<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Clarification on R/C System Frequency and Power Settings]]></title><description><![CDATA[<p dir="auto">We are facing some difficulty responding to TRC’s technical queries, and would appreciate your assistance in clarifying the following points:</p>
<pre><code>                01. Does the 915 MHz value refer to the center frequency of the FCC-allowed band from 902 MHz to 928 MHz?
                02. Is it possible to configure the system to operate only within 920 MHz to 925 MHz, in alignment with the TRC-permitted frequency band?
                03. Can the system be limited to a maximum output power of 23 dBm (200 mW) as per TRC regulations?
                04. Do you have any FCC test reports for the T7 configuration that you could share?
                05. Do you have any CE test reports for the T7 configuration that you could share?
]]></description><link>https://forum.modalai.com/topic/4316/clarification-on-r-c-system-frequency-and-power-settings</link><generator>RSS for Node</generator><lastBuildDate>Fri, 09 Oct 2026 08:13:53 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/4316.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 04 Apr 2025 02:21:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Clarification on R/C System Frequency and Power Settings on Sun, 06 Apr 2025 06:47:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eric-katzfey" aria-label="Profile: Eric-Katzfey">@<bdi>Eric-Katzfey</bdi></a> Yes. This is regarding the Starling 2 Max GPS-denied Development Drone.</p>
]]></description><link>https://forum.modalai.com/post/21701</link><guid isPermaLink="true">https://forum.modalai.com/post/21701</guid><dc:creator><![CDATA[Xavier_Team]]></dc:creator><pubDate>Sun, 06 Apr 2025 06:47:59 GMT</pubDate></item><item><title><![CDATA[Reply to Clarification on R/C System Frequency and Power Settings on Fri, 04 Apr 2025 21:37:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xavier_team" aria-label="Profile: Xavier_Team">@<bdi>Xavier_Team</bdi></a> Is this regarding a ModalAI product? If so, which one?</p>
]]></description><link>https://forum.modalai.com/post/21690</link><guid isPermaLink="true">https://forum.modalai.com/post/21690</guid><dc:creator><![CDATA[Eric Katzfey]]></dc:creator><pubDate>Fri, 04 Apr 2025 21:37:21 GMT</pubDate></item></channel></rss>
