<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cannot connect to cameras on VOXL Flight, voxl-camera-server crashes]]></title><description><![CDATA[<p dir="auto">I upgraded the system image to SDK1.2, as it is the latest supported for VOXL Flight (I have a beta version of the Starling drone):</p>
<pre><code class="language-txt">voxl-version
system-image: 4.0.0
kernel:       #1 SMP PREEMPT Thu Oct 13 17:57:05 UTC 2022 3.18.71-perf
hw platform:  VOXL
mach.var:     1.0
voxl-suite:   1.2.0
Packages:
Repo: http://voxl-packages.modalai.com/dists/apq8096/sdk-1.2/binary-arm64/
Last Updated: Never
List:
	apq8096-dfs-server          0.3.1
	apq8096-imu-server          1.1.0
	apq8096-libpng              1.6.38-1
	apq8096-rangefinder-server  0.1.3
	apq8096-system-tweaks       0.2.3
	apq8096-tflite              2.8.3-1
	libapq8096-io               0.6.1
	libmodal-cv                 0.4.0
	libmodal-exposure           0.1.0
	libmodal-journal            0.2.2
	libmodal-json               0.4.3
	libmodal-pipe               2.10.0
	libvoxl-cci-direct          0.2.1
	libvoxl-cutils              0.1.1
	voxl-camera-calibration     0.5.4
	voxl-camera-server          1.9.2
	voxl-configurator           0.5.6
	voxl-cpu-monitor            0.4.8
	voxl-docker-support         1.3.1
	voxl-jpeg-turbo             2.1.3-5
	voxl-lepton-server          1.2.0
	voxl-logger                 0.4.0
	voxl-mavcam-manager         0.5.3
	voxl-mavlink                0.1.1
	voxl-mavlink-server         1.4.0
	voxl-modem                  1.0.9
	voxl-mongoose               7.7.0-1
	voxl-mpa-to-ros             0.3.7
	voxl-mpa-tools              1.1.5
	voxl-opencv                 4.5.5-2
	voxl-portal                 0.6.5
	voxl-qvio-server            1.0.2
	voxl-streamer               0.7.4
	voxl-suite                  1.2.0
	voxl-system-image           4.0-r0
	voxl-tag-detector           0.0.4
	voxl-tflite-server          0.3.2
	voxl-utils                  1.3.9
	voxl-uvc-server             0.1.6
	voxl-vision-hub             1.7.4
	voxl-vpn                    0.0.6
<p dir="auto">The cameras were working fine up until recently and I did not attempt to modify any hardware. The following cameras are connected to VOXL Flight (<a href="https://docs.modalai.com/voxl-flight-datasheet-connectors/" rel="nofollow ugc">connectors</a>) :</p>
<ul>
<li>tracking (port J4)</li>
<li>hires (port J2)</li>
<li>tof (port J3)</li>
</ul>
<p dir="auto">(left unaltered as provided by ModalAI)</p>
<p dir="auto">I performed the following setup after flashing the image:</p>
<pre><code class="language-bash">voxl-configure-cameras 6 # Hires + TOF + Tracking
voxl-configure-extrinsics starling_v1_voxl_flight
voxl-configure-qvio factory_enable_imu0 # for VOXL Flight all-in-one board.
