<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[barometer status]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/moderator" aria-label="Profile: Moderator">@<bdi>Moderator</bdi></a></p>
<p dir="auto">I want to know the Flight Core v2 Onboard barometer sensors' implementation status. Is it working or not?</p>
<p dir="auto">Because, as per the details on page "Flight Core v2 Onboard Sensors" Link- <a href="https://docs.modalai.com/flight-core-v2-onboard-sensors/" rel="nofollow ugc">https://docs.modalai.com/flight-core-v2-onboard-sensors/</a><br />
There are 2 barometer sensors available.</p>
<ul>
<li>
<p dir="auto">But BARO1 - BMP388 (U5, I2C4, 0x76)  is disabled by default.- Can you provide details on why it was disabled? any reasons like not stable output, improper implementation, or<br />
Can we enable BARO1 and use it without any issues?</p>
</li>
<li>
<p dir="auto">Now BARO2 - ICP-20100 (U17, I2C4, 0x63) seems set as default but as per Note added "Note: ICP-20100 not ported from VOXL2 yet.". It seems like not working at all.<br />
Can you clarify the status of it?</p>
</li>
</ul>
<p dir="auto">Also, I saw posts claiming issues with the barometer on Voxl-mini<br />
Like, data is not stable, variation is too high?<br />
Can you share details for Flight Core 2 sensors, how reliable it is?</p>
<p dir="auto">Thank you.<br />
Ravi</p>
]]></description><link>https://forum.modalai.com/topic/4742/barometer-status</link><generator>RSS for Node</generator><lastBuildDate>Wed, 09 Sep 2026 12:26:33 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/4742.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 15 Sep 2025 14:38:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to barometer status on Tue, 16 Sep 2025 18:23:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ravi" aria-label="Profile: ravi">@<bdi>ravi</bdi></a> The documentation has been updated. If you are running a recent release from us then you will be using the ICP-20100 barometer. The BMP388 will not be started.</p>
]]></description><link>https://forum.modalai.com/post/23774</link><guid isPermaLink="true">https://forum.modalai.com/post/23774</guid><dc:creator><![CDATA[Eric Katzfey]]></dc:creator><pubDate>Tue, 16 Sep 2025 18:23:15 GMT</pubDate></item><item><title><![CDATA[Reply to barometer status on Tue, 16 Sep 2025 12:23:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eric-katzfey" aria-label="Profile: Eric-Katzfey">@<bdi>Eric-Katzfey</bdi></a><br />
No, I am not saying the sensors are not working.<br />
In fact, I haven't tested yet.<br />
I just stated everything mentioned in the flight-core-v2 user guide.<br />
Link- <a href="https://docs.modalai.com/flight-core-v2-onboard-sensors/" rel="nofollow ugc">https://docs.modalai.com/flight-core-v2-onboard-sensors/</a></p>
<p dir="auto">So, while testing, I can check it or configure it on PX4 and reprogram.</p>
<p dir="auto">If everything is working, why user guide say?<br />
<img src="/assets/uploads/files/1758025174698-87941590-b202-47e4-8c6a-56db8d76c26d-image.png" alt="87941590-b202-47e4-8c6a-56db8d76c26d-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">So, as per you say, BARO1 is working but disabled?<br />
And BARO2 is working perfectly. Even though there is a mention of software not ported?</p>
<p dir="auto">Please clarify for both.<br />
Thank you.</p>
]]></description><link>https://forum.modalai.com/post/23772</link><guid isPermaLink="true">https://forum.modalai.com/post/23772</guid><dc:creator><![CDATA[ravi]]></dc:creator><pubDate>Tue, 16 Sep 2025 12:23:17 GMT</pubDate></item><item><title><![CDATA[Reply to barometer status on Mon, 15 Sep 2025 17:18:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ravi" aria-label="Profile: ravi">@<bdi>ravi</bdi></a> The ICP barometer should be working. The issues on the VOXL2 mini are related to temperature since it is on the same board as the Qualcomm device that creates a lot of heat on it's own so not applicable to flight core. Why do you say that it is not working? Is the sensor_baro topic being published? What software version do you have loaded on the flight core?</p>
]]></description><link>https://forum.modalai.com/post/23767</link><guid isPermaLink="true">https://forum.modalai.com/post/23767</guid><dc:creator><![CDATA[Eric Katzfey]]></dc:creator><pubDate>Mon, 15 Sep 2025 17:18:51 GMT</pubDate></item></channel></rss>
