<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Microhard not connecting to USB]]></title><description><![CDATA[<p dir="auto">Hello, I'm using a standalone microhard USB carrier board, and suddenly it's no longer connecting to my laptop over USB via the USB HOST port. None of the LEDs change when I plug in the USB, and the device does not show up on the laptop. I checked with another microhard carrier board using the same cables and it works just fine, indicating that there is something wrong with the board itself. Is there any kind of reset I can attempt? Have you seen this issue before?</p>
]]></description><link>https://forum.modalai.com/topic/4132/microhard-not-connecting-to-usb</link><generator>RSS for Node</generator><lastBuildDate>Wed, 10 Jun 2026 09:04:10 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/4132.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 29 Jan 2025 18:20:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Microhard not connecting to USB on Wed, 29 Jan 2025 18:40:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2811">@Gus-Meyer</a> It looks to be some kind of configuration issue rather than a hardware issue. If I turn on the board while pressing the S2 switch, the USB connection is recognized. But I'm assuming this puts it in some particular mode where the device isn't used normally, because I do not receive an IP on the ethernet device under this circumstance.</p>
]]></description><link>https://forum.modalai.com/post/20692</link><guid isPermaLink="true">https://forum.modalai.com/post/20692</guid><dc:creator><![CDATA[Gus Meyer]]></dc:creator><pubDate>Wed, 29 Jan 2025 18:40:39 GMT</pubDate></item></channel></rss>