<p dir="auto">Which yielded the following extrinsics:</p>
<pre><code>voxl-inspect-extrinsics
#0:
    parent:                imu1
    child:                 imu0
    T_child_wrt_parent:   -0.048   0.037   0.002
    RPY_parent_to_child:   0.0     0.0     0.0
    R_child_to_parent:     1.000  -0.000   0.000
                           0.000   1.000  -0.000
                           0.000   0.000   1.000
#1:
    parent:                imu0
    child:                 tracking
    T_child_wrt_parent:    0.060  -0.014   0.011
    RPY_parent_to_child:   0.0    45.0    90.0
    R_child_to_parent:     0.000  -0.707   0.707
                           1.000   0.000  -0.000
                          -0.000   0.707   0.707
#2:
    parent:                imu1
    child:                 tracking
    T_child_wrt_parent:    0.012   0.015   0.013
                           1.000   0.000  -0.000
                          -0.000   0.707   0.707
#3:
    parent:                body
    child:                 imu0
    T_child_wrt_parent:    0.000   0.014  -0.008
                           0.000   1.000  -0.000
                           0.000   0.000   1.000
#4:
    parent:                body
    child:                 imu1
    T_child_wrt_parent:    0.049  -0.015  -0.011
                           0.000   1.000  -0.000
                           0.000   0.000   1.000
#5:
    parent:                body
    child:                 stereo_l
    T_child_wrt_parent:    0.065  -0.040   0.000
    RPY_parent_to_child:   0.0    90.0    90.0
    R_child_to_parent:     0.000  -0.000   1.000
                           1.000   0.000  -0.000
                          -0.000   1.000   0.000
#6:
    parent:                body
    child:                 tof
    T_child_wrt_parent:    0.065  -0.013   0.010
                           1.000   0.000  -0.000
                          -0.000   1.000   0.000
#7:
    parent:                body
    child:                 ground
    T_child_wrt_parent:    0.000   0.000   0.029
                           0.000   1.000  -0.000
                           0.000   0.000   1.000
<p dir="auto">Listing plugged in camera with <code>voxl-camera-server -l</code> returns:</p>
<pre><code>DEBUG:   Attempting to open the hal module
DEBUG:   ----------- Number of cameras: 2
DEBUG:   Note: This list comes from the HAL module and may not be indicative
DEBUG:   	of configurations that have full pipelines
DEBUG:   Number of cameras: 2
Stats for camera: 0
ANDROID_SCALER_AVAILABLE_RAW_SIZES:
These are likely supported by the sensor
4208 x 3120
4096 x 2160
2104 x 1560
1920 x 1080
1280 x  720
2104 x 1506
ANDROID_SCALER_AVAILABLE_STREAM_CONFIGURATIONS:
These are NOT necessarily supported by the sensor
4208 x 3120 HAL_PIXEL_FORMAT_RAW_OPAQUE
ANDROID_SENSOR_INFO_SENSITIVITY_RANGE
	min = 41
	max = 3987
ANDROID_SENSOR_MAX_ANALOG_SENSITIVITY
	332
ANDROID_SENSOR_INFO_EXPOSURE_TIME_RANGE
	min = 20678ns
	max = 683881516ns
Stats for camera: 1
 640 x  480
 320 x  240
 640 x  480 HAL_PIXEL_FORMAT_RAW_OPAQUE
	min = 100
	max = 6399
	6399
	min = 19425ns
	max = 1020461640ns
Number of cameras detected: 2
<p dir="auto">Trying to run <code>voxl-camera-server -d 0</code> generates:</p>
<pre><code class="language-txt">WARNING Failed to set priority, errno = 1
This may be because the FIFO scheduler is not available when running in a console.
It should work properly when run as a systemd background process on boot.
