<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Error on running dfs_server. Cannot get Point Cloud]]></title><description><![CDATA[<p dir="auto">Hi!<br />
I want to get the point cloud from the stereo imagery using the voxl-dfs-server. I have calibrated the stereo camera using the instructions given <a href="https://docs.modalai.com/calibrate-cameras/" rel="nofollow ugc">here</a>. The calibration procedure was successful and it generated the left.yaml, right.yaml and calibration_stereo.xml files. However,  it did not generate the opencv_stereo_extrinsics.yml and opencv_stereo_intrinsics.yml files. I could not find anywhere on the docs any instructions to generate these files. So I had to write them myself taking information from ost.txt. Here are the two files that I wrote:</p>
<ol>
<li>opencv_stereo_extrinsics.yml</li>
</ol>
<pre><code>%YAML:1.0
R1: !!opencv-matrix
   rows: 3
   cols: 3
   dt: d
   data: [ 0.999731, -0.005262, -0.022599,
            0.005377, 0.999973, 0.005039,
            0.022572, -0.005159, 0.999732]
P1: !!opencv-matrix
   rows: 3
   cols: 4
   dt: d
   data: [527.372271, 0.000000, 331.544373, 0.000000,
            0.000000, 527.372271, 240.925325, 0.000000,
            0.000000, 0.000000, 1.000000, 0.000000]
R2: !!opencv-matrix
   rows: 3
   cols: 3
   dt: d
   data: [0.998424, 0.024289, -0.050596,
        -0.024547, 0.999689, -0.004480,
        0.050471, 0.005715, 0.998709]
P2: !!opencv-matrix
   rows: 3
   cols: 4
   dt: d
   data: [527.372271, 0.000000, 331.544373, -42.405281,
<ol start="2">
<li>opencv_stereo_intrinsics.yml</li>
</ol>
<pre><code class="language-%YAML:1.0">M1: !!opencv-matrix
   rows: 3
   cols: 3
   dt: d
   data: [488.682800, 0.000000, 321.505138,
        0.000000, 489.299446, 232.298091,
        0.000000, 0.000000, 1.000000]
D1: !!opencv-matrix
   rows: 1
   cols: 5
   dt: d
   data: [-0.171999, 0.074949, 0.001013, -0.001734, 0.000000]
M2: !!opencv-matrix
   rows: 3
   cols: 3
   dt: d
   data: [ 500.025405, 0.000000, 290.363517,
            0.000000, 500.227973, 248.074606,
D2: !!opencv-matrix
   rows: 1
   cols: 5
   dt: d
   data: [-0.194946, 0.140224, 0.001638, 0.000149, 0.000000]
<p dir="auto">Then I pushed these files to the VOXL using <code> ./push_stereo_cal_to_voxl.sh</code><br />
However, when I run the voxl-dfs-server on the VOXL I get the following output <img src="/assets/uploads/files/1633385313525-screenshot-from-2021-10-04-15-07-53.png" alt="Screenshot from 2021-10-04 15-07-53.png" class=" img-fluid img-markdown" /><br />
I am suspicious of my .yml files that I generated. Do you have any working .yml files that I can use as template and change values for my system.<br />
Please let me know how can I debug this and get the point cloud from the stereo imagery with dfs-server.<br />
Output of <code>voxl-version</code> FYI: <img src="/assets/uploads/files/1633385523940-screenshot-from-2021-10-04-15-11-45-resized.png" alt="Screenshot from 2021-10-04 15-11-45.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Please let me know if any other information is needed. I'd appreciate any insight into solving this.</p>
<p dir="auto">Thanks<br />
Prasad</p>
]]></description><link>https://forum.modalai.com/topic/477/error-on-running-dfs_server-cannot-get-point-cloud</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Jul 2026 15:30:32 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/477.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 04 Oct 2021 22:15:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Error on running dfs_server. Cannot get Point Cloud on Tue, 05 Oct 2021 16:53:41 GMT]]></title><description><![CDATA[<p dir="auto">Hi Prasad,</p>
<p dir="auto">I've seen the error that you talked about with the ungenerated once or twice and running the calibration procedure again properly generated the files.</p>
<p dir="auto">This is a sample stereo cal from my board (that has a few additional data fields from a soon to be released cal rework) that would serve as a good general idea of what the files should look like. The DFS algorithm is, however, very sensitive to inaccuracies and I'd strongly recommend trying to calibrate your cameras again, but if that doesn't work you can add your values to this format:</p>
<pre><code>yocto:/$ cat /data/modalai/opencv_stereo_extrinsics.yml
%YAML:1.0
R: !!opencv-matrix
   rows: 3
   cols: 3
   dt: d
   data: [ 9.9965050025202740e-01, -5.6519379540328910e-04,
       2.6430245966411248e-02, 2.8842568739021546e-03,
       9.9613506820545850e-01, -8.7787282413751958e-02,
       -2.6278478041102546e-02, 8.7832832399280705e-02,
       9.9578854941426354e-01 ]
T: !!opencv-matrix
   rows: 3
   cols: 1
   dt: d
   data: [ -7.9514399346537298e-02, -2.7245018421472277e-03,
       6.0288890076187220e-04 ]
reprojection_error: 2.8997817600221831e-01
calibration_time: "2021-09-30 22:52:56"
yocto:/$ cat /data/modalai/opencv_stereo_intrinsics.yml
%YAML:1.0
M1: !!opencv-matrix
   rows: 3
   cols: 3
   dt: d
   data: [ 4.9291881707143079e+02, 0., 3.0643471662712096e+02, 0.,
       4.9232152259255315e+02, 2.1697996372929907e+02, 0., 0., 1. ]
D1: !!opencv-matrix
   rows: 5
   cols: 1
   dt: d
   data: [ -1.6984598364049669e-01, 6.0034285910162230e-02,
       -8.8644933037586781e-04, -4.1419313003228072e-04, 0. ]
reprojection_error1: 1.9741562557305206e-01
M2: !!opencv-matrix
   rows: 3
   cols: 3
   dt: d
   data: [ 4.9673975454370270e+02, 0., 3.1711708934220133e+02, 0.,
       4.9610254255552854e+02, 2.2876245199481119e+02, 0., 0., 1. ]
D2: !!opencv-matrix
   rows: 5
   cols: 1
   dt: d
   data: [ -1.6758727319959599e-01, 5.4041564358266361e-02,
       -1.5695644102222835e-03, -5.8891426327232642e-04, 0. ]
reprojection_error2: 3.1594418176162986e-01
width: 640
height: 480
distortion_model: plumb_bob
]]></description><link>https://forum.modalai.com/post/2278</link><guid isPermaLink="true">https://forum.modalai.com/post/2278</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 05 Oct 2021 16:53:41 GMT</pubDate></item></channel></rss>
