<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Setting up different AprilTag families]]></title><description><![CDATA[<p dir="auto">Hi ModalAI team,</p>
<p dir="auto">I would like to use different AprilTag families than the old 36h11 family. How much work would it be to run a different family through the modalAI architecture over ROS packages? Ideally, I would like to change the voxl-tag-detector so it can use the custom48h12 family. How would one approach this problem?</p>
<p dir="auto">Thank you.</p>
]]></description><link>https://forum.modalai.com/topic/4830/setting-up-different-apriltag-families</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Apr 2026 12:53:33 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/4830.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 21 Oct 2025 14:14:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Setting up different AprilTag families on Thu, 23 Oct 2025 17:55:33 GMT]]></title><description><![CDATA[<p dir="auto">Hey <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/3137">@dvz</a>, thanks for your query</p>
<p dir="auto">We’re currently in the process of updating the <code>voxl-tag-detector</code> to support additional AprilTag families beyond just the <code>36h11</code>.</p>
<p dir="auto">If you’d like to try this yourself in the meantime, the following line in <code>main.cpp</code> creates the detector for the <code>36h11</code> family: <a href="https://gitlab.com/voxl-public/voxl-sdk/services/voxl-tag-detector/-/blob/master/server/main.cpp?ref_type=heads#L615" rel="nofollow ugc">here</a></p>
<p dir="auto">To add support for the <code>tagCustom48h12</code> family, you can:</p>
<p dir="auto">Add the include:</p>
<pre><code>#include &lt;tagCustom48h12.h&gt;
<p dir="auto">Replace the detector creation line with:</p>
<pre><code>tf = tagCustom48h12_create();
<p dir="auto">Please note that this change may affect the current functionality, you’ll likely need to make additional modifications in <code>main.cpp</code> to ensure it builds and runs correctly.<br />
As mentioned, we’re actively working on making this a much smoother process in the future. But if you’d like to get started now, the above steps should point you in the right direction.</p>
]]></description><link>https://forum.modalai.com/post/24196</link><guid isPermaLink="true">https://forum.modalai.com/post/24196</guid><dc:creator><![CDATA[ApoorvThapliyal]]></dc:creator><pubDate>Thu, 23 Oct 2025 17:55:33 GMT</pubDate></item></channel></rss>
