<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[AprilTag relocalization fails with down-facing camera due to camera extrinsics mismatch (roll&#x2F;pitch out of bounds)]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/4120/apriltag-relocalization-not-relocalizing">Apriltag relocalization not relocalizing?</a></p>
<p dir="auto">Hello, I have the following issue similar to one above about apriltag relocalization with fixed frame:</p>
<p dir="auto"><strong>Platform / Version:</strong><br />
Starling 2 (C27)<br />
voxl-suite v1.5.0<br />
Front-facing camera used for VIO<br />
Down-facing camera used for AprilTag detection</p>
<p dir="auto"><strong>Issue</strong><br />
AprilTag relocalization works correctly when the tag detector runs on the front-facing camera, but consistently fails when running on the down-facing camera, even though:</p>
<ul>
<li>The down-facing camera intrinsics are correct</li>
<li>The camera→body extrinsics in /etc/modalai/extrinsics.conf are correct</li>
<li>R_tag_to_fixed is correctly set for a flat ground tag R_tag_to_fixed= &lsqb;&lsqb;0, -1, 0], [1,  0, 0], [0,  0, 1&rsqb;&rsqb;</li>
<li>The tag is physically flat and the vehicle is level</li>
<li>With the down-facing camera, voxl-vision-hub repeatedly reports: "WARNING, apriltag roll/pitch out of bounds" does not relocalize.</li>
</ul>
<p dir="auto"><strong>Confirmation</strong><br />
Using the same tag, same fixed-frame configuration, and same environment:</p>
<ul>
<li>Detection from front camera → relocalization succeeds.</li>
<li>Detection from down-facing camera → relocalization rejected.</li>
<li>Swapping only the camera input is sufficient to reproduce the failure.</li>
</ul>
<p dir="auto"><strong>Conclusion</strong><br />
This strongly suggests that the AprilTag relocalization path in voxl-vision-hub is composing R_tag_to_cam → R_cam_to_imu/body using the wrong camera extrinsics (appears to default to the front/tracking camera), rather than the extrinsics corresponding to the camera that actually produced the detection. As a result, the inferred R_tag_to_local ∘ R_fixed_to_tag contains spurious roll/pitch and is rejected by the ±10° gate.</p>
<p dir="auto">Could you please solve the issue in new SDK? (You might add additional parameters in /etc/modalai/voxl-vision-hub.conf to select fixed frame pipe)</p>
<p dir="auto">Best,<br />
Kağan</p>
]]></description><link>https://forum.modalai.com/topic/4992/apriltag-relocalization-fails-with-down-facing-camera-due-to-camera-extrinsics-mismatch-roll-pitch-out-of-bounds</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 20:19:33 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/4992.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 18 Jan 2026 16:44:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to AprilTag relocalization fails with down-facing camera due to camera extrinsics mismatch (roll&#x2F;pitch out of bounds) on Tue, 17 Feb 2026 23:33:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eric-katzfey" aria-label="Profile: Eric-Katzfey">@<bdi>Eric-Katzfey</bdi></a><br />
────────────────────────────────────────────────────────────────────────────────<br />
system-image: 1.8.02-M0054-14.1a-perf<br />
kernel:       #1 SMP PREEMPT Mon Nov 11 22:47:44 UTC 2024 4.19.125<br />
hw platform:  M0054<br />
mach.var:     1.0.1<br />
SKU:          MRB-D0014-4-V1-C27-T9-M22-X0<br />
voxl-suite:   1.4.5<br />
Packages:</p>
<p dir="auto">I am getting this issue as well, where I constantly get WARNING, apriltag roll/pitch out of bounds issue with the front or down tracking camera.</p>
]]></description><link>https://forum.modalai.com/post/25284</link><guid isPermaLink="true">https://forum.modalai.com/post/25284</guid><dc:creator><![CDATA[Nitin Varma Vegesna]]></dc:creator><pubDate>Tue, 17 Feb 2026 23:33:41 GMT</pubDate></item><item><title><![CDATA[Reply to AprilTag relocalization fails with down-facing camera due to camera extrinsics mismatch (roll&#x2F;pitch out of bounds) on Mon, 09 Feb 2026 20:25:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kgn-mdlai" aria-label="Profile: kgn-mdlai">@<bdi>kgn-mdlai</bdi></a> Unfortunately, the April Tag code is quite outdated and hasn't been tested on any of our latest hardware. As it is now it is provided as reference code and if you are able to get things working correctly on your own we are happy to accept PRs to the repo. We do plan an update of this in a future revision of the SDK but there is no scheduled date that we can provide right now.</p>
]]></description><link>https://forum.modalai.com/post/25178</link><guid isPermaLink="true">https://forum.modalai.com/post/25178</guid><dc:creator><![CDATA[Eric Katzfey]]></dc:creator><pubDate>Mon, 09 Feb 2026 20:25:18 GMT</pubDate></item><item><title><![CDATA[Reply to AprilTag relocalization fails with down-facing camera due to camera extrinsics mismatch (roll&#x2F;pitch out of bounds) on Tue, 20 Jan 2026 21:46:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kgn-mdlai" aria-label="Profile: kgn-mdlai">@<bdi>kgn-mdlai</bdi></a> Thank you for bringing this up,  a fix to this is currently being worked on.<br />
Thanks</p>
]]></description><link>https://forum.modalai.com/post/24958</link><guid isPermaLink="true">https://forum.modalai.com/post/24958</guid><dc:creator><![CDATA[ApoorvThapliyal]]></dc:creator><pubDate>Tue, 20 Jan 2026 21:46:58 GMT</pubDate></item></channel></rss>
