<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Starling 2 Max main voltage]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I am trying to understand what the main voltage, or bus voltage, is on the Starling 2 Max.  Are the 2 batteries in series or parallel on the drone?  I.e. is the main voltage ~7.5V or ~15V? and if you wanted to tap off this voltage where would a suitable location be on the drone?  Is there an electrical schematic of the drone available?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.modalai.com/topic/4334/starling-2-max-main-voltage</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Jul 2026 15:20:54 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/4334.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 09 Apr 2025 18:26:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Starling 2 Max main voltage on Thu, 10 Apr 2025 18:31:08 GMT]]></title><description><![CDATA[<p dir="auto">Thanks..</p>
]]></description><link>https://forum.modalai.com/post/21802</link><guid isPermaLink="true">https://forum.modalai.com/post/21802</guid><dc:creator><![CDATA[Kory4Drone]]></dc:creator><pubDate>Thu, 10 Apr 2025 18:31:08 GMT</pubDate></item><item><title><![CDATA[Reply to Starling 2 Max main voltage on Wed, 09 Apr 2025 19:26:03 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/kory4drone" aria-label="Profile: Kory4Drone">@<bdi>Kory4Drone</bdi></a> ,</p>
<p dir="auto">Starling 2 MAX uses two 2S Li-Ion batteries. When connected to the drone, they are connected in series, creating a single 4S battery. The - and + terminals of the combined battery are connected directly to the ESC.</p>
<p dir="auto">You could tap off the power at the ESC main power pads. If the current for your aux functionality is low (up to a few Amps), then you could use the "Battery Input Test Points" on the opposite side from the main pads. These pads are via-stitched to the opposite side using many vias and should be solid.</p>
<a href="https://docs.modalai.com/voxl-mini-esc-datasheet/" title="VOXL Mini 4-in-1 ESC Datasheet">
<img src="https://docs.modalai.com/images/social/docs-card.png" class="card-img-top not-responsive" style="max-height:15rem" alt="Link Preview Image" />
</a>
<div class="card-body">
<h5 class="card-title">
<a class="text-decoration-none" href="https://docs.modalai.com/voxl-mini-esc-datasheet/">
</a>
</h5>
<p class="card-text line-clamp-3">ModalAI technical documentation for VOXL and VOXL 2 Companion Computers for PX4 and ArduPilot Obstacle Avoidance and GPS-denied navigation, assembled in the USA</p>
</div>
<a href="https://docs.modalai.com/voxl-mini-esc-datasheet/" class="card-footer text-body-secondary small d-flex gap-2 align-items-center lh-2">
<img src="https://docs.modalai.com/favicon.ico" alt="favicon" class="not-responsive overflow-hiddden" style="max-width:21px;max-height:21px" />
<p class="d-inline-block text-truncate mb-0">ModalAI Technical Docs <span class="text-secondary">(docs.modalai.com)</span></p>
</a>
</div><p></p>
<p dir="auto"><img src="/assets/uploads/files/1744226226118-8652247b-5e2a-4ef9-8897-e18de7aa3502-image.png" alt="8652247b-5e2a-4ef9-8897-e18de7aa3502-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I do not think we have the power wiring diagram for the drone posted.. will check.</p>
<p dir="auto">Alex</p>
]]></description><link>https://forum.modalai.com/post/21787</link><guid isPermaLink="true">https://forum.modalai.com/post/21787</guid><dc:creator><![CDATA[Alex Kushleyev]]></dc:creator><pubDate>Wed, 09 Apr 2025 19:26:03 GMT</pubDate></item></channel></rss>
