<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Flow Server]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">Had a general question about flow server</p>
<ol>
<li>It appears that the flow server is optimized for the lepton, but was curious what the lift would be to get it working with another camera. I see I can change the pipeline: <img src="/assets/uploads/files/1754323656920-ac91a178-9698-4b8b-8edb-99f01f804e66-image.png" alt="ac91a178-9698-4b8b-8edb-99f01f804e66-image.png" class=" img-fluid img-markdown" /></li>
</ol>
<p dir="auto">Wondering if there are any more "gotchas" besides changing the camera pipe and resolution</p>
<ol start="2">
<li>multi-flow: I understand that voxl-flow-server only allows for one camera stream at a time. Is there anything preventing us from spinning up multiple instances of it in order to have multiple flows running?</li>
</ol>
<p dir="auto">Thank you!</p>
]]></description><link>https://forum.modalai.com/topic/4647/flow-server</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Apr 2026 13:06:06 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/4647.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 04 Aug 2025 16:17:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Flow Server on Mon, 04 Aug 2025 21:07:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/413">@wilkinsaf</a></p>
<ol>
<li>Yes this is definitely possible</li>
<li>You would need to modify flow-server and possibly feature-tracker to ensure this is pointed at the right pipe</li>
<li>Might also need a bit of calibration here and there</li>
<li>Have not tested having multiple versions of flow-server, but should be possible.</li>
<li>Would need to ensure this works with a downard facing tof for accurate height estimate</li>
</ol>
<p dir="auto">To get a rough draft of this working, would take ~2 days</p>
]]></description><link>https://forum.modalai.com/post/23372</link><guid isPermaLink="true">https://forum.modalai.com/post/23372</guid><dc:creator><![CDATA[wilkinsaf]]></dc:creator><pubDate>Mon, 04 Aug 2025 21:07:14 GMT</pubDate></item></channel></rss>
