<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Quectel-CM error when Initializing a connection (SDK 1.5.0)]]></title><description><![CDATA[<p dir="auto">Hi!</p>
<p dir="auto">I just updated to the newest VOXL SDK (1.5.0) to get support for the Hadron and Boson cameras and after the flash my Quectel 5G modem will no longer get an IP address from the cellular network. I ran through voxl-configure-modem again and I also ran the voxel-modem-start command manually. When I run voxel-modem-start manually, I get this error:</p>
<pre><code>qrb5165 based hardware detected...
\Setting mode preference to LTE / 5G
AT+QNWPREFCFG="mode_pref",LTE:NR5G
OK
Initalizing cellular connection...
/usr/bin/voxl-modem-start: line 84: /usr/bin/quectel-CM: cannot execute binary file: Exec format error
<p dir="auto">If I run "file /usr/bin/quectel-CM", I get this:</p>
<pre><code>/usr/bin/quectel-CM: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, BuildID[sha1]=22bb006a724be58f44e4eb6b7ed46f859144f314, for GNU/Linux 3.2.0, stripped
<p dir="auto">Isn't this supposed to be "ARM aarch64"? I'm going to try copying the quectel-CM from a previous release to see if that fixes my issue, but let me know.</p>
]]></description><link>https://forum.modalai.com/topic/4565/quectel-cm-error-when-initializing-a-connection-sdk-1-5-0</link><generator>RSS for Node</generator><lastBuildDate>Sat, 12 Sep 2026 08:30:26 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/4565.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 03 Jul 2025 12:43:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Quectel-CM error when Initializing a connection (SDK 1.5.0) on Thu, 03 Jul 2025 13:03:22 GMT]]></title><description><![CDATA[<p dir="auto">I grabbed the /usr/bin/quectel-CM from another VOXL2 on an older SDK (1.4.1) and swapped out the one that came with 1.5.0 and everything is working again...</p>
]]></description><link>https://forum.modalai.com/post/22855</link><guid isPermaLink="true">https://forum.modalai.com/post/22855</guid><dc:creator><![CDATA[Matthew Wellner]]></dc:creator><pubDate>Thu, 03 Jul 2025 13:03:22 GMT</pubDate></item></channel></rss>
