<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA["weird" error response trying to QDL VOLX2 (unbricking)]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I have tried the web based interface for unbricking my VOXL2 device but no success. It fails on CDT flashing.</p>
<p dir="auto">Device shows up in QDL mode<br />
Qualcomm, Inc. Gobi Wireless Modem (QDL mode)</p>
<p dir="auto">I am familiar with using QDL so tried my own install I use for my work devices and this is the output of flashing which I find very strange</p>
<pre><code>LOG: INFO: benchmark
LOG: INFO: emmc
LOG: INFO: ufs
LOG: INFO: fixgpt
LOG: INFO: getsha256digest
LOG: INFO: End of supported functions 15
LOG: INFO: Calling handler for configure
LOG: INFO: Storage type set to value UFS
LOG: INFO: Calling handler for program
LOG: ERROR: Failed to open the UFS Device slot 0 partition 3
LOG: ERROR: Failed to open the device:3 slot:0 partition:3 error:0
LOG: ERROR: OPEN handle NULL and no error, weird 344481268
LOG: ERROR: Failed to open device, type:UFS, slot:0, lun:3 error:3
[PROGRAM] failed to setup programming
<p dir="auto">I have never seen this "weird" error before. I get this trying to run the same commands that the python scripts do in the web interface.<br />
Are there any suggestions on how to proceed to unbrick this unit?</p>
<p dir="auto">Thanks,<br />
Brian</p>
]]></description><link>https://forum.modalai.com/topic/4167/weird-error-response-trying-to-qdl-volx2-unbricking</link><generator>RSS for Node</generator><lastBuildDate>Sat, 05 Sep 2026 21:08:42 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/4167.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 11 Feb 2025 17:25:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to "weird" error response trying to QDL VOLX2 (unbricking) on Tue, 11 Feb 2025 22:13:29 GMT]]></title><description><![CDATA[<p dir="auto">After trying the web interface as well as command line I am still not able to successfully flash the image. I keep getting the same error above. Regardless of what position the switch is on the device only shows up in QDL mode.</p>
<p dir="auto">If there is no other method for force flashing the device (There does not appear to be any physical switch or button other then the one) do I need to submit an RMA?</p>
<p dir="auto">This device worked fine and was finally able to get the cameras and everything working and it just stopped allowing adb and not showing up on my Linux PC. bummer</p>
]]></description><link>https://forum.modalai.com/post/20889</link><guid isPermaLink="true">https://forum.modalai.com/post/20889</guid><dc:creator><![CDATA[brianaustin]]></dc:creator><pubDate>Tue, 11 Feb 2025 22:13:29 GMT</pubDate></item></channel></rss>
