<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ADB or Wi-Fi no longer communicating!?!]]></title><description><![CDATA[<p dir="auto">Each PCB is thoroughly tested prior to shipment. If your PCB is no longer responding to ADB or Wi-Fi, it is likely the system flash is corrupted, or "bricked". Please follow the instructions <a href="https://docs.modalai.com/unbrick-voxl/" rel="nofollow ugc">here</a> to fix.</p>
<p dir="auto"><a href="https://youtu.be/6_WzFYnpu40" rel="nofollow ugc">Video Demonstration!</a></p>
<p dir="auto">With flash, like what is used on VOXL, removing power while the kernel is writing will result in corruption and bricking of the board. It can happen during development when a lot of changes are being made on the board and then power is removed.</p>
<p dir="auto">To prevent system partition flash corruption:</p>
<ul>
<li>run poweroff before removing power: <code>$ poweroff -f</code></li>
<li>Use the /data partition for file storage</li>
</ul>
<p dir="auto">Linux has a setting for how often the flash is committed to reduce the risk, but of course there could be different side effects. You can see a writeup on the topic <a href="https://superuser.com/questions/1057007/adjust-linux-disk-flush-intervals-to-avoid-blocking-user-processes" rel="nofollow ugc">here</a>, as it is common in all of this type of single board computers</p>
<p dir="auto">Your smartphone fixes this by making you press the poweroff button before shutting off power and does not have a removable battery.</p>
]]></description><link>https://forum.modalai.com/topic/488/adb-or-wi-fi-no-longer-communicating</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Jul 2026 14:57:19 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/488.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 08 Oct 2021 15:51:23 GMT</pubDate><ttl>60</ttl></channel></rss>