WARNING: failed to set scheduler
using new imx214 defaults
configuration for 3 cameras:
cam #0
    sensor type:         ov7251
    isEnabled:           1
    camId:               2
    camId2:              -1
    fps:                 30
    en_rotate:           0
    en_rotate2:          0
    en_preview:          1
    pre_width:           640
    pre_height:          480
    en_raw_preview:      1
    en_small_video:      0
    small_video_width:   -1
    small_video_height:  -1
    en_large_video:      0
    large_video_width:   -1
    large_video_height:  -1
    en_snapshot:         0
    snap_width:          -1
    snap_height:         -1
    ae_mode:             lme_msv
    standby_enabled:     0
    decimator:           1
    independent_exposure:0
cam #1
    sensor type:         pmd-tof
    isEnabled:           1
    camId:               1
    camId2:              -1
    fps:                 5
    en_rotate:           0
    en_rotate2:          0
    en_preview:          1
    pre_width:           224
    pre_height:          1557
    en_raw_preview:      1
    en_small_video:      0
    en_large_video:      0
    en_snapshot:         0
    snap_width:          -1
    snap_height:         -1
    ae_mode:             off
    standby_enabled:     0
    decimator:           5
cam #2
    sensor type:         imx214
    isEnabled:           1
    camId:               0
    camId2:              -1
    fps:                 30
    en_rotate:           0
    en_rotate2:          0
    en_preview:          0
    pre_width:           640
    pre_height:          480
    en_raw_preview:      0
    en_small_video:      1
    small_video_width:   1024
    small_video_height:  768
    en_large_video:      1
    large_video_width:   1920
    large_video_height:  1080
    en_snapshot:         1
    snap_width:          4160
    snap_height:         3120
    ae_mode:             isp
    standby_enabled:     0
    decimator:           1
fsync_en:            0
fsync_gpio:          111
DEBUG:   ------ voxl-camera-server: Starting 3 cameras
Starting Camera: tracking (id #2)
WARNING: cam tracking (id 2) does not seem to be alive
Starting Camera: tof (id #1)
DEBUG:   Checking Gain limits for Camera: tof
Using gain limits min: 100 max: 6399
DEBUG:   cam ID 1 checking for fmt:   33  w:  224 h: 1557 o:   0
DEBUG:   	==&gt; option   0: format= 36 width= 640 height= 480 is_input=0
DEBUG:   	==&gt; option   4: format= 36 width= 320 height= 240 is_input=0
DEBUG:   	==&gt; option   8: format= 32 width= 640 height= 480 is_input=0
DEBUG:   	==&gt; option  12: format= 32 width= 320 height= 240 is_input=0
DEBUG:   	==&gt; option  16: format= 35 width= 640 height= 480 is_input=0
DEBUG:   	==&gt; option  20: format= 35 width= 640 height= 240 is_input=0
DEBUG:   	==&gt; option  24: format= 35 width= 640 height= 360 is_input=0
DEBUG:   	==&gt; option  28: format= 35 width= 480 height= 480 is_input=0
DEBUG:   	==&gt; option  32: format= 35 width= 480 height= 360 is_input=0
DEBUG:   	==&gt; option  36: format= 35 width= 480 height= 320 is_input=0
DEBUG:   	==&gt; option  40: format= 33 width= 640 height= 480 is_input=0
DEBUG:   	==&gt; option  44: format= 33 width= 640 height= 240 is_input=0
DEBUG:   	==&gt; option  48: format= 33 width= 640 height= 360 is_input=0
DEBUG:   	==&gt; option  52: format= 33 width= 480 height= 480 is_input=0
DEBUG:   	==&gt; option  56: format= 33 width= 480 height= 360 is_input=0
DEBUG:   	==&gt; option  60: format= 33 width= 480 height= 320 is_input=0
DEBUG:   	==&gt; option  64: format= 37 width= 640 height= 480 is_input=0
DEBUG:   	==&gt; option  68: format= 37 width= 320 height= 240 is_input=0
DEBUG:   	==&gt; option  72: format= 38 width= 640 height= 480 is_input=0
DEBUG:   	==&gt; option  76: format= 38 width= 320 height= 240 is_input=0
DEBUG:   	==&gt; option  80: format= 34 width= 640 height= 480 is_input=0
DEBUG:   	==&gt; option  84: format= 34 width= 640 height= 240 is_input=0
DEBUG:   	==&gt; option  88: format= 34 width= 640 height= 360 is_input=0
DEBUG:   	==&gt; option  92: format= 34 width= 480 height= 480 is_input=0
DEBUG:   	==&gt; option  96: format= 34 width= 480 height= 360 is_input=0
