<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Concurrent Use of Two PMD TOF Sensors]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">Can the VOXL be configured to interface two PMD TOF sensors concurrently?</p>
<p dir="auto">Kind Regards,<br />
Aron</p>
]]></description><link>https://forum.modalai.com/topic/411/concurrent-use-of-two-pmd-tof-sensors</link><generator>RSS for Node</generator><lastBuildDate>Fri, 09 Oct 2026 08:30:46 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/411.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 23 Aug 2021 05:39:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Concurrent Use of Two PMD TOF Sensors on Wed, 25 Aug 2021 03:06:10 GMT]]></title><description><![CDATA[<p dir="auto">Actually, I don't think it's possible because two identical PMD sensors will have the same I2C ids and communication will interfere. All cameras, with the exception of right stereo (if stereo flex is used) are communicating on the same (primary) i2c bus. The right stereo camera uses the secondary i2c bus. If it were possible to change the I2C id of the PMD sensor, then it could work, but I am not sure if that's an option.</p>
]]></description><link>https://forum.modalai.com/post/1993</link><guid isPermaLink="true">https://forum.modalai.com/post/1993</guid><dc:creator><![CDATA[Alex Kushleyev]]></dc:creator><pubDate>Wed, 25 Aug 2021 03:06:10 GMT</pubDate></item><item><title><![CDATA[Reply to Concurrent Use of Two PMD TOF Sensors on Mon, 23 Aug 2021 15:37:38 GMT]]></title><description><![CDATA[<p dir="auto">The VOXL board can handle multiple TOF sensors, but this is not a configuration that we support with voxl-camera-server. It would be possible to have custom processes running that fetch data from the specific ports. If you wanted to try this you could look through the deprecated <a href="https://gitlab.com/voxl-public/old-projects/voxl-hal3-tof-cam-ros/-/blob/master/source/src/hello_hal3_camera_mgr.cpp" rel="nofollow ugc">hal3-tof-cam-ros</a> project for how to fetch image data from hal3 and send it to the royale/spectre libs for processing.</p>
]]></description><link>https://forum.modalai.com/post/1970</link><guid isPermaLink="true">https://forum.modalai.com/post/1970</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 23 Aug 2021 15:37:38 GMT</pubDate></item></channel></rss>
