<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Which development environment is suitable to build ROS2 packages and nodes for the RB5]]></title><description><![CDATA[<p dir="auto">Hi</p>
<p dir="auto">I have the following Rb5<br />
system-image: 1.7.1-M0052-14.1a-perf-nightly-20231025<br />
kernel: #1 SMP PREEMPT Thu Oct 26 05:24:02 UTC 2023 4.19.125<br />
hw version: M0052<br />
voxl-suite: 1.1.2</p>
<p dir="auto">Question:<br />
Which development environment is suitable to build ROS2 packages and nodes for the RB5?<br />
I have listed the following environment so far</p>
<p dir="auto">1)VScode ROS2 environment</p>
<pre><code>2)Voxl-emulator
3)RB5-flight emulator
4)docker pull arm64v8/ros
<p dir="auto">Thanks</p>
]]></description><link>https://forum.modalai.com/topic/4268/which-development-environment-is-suitable-to-build-ros2-packages-and-nodes-for-the-rb5</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 00:07:30 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/4268.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 19 Mar 2025 12:51:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Which development environment is suitable to build ROS2 packages and nodes for the RB5 on Thu, 20 Mar 2025 16:19:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/1356">@Zachary-Lowell-0</a></p>
<ol>
<li>
<p dir="auto">What kind of upgrade is necessary for this Rb5? Should we upgrade the sdk?<br />
we can run ros2 foxy with it. The dds is also working.</p>
</li>
<li>
<p dir="auto">How did you build this ros2 packages and nodes<br />
<a href="https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-to-ros2" rel="nofollow ugc">https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-to-ros2</a></p>
</li>
</ol>
<p dir="auto">Thank you</p>
]]></description><link>https://forum.modalai.com/post/21433</link><guid isPermaLink="true">https://forum.modalai.com/post/21433</guid><dc:creator><![CDATA[tahawaru]]></dc:creator><pubDate>Thu, 20 Mar 2025 16:19:08 GMT</pubDate></item><item><title><![CDATA[Reply to Which development environment is suitable to build ROS2 packages and nodes for the RB5 on Wed, 19 Mar 2025 20:52:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2108">@tahawaru</a> cant say that I can recreate this as the RB5 board is fully EOL and depracated.</p>
<p dir="auto">As for the best ROS2 environment you can run via docker, I always leverage ros humble docker image to program on. Since you are rurnning SDK 1.1.2 I am unsure if the dds micro-agent is on that SDK - if the goal is to just use docker on the board and leverage ros2, I would recommend:</p>
<p dir="auto">docker pull ros:humble-ros-base-jammy</p>
<p dir="auto">OR</p>
<p dir="auto">docker pull ros:humble-ros-desktop-jammy</p>
]]></description><link>https://forum.modalai.com/post/21419</link><guid isPermaLink="true">https://forum.modalai.com/post/21419</guid><dc:creator><![CDATA[Zachary Lowell 0]]></dc:creator><pubDate>Wed, 19 Mar 2025 20:52:32 GMT</pubDate></item></channel></rss>