DEBUG:   	==&gt; option 100: format= 34 width= 480 height= 320 is_input=0
ERROR:   Camera 1 failed to find supported preview config: 224x1557
WARNING: Failed to start cam tof due to invalid resolution
WARNING: assuming cam is missing and trying to compensate
Starting Camera: hires (originally id #0) with id offset: 1
WARNING: cam hires (id -1) does not seem to be alive
ERROR:   failed to initialize any cameras
------ voxl-camera-server: Started 0 of 3 cameras
------ voxl-camera-server: Camera server is now stopping
DEBUG:   	Erasing all managers
------ voxl-camera-server: Camera server exited gracefully, returning -1
<p dir="auto">Finally, here is the camera server configuration (<code>/etc/modalai/voxl-camera-server.conf</code>) :</p>
<pre><code>{
	"version":	0.1,
	"fsync_en":	false,
	"fsync_gpio":	111,
	"cameras":	[{
			"type":	"ov7251",
			"name":	"tracking",
			"enabled":	true,
			"camera_id":	2,
			"fps":	30,
			"en_rotate":	false,
			"en_preview":	true,
			"preview_width":	640,
			"preview_height":	480,
			"en_raw_preview":	true,
			"ae_mode":	"lme_msv",
			"ae_desired_msv":	60,
			"exposure_min_us":	20,
			"exposure_max_us":	33000,
			"gain_min":	54,
			"gain_max":	8000,
			"exposure_soft_min_us":	5000,
			"ae_exposure_period":	1,
			"ae_gain_period":	1
			"type":	"pmd-tof",
			"name":	"tof",
			"enabled":	true,
			"camera_id":	1,
			"fps":	5,
			"ae_mode":	"off",
			"standby_enabled":	false,
			"decimator":	5
			"type":	"imx214",
			"name":	"hires",
			"enabled":	true,
			"camera_id":	0,
			"fps":	30,
			"en_preview":	false,
			"en_raw_preview":	false,
			"en_small_video":	true,
			"small_video_width":	1024,
			"small_video_height":	768,
			"small_venc_mode":	"h264",
			"small_venc_br_ctrl":	"cqp",
			"small_venc_Qfixed":	30,
			"small_venc_Qmin":	15,
			"small_venc_Qmax":	40,
			"small_venc_nPframes":	9,
			"small_venc_mbps":	2,
			"en_large_video":	true,
			"large_video_width":	1920,
			"large_video_height":	1080,
			"large_venc_mode":	"h264",
			"large_venc_br_ctrl":	"cqp",
			"large_venc_Qfixed":	40,
			"large_venc_Qmin":	15,
			"large_venc_Qmax":	50,
			"large_venc_nPframes":	29,
			"large_venc_mbps":	40,
			"en_snapshot":	true,
			"en_snapshot_width":	4160,
			"en_snapshot_height":	3120,
			"ae_mode":	"isp"
<p dir="auto">I doubt all cameras are dead... I can actually run the server with only hires by setting the enabled field to false in the camera server config. Could this be linked to some hardware/software version mismatch of the expected camera types? Any pointers as to how to address this issue would be much appreciated!</p>
<p dir="auto"><strong>Edit</strong>: a similar issue has been raised before, see <a href="https://forum.modalai.com/topic/4439/cannot-connect-to-cameras-on-voxl-flight-voxl-camera-server-crashes">this post</a>, but no solution was given.</p>
]]></description><link>https://forum.modalai.com/topic/4439/cannot-connect-to-cameras-on-voxl-flight-voxl-camera-server-crashes</link><generator>RSS for Node</generator><lastBuildDate>Sun, 11 Oct 2026 23:35:33 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/4439.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 19 May 2025 16:36:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cannot connect to cameras on VOXL Flight, voxl-camera-server crashes on Mon, 19 May 2025 18:05:57 GMT]]></title><description><![CDATA[<p dir="auto">I tried swapping the tof camera with a spare one I had around. The spare tof worked immediately without issue. I then disconnected the spare tof, configured the camera server with only hires and tracking (with no connected tof camera, which worked fine). I then tried to plug back in the original tof and it started working again. So nothing changed, just unplugged and plugged back the tof camera and reflected the changes by configuring the camera server accordingly, weird...</p>
]]></description><link>https://forum.modalai.com/post/22282</link><guid isPermaLink="true">https://forum.modalai.com/post/22282</guid><dc:creator><![CDATA[LucasW]]></dc:creator><pubDate>Mon, 19 May 2025 18:05:57 GMT</pubDate></item></channel></rss>
