<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[mavros node on base station fcu_url]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I usually connect my QGroundControl (running on base station) to the voxl which in my unsderstanding "routes" the mavlink data from the flight core to my base station.</p>
<p dir="auto">Sometimes I want to run a mavros instance not on the voxl but on my base station. I am not sure how to configure this node correctly in order to connect to the flight core using voxl as "wifi link". It works if I set the <code>fcu_url</code> param like that: <code>udp://:14550:@VOXL_IP:14556</code> but then the link in my QGroundControl fails. I guess it is because both connections are running over port <code>14550</code>. I have no idea how to set <code>fcu_url</code> and gcs_url`. Or do I have to install additional software on the voxl to route the packages?</p>
<p dir="auto">Any help would be appreciated!</p>
]]></description><link>https://forum.modalai.com/topic/50/mavros-node-on-base-station-fcu_url</link><generator>RSS for Node</generator><lastBuildDate>Fri, 09 Oct 2026 13:20:49 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/50.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 01 Dec 2020 15:27:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to mavros node on base station fcu_url on Wed, 02 Dec 2020 13:38:23 GMT]]></title><description><![CDATA[<p dir="auto">Thank you, it works now. I did not think about using my local mavros as connection link between voxl and QGroundControl.</p>
<p dir="auto">I changed the port. The original issue was a binary installed mavros which crashed when using a <code>gcs_url</code>. So I thought it was a configuration problem but building mavros from source and running with your proposed configuration worked. Thank you again!</p>
<p dir="auto">Raphael</p>
]]></description><link>https://forum.modalai.com/post/165</link><guid isPermaLink="true">https://forum.modalai.com/post/165</guid><dc:creator><![CDATA[rapit]]></dc:creator><pubDate>Wed, 02 Dec 2020 13:38:23 GMT</pubDate></item><item><title><![CDATA[Reply to mavros node on base station fcu_url on Tue, 01 Dec 2020 20:12:43 GMT]]></title><description><![CDATA[<p dir="auto">Hi Rapit,</p>
<p dir="auto">You don't need the secondary qgc_ip, just one udp link from VOXL to MAVROS. In this case you would use MAVROS as another link in the chain between VOXL and QGC.</p>
<p dir="auto">VOXL &lt;--&gt; MAVROS &lt;--&gt; QGC</p>
<p dir="auto">Try launching mavros with the fcu_url :<br />
fcu_url:=udp://VOXL_IP:14550@:14550</p>
<p dir="auto">and gcs_url:<br />
gcs_url:=udp://@127.0.0.1</p>
<p dir="auto">You may need to change the port to QGC to something else (like 14551) to avoid a conflict.</p>
<p dir="auto">Best,<br />
James</p>
]]></description><link>https://forum.modalai.com/post/156</link><guid isPermaLink="true">https://forum.modalai.com/post/156</guid><dc:creator><![CDATA[James Strawson]]></dc:creator><pubDate>Tue, 01 Dec 2020 20:12:43 GMT</pubDate></item><item><title><![CDATA[Reply to mavros node on base station fcu_url on Tue, 01 Dec 2020 15:57:39 GMT]]></title><description><![CDATA[<p dir="auto">Hi Chad,<br />
thank you for the link. I did read section before but I could't see how it would help me as the port on the outgoing connection is still the same.</p>
<p dir="auto">I just configured my base station ip in <code>ggc_ip</code> and <code>secondary_qgc_ip</code> (and <code>en_secondary_qgc</code>) and the connection to my ground control station is successfully initiated by voxl. But when I fire up mavros at my ground station, QGroundControl again loses the connection to voxl, so initiating "from the other direction" does not seem to solve the port conflict.</p>
]]></description><link>https://forum.modalai.com/post/152</link><guid isPermaLink="true">https://forum.modalai.com/post/152</guid><dc:creator><![CDATA[rapit]]></dc:creator><pubDate>Tue, 01 Dec 2020 15:57:39 GMT</pubDate></item><item><title><![CDATA[Reply to mavros node on base station fcu_url on Tue, 01 Dec 2020 15:40:05 GMT]]></title><description><![CDATA[<p dir="auto">Hi Rapit, have you looked at this doc <a href="https://docs.modalai.com/voxl-vision-px4-telemetry/" rel="nofollow ugc">here</a>?</p>
<p dir="auto">I think you'll want to look at this parameter "en_secondary_qgc"</p>
]]></description><link>https://forum.modalai.com/post/151</link><guid isPermaLink="true">https://forum.modalai.com/post/151</guid><dc:creator><![CDATA[Chad Sweet]]></dc:creator><pubDate>Tue, 01 Dec 2020 15:40:05 GMT</pubDate></item></channel></rss>
