera-server/#camera-server-config-file</a></p>
<p dir="auto">in your case, the decimator is set to 5, but i also see that "standby enabled" is set to false, so perhaps there is a bug that still applies the fps decimation.</p>
<p dir="auto">Can you please try setting the decimator to 1 and see if that resolves your issue and we will double check if the <code>standby_enabled</code> parameter is not working correctly.</p>
<p dir="auto">Alex</p>
]]></description><link>https://forum.modalai.com/post/25664</link><guid isPermaLink="true">https://forum.modalai.com/post/25664</guid><dc:creator><![CDATA[Alex Kushleyev]]></dc:creator><pubDate>Thu, 02 Apr 2026 19:37:05 GMT</pubDate></item></channel></rss>
